Question about Cannon Magnum 10 Hs Electroncs Downrigger
Early Cannon Marlin Electric downriggers. Just up and down switch. Need elec schematic please. Cost of ? Fax or email fine
  • 905 Answers
Hi Paul,
Here is the manual for your unit, but it may not be of any use to you as there is not a schematic in it.
Cannon's Service / Tech Support info is here. They may be able to direct you to a local service center that can provide the diagram that you need, or they may be able to send it to you directly, as well as parts lists if needed.
Posted on Sep 11, 2010
Cable jumps off of roller at end of boom
I've had the same problem with my electric Walker down-riggers, the line guides didnt work well because of the crimp for the cannon ball return pully snags on the guide, the best I came up with is a cannonball snubber similar to ones used with Dipsey-Divers, made heavier for cannonballs, hope this helps
Jun 04, 2012 | Electric Cannon Mag 10 Hs Downrigger
Looking for parts & service: mag 10A cannon downrigger
Your best bet for price is looking on ebay, there are lots of links off of an inquire.
Apr 12, 2010 | MAG Cannon Mag 5 HS Downrigger
Cannon downrigger
score along the seam with a razor knife just below the cover where the screws are you need to reach an 1/16th inch deep insert a screw driver into the rubber gromet where the power cord goes in and pry open the cover be very carefull not to use any of the insides as a lever and use finess not brute force
Oct 04, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
A)will not work at all,had radio shack test out the fuse and switch;said they were fine,direct wired motor to batteryand the motor worked fine in both directions and b)have another downrigger that once the...
I may be able to suggest a cure for downrigger #1. The switches sometimes have several terminals and they work differently than they look.
For example, if you have 6 terminals, 3 on each side of the switch. The left bottom and right bottom are a pair. The middle two are a pair and the top two are a pair. Then you have terminals that are separate on the right side with the middle terminal being common and the pair being right lower and middle, right upper and middle with corresponding left side action.
This point being that the switch for unit #1 is good as tested by Radio Shack. Its where you stick the wires on the terminals that is the problem.
You need a multitester and use an OHM setting without juice flowing through your wires. This way you can figure out the pairings of the terminals without burning something up.
Aug 21, 2009 | MAG Cannon Mag 5 HS Downrigger
Used (older) Cannon Digitroll II Manual or advice
I have the quick start manual for digi-trol II. I will try to scan it and post later today.
Kevin
Jun 20, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Cannon Digitrol 1V bottom tracking not working
Hello!
Here is the user manual for your downrigger:
DT IV Downrigger
The programming starts on page 12.
Best of luck!
Mike
Jan 14, 2009 | Cannon Digi Troll(Tm) Iv Eelectric...
Electric Schematic
sorry i need your fax # i can't access the diagram & attach to email. give the fax # then.
Jun 16, 2008 | Black & Decker 19" Electric Lawnhog...
Cannon Magnum 10 Hs Electroncs Downrigger Logo
598 people viewed this question
Top Cannon Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Cannon Boating Expert? Answer questions, earn points and help others
