Question about Seagate Computers & Internet
I cannot boot my PC when the seagate hard drive is attached. I have to disconnect the external Seagate drive and then boot. Once booted I can physically plug in my seagate External Hard drive and it works. Why can't I leave the drive attached physically all the time. The connection will wear out eventually if I keep unplugging and plugging it in. Is it because the system doesn't recognize it?
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 146 Answers
Restart the system, while restarting , press delete/F8 to enter in BIOS menu, select boot priority and select the primary HDD as first boot device, deselct the "boot otehr device" option.
it should work fine.,
Cheers!
Posted on Sep 11, 2010
My external hdd has is not detecting
Seagate is a company that manufactures external hard drives.
These hard drives can be used to house large files or even to backup an entire hard drive.
When your Seagate external hard drive is not working properly, you might ready to send it into the company for repair.
Before you send it away, you can troubleshoot the problem and potentially save yourself a lot of time and grief.
Look over the power cable going from the wall outlet to the back of the Seagate hard drive. Make sure that there aren't any breaks or tears in the electrical wiring.
If there are breaks, replace the power cord.
Look over the power cable and make sure that it is plugged into the wall outlet in your home as well as plugged into the back of the hard drive.
Plug the power cable directly into the wall outlet or into a surge protector.
Do not plug the power cable into an extension cord.
Seagate Data Cable
Disconnect all of the USB devices that are plugged into your computer's USB ports except for your mouse and your keyboard.
Disconnect the Seagate external hard drive from your computer.
Unplug the power cable from the back of the Seagate external hard drive and restart your computer.
Wait until your computer has fully booted and then plug the power cable back into the hard drive.
Look over the USB data cable to make sure that there are breaks or tears in the cable.
Look over the ends of the cable where they meet the computer and the hard drive.
Make sure the pins are straight.
Replace the cable if needed.
Plug the data cable into the back of the hard drive.
Plug the data cable into your computer.
Hope this helps.
Nov 23, 2012 | Seagate FreeAgent Go 250 GB USB 2.0 Hard...
How can I fix my Seagate Free agents 250GB? It gives a faint beep and not recognised by the system
try to hard boot your hard drive by removing the cables and press n hold the system since your hard drive is inserted there. But if it is a separate device from the pc, do the same separately. If ain't work then go ahead & contact Seagate for repair..
Sep 16, 2011 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Its slow, does not boot up after shutdown (unless re-plugged again) disconnects randomly and has hard time searching files!
download the seagate utility from seagate and run a diagnostic. It will tell you what's wrong with the drive. Your drive should have come with this software on it.
Oct 25, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
500 GB Seagate freeagent classic - windows 7 won't start when power cord is connected. Okay to connect after boot up and HD works find. Is there a workaround that will allow the external HD to remain in...
Most likely the problem is that your computer is trying to boot from your external hard drive and that why windows 7 wont start up but it is a very easy fix. with the freeagent attached start up your computer system and when the first BIOS screen is displayed press either the F8 key or the ESC key to enter BIOS setup it should say on the screen which button you need to press. Once you press the correct button the BIOS set up screen will load there should be tabs at the top and select the boot tab, under the boot tab there will be a list of devices in the order that the computer will try and boot off of them all u need to do is move your freeagent to the bottom of the list and every thing will work perfect.
I hope this helped.
Thank you,
Norse
May 18, 2010 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
I HAVE A SEAGATE EXTERNAL DOES THE SAME THING
yes the PC will not boot when the external driver is connected, thats cause you dont have any boot files on the drive.
Jul 18, 2009 | Western Digital 250GB MyBook External USB...
Wd and Seagate usb hard drives attached to computer Will not boot when WD usb hd on Seagate makes no difference
Check the drive letter assignment for the disks, and make sure it is not the C: driver.
I am assuming you can boot and then plug the disk, right?
So use the Disk Manager to check the driver letter, and change it if it is conflicting with another disk.
Jules
Apr 22, 2009 | Western Digital My Book Essential Edition...
Seagate Free Agent Drive Cannot be Modified on Mac G5
First of all Hello John :)
The new seagate drive you got needs to be unpartitioned and its file format system needs to be deleted and changed.
NB: You will lose all your data so make sure that you copy everything useful off it before you do these steps.
1. Get hold of a windows PC and right click on my computer
2. Choose manage ... choose disk management right click on the drive and delete the partition type
3. delete again until it comes unpartitioned space
4. Then go to your mac and you should be able to format it as a regular Mac drive.
5. If the Windows PC is inaccessible. Get hold of a copy of Linux UBUNTU distro. Boot your MAC from CD choose to boot os from CD (don't worry it will install nothring on your MAC it will just use the CD but make sure you choose the right option)
6. Keep your hard drive attached so it gets detected during bootup. Once the UBUNTU OS boots choose GParted and from there do the same thing i explained above.
Hope that this was of help :)
Cheers
(please take some time to rate solution)
Jan 06, 2009 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Connecting my Seagate 500GB USB drive reboots PC continuously.
update the firmware from seagate official,sir,any problem u can contact with me,thanks honglake@gmail.com
Nov 09, 2008 | Seagate FreeAgent Pro - 500GB, 7200 RPM,...
Computers & Internet Logo
505 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
