Question about Dometic Rooftop RV Air Conditioner
UNIT WAS ACCIDENTLY CONNECTED TO 240 VOLTS AND NOW WON'T WORK. REPLACED A $70 RELAY AND IT STILL WONT COME ON. HAL
    President:
  • 1,515 Answers
Hi, it doesn't take very long at that voltage to take out motors and controls. Normally, you will blow fuses, or the motors will trip out on there over loads, so Hook it back to 110 volts and start the process off checking the motors, compressor, thermostat, ect. I have worked on a/c systems for 30 years, and 2 times I have hooked up my service equipment to 240 volts. The motors in my recovery machines lasted only a few seconds before smoking the windings. If you have a digital meter and are familur with using it, you will need to check all of your motors. Or, you can disconnect each one and apply 110 volts to each one to see if it runs. You have to be very careful as this is very dangerous if you know nothing about voltage and amps! !/10 of 1 amp will stop your heart, and you are working with around 30 amps, so keep this in mind. This will be a process of elimination on the parts that may have burned out. If you have 110 volts in all the right places such as the compressor and condenser motor, they should be running. Make sure you didn't burn out the thermostat by taking off the sub-base exposing the wires and jumping them out to see if it comes on. If it does, the stat is faulty. More then likely, you didn't burn out any control voltage parts. Check what I have asked you to, all motors, take the run capacitors and have them checked, but draw you a diagram on how they are wired and a parts house will check them for nothing to see if they are shorted or open, (dead ) internally. Please don't forget to rate me as I know you will be kind. Please keep me posted on this so we can get this going for you.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Posted on Sep 11, 2010
The elements only work if the fan is turned on. And they do not get real hot and the fan does not go full speed why is that?
Bad wiring. I'd guess you are trying to run the elements via the fan! Double check your work. This could be a very dangerous situation if not to you, those near you.
Apr 01, 2015 | Kitchen Ranges
Ion tailgater speaker - changed the ac switch from 240 to 120 and now it wont work? Live in uk if it helps
Hi
The fact that you live in the UK is key to this. The mains voltage in the UK is normally 220 - 240 volts and your system should be set to 240 volts. If you changed the voltage switch to 120 volts and then tried to use it, you will have connected circuitry within the box designed for 120 volts to 240 volts. This will have damaged some of the circuitry for sure.
Your best bet is to return the ac switch to 240 volts and hope that the 120 volt and 240 volt sets of circuitry are completely isolated from each other within the box, so that resetting the ac switch will allow the kit to work.
I strongly suspect that the kit will need to be professionally repaired, and will be useless until it is.
Not perhaps the answer you would have preferred but hopefully of some help, if so would you please register that with Fixya
Cheers
Mar 06, 2015 | AC Cars & Trucks
I have a 1989 560sec everything on but starter wont turn over any suggestions?
If everything else works { lights, radio etc } then check the connection at your starter.
Aug 17, 2014 | Cars & Trucks
120v on bake element red wire and element wont heat up
the reason its not heating is because you will always have 120 volts on this red wire due to its being connected directly to one side of the in coming power source,its either that you lost the other 120 volts of power coming into the unit,a tripped breaker/fuse/etc. or the control board relay that supplies the other 120 volts to the element for a combined 240 volts needed to heat the element,if you have 240 volts to the connection to the unit then you either a bad control board or the Neutral incoming power wire could be burned off which you need to get 120 volts to operate the control board which operate the relay to supply the element with the required 240 volts to operate
Oct 27, 2012 | Jenn-Air JMW8530C Electric Double Oven
Dryer and electric cookstove
First make sure that the circuit breakers are compatible with the installed circuit breaker panel. If you have to force it or jerry rig it, replace with the correct one. Then make sure that you tightened down the terminals and that you are using the correct wire size - 6 awg for the 50 amp and 10 awg for the 30. Then verify that you connected the wire correctly to the new outlets you installed.
The voltage between the Hot lead at 7 o'clock and W 120-volt, Hot lead and G 120-volt, W and G 0-volt1_1_2012_4_17_30_pm.jpg
The voltage between Y and X should be 240-Volt, X and W 120-Volt, Y and W 120-Volt, X and G 120-volt, Y and G 120-volt, W and G 0-Volt
Hope this helps! Hal aka ImJustAvg
Jan 01, 2012 | Dryers
Installed LG split system. The unit does not
Any chance that you've got L1 and L2 hooked up to the same leg of the main? That would still give you 120 on each but not 240 from L1 to L2 like it should be. I'm not familiar with the LG system, but I would think that a comm line would have two wires.
Jul 14, 2010 | LG Art Cool LA181CNW Split System Air...
Dewalt radio accidently plgged into 240 volt outlet.... Help!!!
There's a good chance they fried it if it's designed to run on a 120v circuit. The main part that turns on the LED might have handled it, but the more sensitive areas were probably overloaded. Does it work with the battery in it?
May 04, 2009 | Dewalt DC011 AM/FM Radio
110 volt photo frame connected to 240 volts outlet in India.
I hate to tell you this but I am sure it is fried.
Jan 26, 2009 | Lands Phones
No power
First thing to do is pull the oven and check if there is 240 volts going to the oven. The display works off 1 of the 120 volt legs of the 240. If you have the 240 volts, then your issue is with either the display or relay board.
Jan 06, 2008 | GE Profile JTP18 Electric Single Oven
Dometic Rooftop RV Air Conditioner Logo
57 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Donni Steen
mike cooper
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
