Question about Saniflo & Saniplus& Macerator Pump
Can I get a replacement cap for the vent on the lid of my Saniflow system ?
    Scholar:
  • Saniflo Expert
  • 115 Answers
I've been told that any spare part can be purchased through Saniflo at 800-571-8191. If you are buying a brand new pump then it will have to be purchased through a Saniflo distributor.
Posted on Sep 15, 2010
Code # PO446
P0446 Nissan - Evaporative System Canister Vent Control Valve Circuit
Possible causes - Missing Fuel cap
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Vent control valve harness is open or shorted
- Vent control valve circuit poor electrical connection
- Faulty vent control valve
Tech notes Before replacing any parts, try re-tighten the gas cap and clearing the code. If the cap or cap seal is damage replaced cap and clear the code.
Apr 12, 2014 | Nissan Pathfinder Cars & Trucks
Bolens push mower Briggs mower when pulling fo start and running pushes gas out of the ventholes of the fuel cap.
I think that you have a defective gas tank lid that is not venting properly which could pressurize your system and cause problems. Invest in a replacement and hopefully this will solve your problem. The cap has a small breather vent cover [it sort of looks like a small mushroom], this allows air to enter the tank, but keeps air/fuel from going out of the cap. Some mowers use a pressurized system, and I am not sure if Bolens is one of them.
Sep 21, 2013 | Garden
Saniflow runs, but not straight after flushing
Here is a nice link for your saniflow maintenance.
http://www.plumbteamltd.co.uk/sanifloguide.html
This will definately help.
Jan 30, 2013 | Saniflo Home
Replaced gas cap engine light came back on
most fuel systems are not vented if cap has vent that could be your prob or you have a prob with your evap system front or rear sencer could be bad or your evap canister could have mosture in it you need to have a systems check to find out what code has been thrown weather it's electrical or emmissions
Mar 25, 2012 | Chevrolet Silverado 1500 Cars & Trucks
I need the rubber lid to go on the vent holes on the lid so I can melt butter
Replacement parts, including the butter cap, for your West Bend 82306 Stir Crazy® Popcorn Maker may be ordered on-line from this site:
http://www.westbend.com/catalog.cfm?dest=itempg&itemid=3906&secid=87&linkon=subcategory&linkid=108
Feb 24, 2011 | West Bend 82306 Stir Crazy® Popcorn...
My saniflow is pumping to a fall and when flushed it blows the plug out of the sink i fitted air admittancs valves as recomended , how do i solve the problem
you have a venting issue, air admittance valves are not for venting purposes, although they do work in some situations.
you may need the services of a plumber to solve your venting issue.
Jul 19, 2010 | Saniflo Home
My saniflow dosnt allways come on when you flush
That can be a problem with the pressure chamber, the membrane might be warped or the micro switch may be defective. Open the lid and remove the motor and presure chamber. Inspect the unit for damages or any broken pieces. Check that the membrane is not warped. This can be tested manually by placing the motor on a work bench and putting pressure on the membrane to manually start the pump on and off. If parts are needed you can buy them through Saniflo directly. Their website is www.saniflo.com
Jul 13, 2010 | Saniflo 013/003/005 Sanibest Toilet with...
Gas cap light is on but cap is secured
Is this the original gas cap for this vehicle? I have ran into this issue before with some cars when people change the gas cap to a locking one. The original has certain vents that is crucial to operation. If it is the original gas cap, then your fuel tank pressure sensor could be faulty.
Feb 15, 2010 | 2006 Volkswagen Jetta
Water leaking out of breather
I have a question, I have a saniplus no problems hooking it up filled the tank and then flushed it..On the discharge end I had a small about of water puddling up at the pressed in rubber fitting. Every clamp was tight not sure what the reason is any ideas. I thought about silcone around the rubbber seal between the lid.
Sep 08, 2009 | Saniflo SaniPlus-Round SaniPlus Macerator...
Saniflo & Saniplus& Macerator Pump  Logo
451 people viewed this question
Top Saniflo Home Experts
Donni Steen
Paul Carew
Are you a Saniflo Home Expert? Answer questions, earn points and help others
