Question about Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set
Sony clock radio with auto time set is always 4 minutes fast.
This is easily fixed. Set the time manually the 1st time. Make sure you use the CORRECT time, which is four minutes less than what the clock said when you first plugged it in. Once you reset the timing, it will remember the four minute difference and always show the correct time.
Posted on Feb 05, 2011
How do I set the clock in the radio?
Typically, you have to hold down a "Time" or "Clock" button, then press either a fast or slow button and hold it until the display reads the correct time. Some models have hour and minute buttons instead of fast or slow, and a few have a slide switch that you move to the clock adjust position (it would also have an alarm set position) before the hour/minute or fast/slow buttons are enabled. Some clocks reset to 12:00 AM if you hold Clock, Fast and Slow all at the same time. You'll just have to experiment a bit to find out what works on yours.
Jun 25, 2015 | Audio Players & Recorders
I cannot set the clock radio with automatic time set due to daylight savings timem change
I have the same clock and am always able to change it manually with no problems....have you tried unplugging it for a few minutes and then powering back on to see if it adjusts properly?
Nov 04, 2012 | Sony Dual-Alarm AM/FM Clock Radio with...
Set tme 4837 clock radio
I have the same clock radio and I found out that you have to hold down the button and run through the times. The hour will change with the minutes. It goes pretty fast once you hold down the button, so I stop when I get close (like within 20 minutes of where I need it to be) and then click it one minute at a time until it's at the right time.
Jun 09, 2012 | GE 7-4837 Clock Radio
Sony IFC-218 clock radio runs 8-9 minutes fast
Hold the 'Clock' button until the display flashes. It will first show the year, next press on 'Clock' with show the month, then the day, then the time. Use + and - to set your time and press 'Clock' again.
Don't expect this clock to set the time by itself. It is not an atomic clock.
Nov 29, 2011 | Sony Audio Players & Recorders
I have model cd 3424 and cant set clock
This was taken from a radio similar to yours. Same brand but different model. Hopefully it'll help.
(Also the "SEL" button it talks about is a big round button/knob on the right of the unit.)
Setting the Time
This receiver uses the 12-hour display notation.
1 Turn [SEL] button to select CLOCK ADJ.
2 Press the [SEL] button.
The clock adjustment mode is activated.
3 Turn [SEL] button to display the item to be selected for
adjustment.
Hours, minutes or exact hour will be switched each time the
button is turned.
4 Press the [SEEK / FAST] button.
[SEEK] button: Turns the time forward.
[FAST] button: Turns the time back.
To set the clock to 0 minutes, 0 seconds (an exact hour),
press the [SEEK / FAST] button.
For example:
At 3:29: Pressing the [SEEK / FAST] button returns to 3:00.
At 3:30: Pressing the [SEEK / FAST] button advances to 4:00.
5 Press the [RTN] button.
At this time, other adjustments can also be made in
Function Mode.
6 Press the [FUNC] button to exit Function Mode.
Mar 02, 2011 | Eclipse CD3422 CD Player
My sony radio alarm clock is too fast about 1 hour. i have moved in the philipines. but my alarm clock is working too fast; ie, it does not show the exact time (about 70-80 minutes) faster
alarm clocks works on frequency and not only on voltage.if it is original 110v 60htz and you trying with 220v 50htz supply then it wont work correctly
Jun 04, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
The auto time set on my Sony Dream Machine is five minutes fast and I don't know how to get it to sync properly. I've tried unplugging and plugging it in again, but it always comes back with the incorrect...
Have you tried to manually reset the time? I had the same problem. It got the the point where it was almost 20 minutes fast - I finally looked up the manual on-line and found instructions to manually reset it. It seemed to work just fine. I'm not sure if I have the same model as you do, but I'm sure the procedure is similar. I suggest you search the net for your manual.
Mar 05, 2010 | Sony Dual-Alarm AM/FM Clock Radio with...
I need the colon in the time display of the Sony ICF-C1iPMK2 to stop flashing.
Sometimes the colon is the 'seconds' count - did it always do this? Try to unplug for 1 minute and then reset the time - if it still flashes I suspect that it was a built in feature - some do this...
Jul 19, 2009 | Sony Dual-Alarm AM/FM Clock Radio with...
Brookstone smart set alarm clock. It is about 20minutes ahead
I've noticed that manually setting the clock forward or back by any number of minutes, results in the same time offset being displayed after unplugging - plugging back in. So, if it's 9pm and you set if 5 minutes fast (9:05pm). Then unplug it and plug it back in 30 minutes later (9:30pm), the clock will maintain your setting of 5 minutes ahead of the actual time (9:35).
I like to set my clocks 5 minutes fast, just to make me always think I'm running a bit late (sure, maybe I'm a bit crazy). But this "sticky" manual setting is kind of a nice feature in my opinion. I'm wondering if it's not intentional?
Anyway, just manually set it back to the real time, and it sho
Feb 18, 2009 | Brookstone SmartSet Alarm Clock
Sony Dual-Alarm AM/FM Clock Radio with Automatic Time Set Logo
964 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
