Question about DFI WB72-SC Motherboard
Need manual for wb72 main board - DFI WB72-SC Motherboard
    Guru:
  • 377 Answers
Posted on Sep 11, 2010
Is there a repair manual for insignia NS-LT-DVD-26?
Service manuals are hard to find now a days, even service parts. Check the link provided to find the main board for your LCD.
Finding the tuner alone might be hard or if you do, it might cost you the same as replacing the entire main board.
Let me know if you need further assistance. Insignia E23546 Main Board For Insignia E15318G NS LTDVD26 09 V260B1 LN1
May 06, 2014 | Insignia Televison & Video
La40a450c1dxxy service manual
i have been told that my power suppy board has gone out and i need to know how to fix it and where it is
Jul 10, 2013 | Televison & Video
Ge dpgt750
test the main control board. God bless you
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
Jul 09, 2013 | Dryers
How do I test the y-sustain main board from a philips plasma tv...tv model is 42PF7220A/37 the Y-Main sustain number is LJ92-01200A....both buffers tested bad but now I dont know how to test the y-main...i...
Hi.
As such boards are cheap and fail quite easily (both the two sustain and the buffers) Philips service manuals are more oriented at board swapping then at proper testing. In this particular case the buffer boards fail very easily because of a bad soldering to IC. The short will regularly blow the main sustain board.
To start when a main sustain (e.g. Ysus) is fried the TV will go in protect mode with the led flashing in standby. One test is done disconnecting the Sus board (with power off) and restarting the TV. If TV does not go in protect, then the sustain board was good.
If there is no protection:
The first thing to check on a main sustain board is the fuse. If the fuse has blown the IC is probably fried.I believe fuse is F5004. Check for swollen capacitors that may have blown. Test the FET. That is the core of the board as it is the power amplifier.
Here the service manual:PHILIPS_SM_15540.pdf - Right Click "Save Target As"
Here a more useful service manual. Check and follow troubleshooting diagrams in manual.
Here some troubleshooting from users.
Note:if buffer board was shorted, then the main sustain board is usually faulty.
Regards.
Ginko
Sep 13, 2011 | Philips Televison & Video
AEG OKO LAVAMAT 86820 Update .Its dead.How can i fix it, but first, open the door without being pluged ?
Hi.
First you need to do an emergency emptying by accessing the filter.
Follow page 34 and 32 in this manual.
If you repute the solution helpful, then please do not forget to accept the solution.
Thanks.
Ginko.
Sep 13, 2010 | AEG Washing Machines
I hear some beebs sound in mobo WB72 revA1. but no
http://www.5starsupport.com/info/beep_codes.htm
here you will find some info about the beep codes and what it means...
Jan 31, 2010 | Computers & Internet
When i plug in my memorycard adapter into the usb ports .the baloon says i need a hispeed usb host controller.
The memory card you have is for a USB2 configuration and the USB port configuration or port you are using is USB1 configuration.
Try a different port or check the manual for port layout or description.
Sep 26, 2009 | DFI WB72-SC Motherboard
How to connect plugs of front panel in the main board?
the power switch connector goes vertically where it says pw on the pins at the bottom right of the board. there is a diagram in the user manual on page 23. you can download the manual fro their website.
Thanks
Apr 05, 2009 | Gigabyte GA-7IXE4 (GA-71XE4) Motherboard
Replacement hose connection for Equator 3500
You can contact Appliance Desk who carry parts for all Equator models.
You can get their contact information from their website www.appliancedesk.com and also place the order online.
Jan 19, 2008 | Equator 23 in. WB72 / BB72 Built-in...
DFI WB72-SC Motherboard Logo
273 people viewed this question
Top DFI Computers & Internet Experts
mukhtar21 shaikh
mukhtar21 shaikh
Tony
Matthew Spark
Matthew Spark
Are you a DFI Computer and Internet Expert? Answer questions, earn points and help others
