Question about Sony KP-57HW40 57" Rear Projection Television
Picture is turning blue .If you shut TV off and turn it back on,it will be good for about 30 seconds. When you turn TV on ,it will take an hour before you can see anything. Purchased Dec. 02. First time with any problems.
  • cklein58 Sep 15, 2010
    I thank you for the information. After checking into this further I found out they do not make tubes anymore so I will have to send it in to get rebuilt. Thanks again for the expert answer. Mark
  • Sony Master
  • 11,800 Answers
You have a problem with the CRT's - either they are used and need to be replaced (most likely on a tv of that age) or the video final module is failing.
Open the tv, set it on an blank channel and check the voltages on the CRT: if the voltages are steady and equal then the tubes are worn out; if they are different from each other and variable then the video final module has failed (or is about to) - fix it.
Either way it's gonna cost you around $350.
Posted on Sep 11, 2010
My Sharp LC-42SB45U takes 15 min to an hour to turn on. Also, sometimes picture blacks out for 10-15 seconds. Any suggestions? Pat Courson
Have same problem. Not the proper fix though I found that taking the back off and heating it up with a heat gun for 30 seconds to 1 minute and tv works fine till you shut it off over night.Maybe someone can offer a solution with that in mind. Pretty strange
Sep 17, 2012 | Sharp LC42SB45U 42 in. LCD TV
TV wont stay on.
Similar problem with my Sony. unplug for 36 hours and try again
Aug 13, 2009 | Samsung HL-R6767W Replacement Lamp
I loose picture on my big screen
bad voltage regulator - BA09FP requires a bit of tech experience to replace, but its relatively easy. It took me about 1 hour to replace mine. If you need clarification on this, email me at Doin12volt at yahoo
Jul 03, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Error Code 5 flashes when unit shuts down
Good Day;
It sounds like the TV may have a shorted CRT, picture tube, but let's trouble shoot:
1. Unplug TV from wall.
2. Remove speaker grill, two on bottom, the screws are covered with plastic caps, right and left side on bottom next to floor.
3. Remove inner panel.
4. The blue tube is the one the right side, remove socket, with phillips driver, make sure it's not touching anything.
5. Plug and turn TV back on, if picture appears with no blue it's the tube.
6. If still shuts down, bad blue CRT driver IC.
CAUTION: Call a factory authorized service dealer to give you an estimate, if this sounds too hard.
Good Luck, Day, Big Irish.
Jun 18, 2008 | Sony KP-51WS510 51" Rear Projection...
Tv screen goes black
No, if the picture of your tv screen is clear when when you watching. the troble of your tv is looseboard, and you replace your CRT socket too.
Apr 16, 2008 | Sony KV-35V35 TV
TV goes out
pyrosp4,
it maybe you blue crt (picture tube). mine turn blue and then shuts off. i got it repaired for 460. 300 for the part 160 to install. you can try to adjust the voltage settings behind the speaker screen and see if that clears the problem. if not its you blue crt.
pridah
Dec 18, 2007 | Sony KP-65XBR10W 65" Rear Projection...
Sony KP-57HW40 57" Rear Projection Television Logo
609 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
