Question about Kenwood KM800 Major Classic Stand Mixer
Mincer attachment is stuck at right angles to the mixer & won't turn either way. Had been mincing fine, but material needed clearing out & trying to remove attachment, it stuck
Unable to remove Bamix mincer attachment, any advice?
Try to gently wiggle it off with needle nosed pliers.
May 07, 2014 | Bamix 391120 mincer blade
Kmix mincer not rotating
Hi, it sounds like a broken gear.
Send me your email
Aug 12, 2013 | Kenwood Ax950 Attachment For Kmix Stand...
Compatibility of mincer attachment
1) remove the front power outlet of the mixer head.
2) look for a notch in either the top edge or the bottom edge of the casting. (hole)
3) Guide Pin on 9xx accessories is at the top of the connecting shaft.
4) if notch and pin point in the same direction, accessory will usually fit (9xx acc's point up and 7xx acc's point down)
May 30, 2013 | Kenwood KM300 Chef Stand Mixer
I have Kenwood Major Classic (Grey colour) will a mincer A720
Hi. I've checked the Kenwood Service website and from what it looks like, A720 mincer is only suitable for A701, A701A, A702, and for Major models A707, A707A, A717.
The mincer specified for the KM800 (from it's owners manual) is the
A950.
May 20, 2010 | Kenwood KM800 Major Classic Stand Mixer
Kenwood mixmaster spare parts
Hello you need a complete mincer, or a mincer part ?
try in 4kenwood.co.uk ( be careful )
or in Ebay.co.uk
Billingtonelec.co.uk
regards
Kenwood Chef Restore
Dec 10, 2008 | Kenwood KM800 Major Classic Stand Mixer
I can't find the model number on the mincer attachment I have that shows which model process it fits
Hi. if you have a mincer without box, you cannot see the model, but. its simple know for what model fit.
you see in your mincer the connection shoulder have a pin.
if the pin its in the botton, its model A700 /701/702/703
if the pin its in the top. its for models A900 and ahead
click here for more info Kenwood Chef Restore
Aug 24, 2008 | Kenwood KM300 Chef Stand Mixer
? Hobart A200 Mincer/Mixer wont work
does the motor have brushes? If so the mixer will have two removable covers on the back motor plate. If so take some light sandpaper to the part called the comutator that these carbon brushes ride on and make them shinny. If you have a newer style motor that doesnt have brushes. pull the motor cover and make sure the start switch is cleaned by sanding the contacts. If you check your wiring with a ohm/volt meter and it all checks good, well, the first question I should ask is does it hum? if not, the problems in the wiring or power switch. if it humes the problems in the comutator, start switch, capacitor or your motor is shot. unlikely for a mouse infestation. most likely wiring or switch problem.
Apr 06, 2008 | Hobart A200 Stand Mixer
What kind of bang was it ? an electrical or mechanical. The A-200 has a stator and rotor assy with a start capacitor and relay behind the back cover at the head of the unit. You can access the retaining nut for the rotor (motor) shaft by removing the small 2 inch cover and getting a wrench on the nut and spinning it by hand. The handle you mentioned with the three numbered selections are your speed settings and everything is driven through a planetary drive. Hobart A-200 have been around longer than I have (im 48) and are work horses and in my opinion, are the top of the line for mixers. Put it this way, I would take a 25 year old A-200 over a brand new Varimixer or other brand name. You can access parts manuals and break downs on Hobarts web site with model # and M/L # any other question e-mail me capt_rick1912@yahoo.com if you cant find what you are looking for I will e-mail you a wiring diagram (found behind the small gear selection cover on side) Good Luck......Rick
Kenwood KM800 Major Classic Stand Mixer Logo
203 people viewed this question
Top Kenwood Food Mixers Experts
ashburton
Treefrog15
Treefrog15
Are you a Kenwood Food Mixer Expert? Answer questions, earn points and help others
