Question about Cameras
My camera got real hot now it comes on but thats all it do
    Problem Solver:
  • 11 Answers
Take the battery out and leave it to cool down for a while, try and flatten the battery and fully re-charge it to see if this helps, if not replace the battery.
Hope this helps!
Posted on Sep 11, 2010
2002 jeep liberty v6 3.7 l , oil light keeps coming on at idle at stop light. had engine flush and oil change and sender pressure unit changed out, but it keeps coming on. could it be a connector into...
Have a reputable garage check the oil pressure with a manual oil pressure gauge. Very well may have worn internal parts, or weak oil pump. Thats the only way to know for sure.
Oct 21, 2011 | 2002 Jeep Liberty
My volkswagen cabriel is heat the tampreture is coming full
Do a complete cool/heating overhaul of the system.That is radiator and hose check out.
Oct 07, 2011 | Cars & Trucks
Hey, Im using canon EOS 60 D> I have a problem
This camera is pretty new to have this problem unless you are using it with oily hands or it's in a dirty environment.
Anyway what happens is that Canon has two extremely tiny holes under the hot shoe where sensors are placed to sense the presents of an accessory in the hot shoe. What has been happening is that the alignment of these little holes is so critical that any shift in the body to hot shoe will cause the malfunction you are experiencing. This shift can be caused my simple expansion and or contraction of the two materials the hot shoe metal and the carbon fiber of the camera body.
Also normally found on a camera that's a little older then your Canon 60D is a build up of oily dirt under the hot show which then plugs these little holes rendering the sensor inoperable.
What to do?
The camera should be returned to Canon for service, yours could still be under warranty.
Another is to attempt to realign the hot shoe (good luck with this one) by gently tapping the metal part of the hot shoe with a plastic object. I used the handle of a wooden kitchen knife.
When mine stuck I was on a shoot for a real estate interior and was using the internal flash to trigger other slave flashes, the kitchen knife was there and the only thing I could find. It was more a desperation thing and I'd suggest finding something else.
Cheers hope this works out for your
Mar 30, 2011 | Canon EOS 60D Digital Camera with 18135mm...
My moen single lever faucet problem is no hot water. The water is warm at most and when you turn it off and on it goes to cold. The faucet is only 8 months old. The only way to get real hot water is to...
The hot side sounds like it has some junk in the hot side blocking the hot water from coming through check hot water line to make sure that it is coming through down below and if so you would need to take it apart and try to get the junk out of that side of the faucet.
Nov 14, 2010 | Moen 7437 Chateau Single Hole Kitchen...
Black Screen
Did you leave it in the sun . Or in a hot place ? Was it wet in any way ?
Aug 18, 2009 | Nikon COOLPIX L18 Digital Camera
REAL HOT EXHAUST
Sounds like the catilitic converter is plugged.
Jan 09, 2009 | 1991 GMC S-15 Jimmy
Hi everybody,when i on the camera it comes ABORT!
i had the same problem.so i took it apart and found that cos of that dodgy swivel camera the feed from the mother board to the camera tears right at that swivel bit and gets hot.i think the only way to fix that is to take it to someone and have it done or find the bits u need from another phone of the same brand and type and fix it yourself...
Dec 03, 2008 | Samsung SGH-Z510 Cellular Phone
Replaced water pump due to bad bearing but radiator hot
i f lower hose is not hot and the top is your thermostat is stuck closed
Nov 12, 2008 | 1993 Toyota Celica
Tiffen "Hot Mirror" filters ...
The Tiffen hot mirror works fine on my D500. On some cameras it's not needed as the lens system already has some amount of IR filtering. When IR is present it causes some tinting of sky towards purple. The filter works as a mirror by reflecting the 800 - 1100 nanometer wavelengths. This is the range that causes the problem. I wouldn't just buy one without determining if the camera really needs it. Mine may not need it in most cases but many of my pictures come from the Arctic and there's no way to do some over again. I had a real problem with a previous Casio so I didn't want to take any chances.
Sep 07, 2005 | Olympus Camedia C-2100 Ultra Zoom Digital...
Cameras Logo
16 people viewed this question
Top Cameras Experts
Steve
Are you a Camera Expert? Answer questions, earn points and help others
