Question about GE WBSR3140DW Top Load Washer
GE WNSR3120W0AA about 11 year old top load washer everything seems to be working, fillsup, agitate, pumps drains except it does not spin. recently had developed a loud noise during spin cycle and now it just humms but does not spin. Thanks ashvin.baxi@gmail.com
JULIANFIX
  • 975 Answers
SOURCE: GE Washer won't drain or spin
this is something that you can fix even if your not a technical person . first you have to open the washing machine front panel or back panel , second , follow the DRAIN HOSE to where its connected to a little motor, disconnect the DRAIN HOSE , take the LITTLE MOTOR out and clean it out , it could be clogged.
it happen once and find out the person put the BATH RUG SET
to wash , the rug was so old that pieces of a rubber underneath the rugs clogged the drain , so there was no rinse and no spin.
try it , I hope it helps.
Posted on Apr 16, 2008
shaggyrat
  • 1224 Answers
SOURCE: GE top load washer will drain but not spin
you both need to have the switch replaced or you can open top of washer and combine the lid switches wires together as a bypass and electrical tape
the lid switches are put in the washers to keep kids from opening the washer machine this is automatic shut down
for xenazoe
you require this part for your washer
Part Number: WH12X10065
SWITCH PRESSURE
Posted on Jun 13, 2008
sdmc73
  • 121 Answers
SOURCE: grinding noise spin cycle jumping around
what brand
Posted on Nov 29, 2008
  • 7 Answers
SOURCE: Washer won't agitate or spin out.
Well it is ethier Belt, Cluch ,motor ,Or transmission. But it does sound like your transmission . The loud clunk is the brake in the gear case ( Trans.). It might have broken off.
Posted on May 05, 2009
  • 111 Answers
SOURCE: GE Washer does not drain or spin
Inspect the drain hose for kinks
Test the timer control
Test the lid switch (some models)
Inspect the water pump
Inspect the drive belt (belt drive only)
Inspect the motor coupler
Posted on Jul 15, 2009
GE top load Profile washer. Spin cycle not
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Jun 11, 2010 | GE WVSR1060A Top Load Washer
Gets stuck in drain phase, spin cycle working too hard, flooding
I know that this isn't what people want to hear in situations like yours, but...that definately is the quality of GE. With everything you've described...its' going to cost about 2x what you paid for it between diagnostics, repair & labor. I'd start shopping for anything with a Whirlpool name. Over the years, GE has had MAJOR KNOWN PROBLEMS with their gearcases (transmissions). My parents had a HOTPOINT and it lasted three years and one day I went down into the basement and there was oil on the floor. But anyways...I'd say it's a lost cause. It sounds like it was made on a Friday. Good luck to you, and let me know if I can help you again! God Bless and Merry Christmas!!!
Dec 17, 2009 | GE Washing Machines
1.5 year old ge profile washing machine will not agitate or spin
Timer seems to have gone bad. Manually move the timer to make the dryer spin. If you get it to spin and drain then it's your timer.
Jul 01, 2009 | GE WDSR2080D Top Load Washer
Doesnt agitate or spin.
Mine is 1 1/2 years old and this worked for me
unplug from power for at least 30 seconds
turn the dial to spin but don't pull out
plug back in to power and open and shut completely so switch is engaged solidly 11 times in 15 seconds.
pull out knob to turn on
This should clear a error code.
hope it helps!
Jun 02, 2009 | General Electric WHDSR316G Top Load Washer
Ge top loader washer agitator does not work
To check the agitator. Start the washer into wash cycle. Once started Push down on top of agitator. If it catches some times or all of the time when pushing down, then then doggets are worn, under the agitator. You`ll have to remove the agitator to see these. If by pushing down on the agitator, nothing changes, Then you probably have a transmition problem. Check this and let me know what you find.
Nov 27, 2008 | Kenmore 22422 Top Load Washer
GE WDSR2080D5WW Top Load Washer
sounds like the agitator is bad not hard to replace look up on internet agitator replacement for that model
Sep 10, 2008 | GE WDSR2080D Top Load Washer
GE washer eill not drain or spin.
if the unit is at least 4 or 5 years old, most likely the pump is clogged with the same hair.....that clogs vacuums. you probably can fix it yourself provided you can get to the pump without too much trouble. i'm not familiar with all the brands designs. maybe someone else on this sight can help. if this is not the problem than most likely some of the timers points are burned. if the unit is more than 10 years old and/or the unit has been used unusually alot there is the possibility that the transmission has problems, but that is pretty unlikely. hope this helps.
Mar 05, 2008 | GE WDSR2080D Top Load Washer
GE Top Load Washer 10 yrs. old, used for 3 years, stored after that
the water must drain out of the tank b4 it can spin make sure the pump is working ok
Nov 17, 2007 | GE WBSR3140DW Top Load Washer
Washer won't drain - completely.
I have been having the exact same problem in a top load Kenmore 80, starting about a year ago when I replaced the pump because the old one, (30 years old), finally seized it's bearings.
The new pump design has some rough edges near the water exit port and lint slowly collects there until it stops it from draining properly. Since the lint clumps do move around a bit, when the problem first starts occurring it is an intermittent problem, but as more lint accumulates it gets worse and worse.
The old pump couldn't be taken apart, (and never need to be taken apart), but the new one can be disassembled rather easily and when the lint clumps are removed everything works great for another month or two.
The pump is the so called direct replacement from Sears, for the washing machine that they sell, but obviously is not well suited for machines like mine that do not have lint filters.
I suspect they want to render my machine obsolete so that I buy a new one, after all they don't make much money selling 1 washer every 30+ years, especially if it rarely needs service. Why else would they sell pumps that don't work in place of pumps that worked well and lasted over 20 years.
anamouse@earthlink.net
Nov 08, 2007 | GE WDSR2080D Top Load Washer
GE Model WBSE2090A2WW - shut off intermittenly
Does the machine drain on its own or do you drain it manually? The drain pump may be jammed or seized. Try giving the door a light bang with your hand on the handle. The door interlock could be faulty. If the machine starts up after you hit it with your hand on the door handle, the interlock is faulty. Good Luck!!
Sep 07, 2007 | GE Energy Star WCVH6260F Front Load Washer
GE WBSR3140DW Top Load Washer Logo
56 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
