Question about AEG T57800 Electric Dryer
AEG T57800 condensing tumble dryer. Randomly the machine will run for a while and then start to beep with an error E60 but will continue to tumble the clothes. The beep is sometimes very weak and only just making the noise. Then the door will pop open and the machine will stop. If you turn it off and on again it will work for a short time then do it again. It will work fine on the 30 minutes setting which does not involve detecting the dampness of the clothes. I have cleaned the inside of the drum with white vinegar as reccomended by AEG book. Cleaned out all the condensing exchanger cartridge and all the airways I can get to. Also taken the back panel off to clean around the heating element. Air flow around the machine is also good. Please can you help?
  • dawrhants Sep 11, 2010
    Thanks for this. Sounds right as the beeping does sound quite sad at times and as if moisture is shorting someting out or low voltage. I will have a look now.
  • 10,319 Answers
The code E60 means low voltage. Theis means you can have dampness in the circuit which will hinder the voltage output or another problem in the breaker box such as the same. Moister will deduct the current flow in electrical lines as you may know.
Posted on Sep 11, 2010
  • 1 more comment
  • frank thomas wilson
    frank thomas wilson Sep 11, 2010
    try using a hair dryer to dry the circuits and all connections with the dryer unplugged
    good luck and keep me posted
  • paulkrom Oct 24, 2010
    You should read the sub code: the rotary switch to Lighting (one turn to right), press the 2 most right bottums under the display. it will show you the latest error code. intermittent E60 is very often E62. this means that the air around the heater has is more than 80 C. it can be multiple reasons: 1 you put to much wash in the dryer at the same time, blocking good airflow 2) the Airflow is blocked because of dirty condensor blocked for other build blocking, the NTC in the heater are dirty or malfunctioning. The heater is at the back of the dryer. to access remove the power plug, remove the plastic cover (3 screws) and the large metal cover (many screws rubber coating)
E60 code on Aeg lavertherm dryer understand it us
Yes the NTC or thermal cutoff failure can cause E60 error.
It may look something like this.
AEG Thermostat Thermal Limiter
For diagrams of your dryer refer this site.
AEG LAVATHERM 60750225500 Tumble Dryer Thermostat Spares Parts
Sep 20, 2014 | Dryers
How do I fix my AEG Lavamat T57800 dryer
E51 - Motor power triac short-circuited
Motor faulty ; Wiring faulty ; Electronic board faulty ; Motor capacitor ; also check tension of belt
Dado
Jul 15, 2014 | AEG T57800 Electric Dryer
Why is my dryer beeping and showing E60?
The last alarm code memorized can be displayed even if the appliance is in normal operating mode (e.g. while the drying programme is being performed): - Press (start/pause) and first option button simultaneously for at least 5 seconds: the display shows the last alarm.The alarm sequence continues to flash as long as the two buttons are held down.
The appliance continues the cycle while the alarm codes are being displayed. If the appliance is in programme selection mode, the options previously selected are stored in memory.
E60 is family fault code but after reading last alarm you will see exactly fault code (E61; E62; E63)
E61 - Insufficient heating (maximum time exceeded)
  • Heater unit faulty
  • Wiring faulty
  • NTC sensor incorrectly calibrated/out of position
  • Electronic board faulty
E62 - Power reley to heater unit faulty
  • Wiring faulty
E63 - Intervention of auto-reset thermostat on the heater unit
  • Thermostat faulty (replace heater unit)
  • Wiring faulty
Dado
May 10, 2014 | AEG T57800 Electric Dryer
T57800 errore e60
What's the problem?
Jan 15, 2014 | AEG Dryers
Dryer stops and Beeps with Error code E62
You machine needs to be entered to the diagnostic mode, so that you can test the components. But it appears the thermostat or control board is having an issue, and it could because there is lint built up.
Jan 11, 2014 | AEG T57800 Electric Dryer
Got new tmbledryer week old no digital display checked fuse on plug
Cheapest price search results for AEG T58840- Tumble dryer- Technical details, features, compare prices, AEG T58840 buying guide, reviews, tests, d and buy a AEG Lavatherm T58840 Electric Dryer from 419 at Deal Time UK.See images, features, check best price and 2 reviews and ratings by people who have bought this Aeg T58840: "A lot quieter than my old tumble pare prices for the AEG T58840 Washer d impartial reviews and buy online for speedy delivery only denser tumble dryer with Silent pare the UK's best prices for AEG T58840 and other Washer-Dryers from 100s of online shops.
AEG T58840 AEG Tumble Dryer Condenser, FREE DELIVERY, Buyers and Sellers offer the widest range of domestic appliances from top of the range to budget items at the most.7Kg Drying Load, Condenser Dryer, Sensor Drying, Large LCD scree, 20hr Delay rn everything you need to know about tumble pride ourselves on our customer service and the best prices on internet for the AEG Appliances Tumble Dryer Condenser Freestanding T58840 from BHS pare prices from across the web and read product reviews on AEG Lavatherm t58840 compare prices on Aeg t58840 from online T58840 Condencer Dryer- 7kg Load in White.
T58840: 7Kg Condenser Tumble Dryer in White: 433.97: AEG: T88840: 7Kg Condenser Tumble Dryer in White: 535.00: AEG: T35850: Vented Tumble Dryer: 264.97: AEG: Electric Shop supply AEG T58840 7Kg Condenser Tumble Dryer in White from leading manufacturers at discounted T35850 Vented Tumble Dryer- Special T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 White Freestanding condenser tumble T58840 Condenser tumble Price: 448.85.Tumble Dryer Models from AEG: T35850; T58860; T88840; T58840.
Aeg T58840 Condenser Dryer, read the latest user reviews and compare prices on Aeg T58840 Condenser T58840 review, price comparison and where to buy online at Compare Store Prices UK for cheap T58840 Condencer Dryer- 7kg Load in T58840 from Chantry Digital AEG 7kg Load Condenser Dryer with White T58840 Colour WhiteManufacturer AEG7kg Drying LoadCondenser DryerSensor DryingLarge LCD Screen20hr Delay StartCondenser duct information and details for AEG Lavatherm T58840 Electric AEG T59800 Dryer is in stock at several UK k the green box and well make sure that more people get to.
Find out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in p with dryer hotpoint tumble problem on AEG T58840 Condenser Tumble Dryer Electric and free tech support for dryer hotpoint tumble d out more about the amazing AEG Lavatherm T58840 tumble dryer condenser in rything you want to know about the T58840.491.00: NEW AEG T58840- MANUFACTURE a better deal by comparing prices on AEG T58840 Washing Machines to save money online and guarantee Christmas T58840 3) Tumble Dryer Spares and T58840 3) Parts- Page 2- Belt, Door, Drum, Filter, Seal, Heater, Hose, Knob, T58840 Tumble Dryers Condenser In White Aeg The number one appliance specialist in the UK.
Condenser Sensor dryer
Large LCD Display
Sensitive Option, Leisure Programme
21 programmes including Microfibre, Jeans, Bed Linen
Easy Iron, Extra Dry, Storage dry, Hand Iron
Machine Iron, Intensive Dry, Extra Dry, Wool Care etc
Large 36cm porthole opening
Interchangeable door hinge
Manual timer up to 40 minutes
Stainless steel drum with Internal Light
Drum Light
please comment on these on how helpful.
Dec 21, 2010 | AEG T58840 Dryer Electric
Dryer stops and Beeps with Error code E60
At MaybeNow online guides are always there to provide technical support to troubleshoot Maytag Neptune MDE6700A Electric Dryer Problems which is free of cost. You can also get Maytag Neptune MDE6700A Electric Dryer, Dryers Help from archived solutions related to repair, maintenance
Dec 21, 2010 | AEG T57800 Electric Dryer
AEG 57700 only blowing cold air, heater not working
CHECK VOLTAGE=240VOLTS NOT 120VOLTS,ITS TAKES 240V TO HEAT BUT WILL RUN ON 120V.
THEN START WITH HEATER ELEMENT ..SEE IT ELEMENT IS OPEN.
THEN START RUN ING TEST ON THERMO'S TO SEE IF CLOSED OR OPEN...
THANKS FREDDY
Feb 14, 2010 | AEG T57800 Electric Dryer
AEG T57800 Electric Dryer Logo
3,440 people viewed this question
Top AEG Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Gaark
Are you an AEG Dryer Expert? Answer questions, earn points and help others
