Question about Baby Lock Sewing Machines
My machine was working fine and during the embroidery, it suddenly stopped and said "Trimming Sensor Error". I have tried everything to no avail. It will not let me do ANYTHING. I have moved to an area where I don't have service on the Babylock EMP6 and I am at a loss of where to go from here.
I have found that this error most commonly is a result of a lot of thread caught in the cutting blades preventing the cutting blade from moving. See the "Cleaning around the Needle Plate" in the User Guide or "Cleaning of Knives and Rotary Hook" on page 316 (or 6-6) in the Service Manual located at http://www.brodyrmaskiner.se/service/pr620/pr-620-service.pdf..
Posted on Oct 17, 2010
  • Nancy Early
    Nancy Early May 09, 2014
    How do you clean the wiper blade on the babylock enterprise? I've cleaned the needle plate and still no fix. THANKS FOR YOUR HELP!
How can I get my machine to stop jamming
Have you tried oiling all moving parts. Go under presser foot under bobbin and remove all lint. Try to change the needle.
Oct 25, 2015 | Brother LB-6800PRW Project Runway...
On an Elna 9006 sewing machine I have an error that reads ( stepping motor error) what does that mean.
Time to get this machine a repair shop. Motors in embroidery unit may be bad or headed that way...
Cheers,
Kelly
Embroidery Services
San Diego, CA
Nov 11, 2014 | Sewing Machines
Thread not catching to bobbin
Hai, How many heads in your embroidery machine? As far as you should have brother embroidery machine's maintain and handling is smooth and carefully. Please check the timings. Otherwise ask your machine mechanic.
Mar 19, 2014 | Brother Se400 Computerized Embroidery &...
While working, the embroidery machine stopped with this message on screen.I stopped it and worked a few stitches and the stopped again with the same message. The next day I started the machine again a
Please you ask your machine service provider or embroidery Machine service mechanic. My suggestion Normally every year machine service and over oil the machine is safest way.
Feb 06, 2014 | Sewing Machines
Janometroubleshooting
checks that the strip wire and strip wire sensor, this worked well.
(the strip threads is the small spring by which you spend the thread to thread)
Jan 04, 2014 | Janome MB4 Four Needle Embroidery Machine
Singer CE-150: Constant error messages, thread breakage, etc.
Check the sensor at the top of the machine. It is where the thread passes through the plastic "u-turn". Check to see if the wheel turns when you pull the thread through the machine. The wheel has a red marking on it. If the wheel isn't turning when you pull the thread, it may not be sensing the threading correctly.
I hope this helps. God bless you!
Mar 09, 2010 | Singer CE-100 Futura Computerized Sewing...
Step motor error Janome My Craft step motor error shows up on screen and then stops. Turn machine off, sometimes comes back straight away then another time it may be a day or so later. Is this a motor...
If it really is your motor overheating, you either need it serviced, or replaced, possibly with another machine which is more suited to the type of sewing you do.
Feb 19, 2009 | Janome Memory Craft 9000 Computerized...
Stepping motor error on embroidery machine
Hi again and welcome back to FixYa.
It is nice of you to remember. To your concern, possibilities are:
  • if the grinding noise is coming from the bobbin case area, then pls ensure that nothing is stuck/caught there, it would only take a small foreign object to trigger the problem; or
  • verify that the embroidery carriage in its parked/original position;
  • there would be a sensor/switch that tells the computer that the embroidery carriage is back. Pls check that if the carriage is back and see if you can check the sensor/switch;
  • worst case scenario is that the controller's circuit board is faulty. In some case, it could just be the wires or connection leading to the controller board.
Good luck and Thank you for using FixYa again. Happy Holidays.
Dec 07, 2008 | Sewing Machines
Sewing Machines Logo
357 people viewed this question
Top Baby Lock Sewing Machines Experts
Tally Girl
Tally Girl
Jon Piercy
Jim Goldsmith
Jim Goldsmith
Are you a Baby Lock Sewing Machine Expert? Answer questions, earn points and help others
