Question about General Electric Cafe CSS25USWSS Side by Side Refrigerator
The doors are not straight, how do you adjust them so they will be ? The instruction manual does not show a picture...
  • 4,793 Answers
They think anybody can adjust the wheels on the bottom......you need to tip the unit to adjust level
Posted on Sep 11, 2010
The full screen picture is not set straight, it is slightly down on the left and up on the right, ie straight lines are sloping down to the left. It is a pannosonic 26" l.c.d. vierra. Is it a simple...
I cannot remember exactly but it is a menu adjustable adjustment that you can do quite easily. Your instruction book will show you how to do it. On tube type TV's the adjustment was needed to combat the magnetic field of the Earth though why it is on an LCD, I don't know.
Hope that helps.
Nov 19, 2010 | Televison & Video
I need the instructions to program the EJ 5000C
EJ500 is battery operated timer.
Battery is located in pull-out tray behind flip-down door.
If display does not show, battery is dead, or timer has quit working.
Instruction manual:
http://waterheatertimer.org/Intermatic-ej500c-manual.pdf
Nov 18, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Freezer door has a gap in the middle. Seal doesn't
Put a long straight edge on the door to verify a warp. A 4 foot level is good for this test.
If the door is in fact warped. You should pull back on the seal,loosen the screws behind the seal holding the door liner in place,adjust the door to the straight edge and re-tighten the screws.
If the straight edge does not show a warped door,take a hair dryer and heat the seal where it is off the frame. Do this with the door closed and you will see the seal relax and touch the frame. Let it cool in this position before opening the door again.
If neither of these is the cause,loosen the door hinge and re-adjust the door position,then re-tighten the hinge screws.
Feb 13, 2010 | Frigidaire 19.53 cu. ft. Commercial...
Baumatic bd1631. where is the door tension adjuster please? manual shows picture but still cant figure out where it is.
On the top front edge there is a white seal, lift it slightly and it reveals the head of a bolt on each side. You need an alan key to adjust it but I am having trouble getting it right. Let me know if you succeed.
Oct 19, 2009 | Dishwashers
My convergence is fine but after professional replacement of the board there is a slight bowing and slanting of in-screen borders and some channels have a little distortion at the top of the screen. The...
First: If the convergence board was replaced--the set may need a total adjustment---this is why most good techs replace the convergence chips and any bad parts instead--also costs less----Second: to enter the service mode (it is done with the set already turned on) should be Mute, 182 or Mute 183---if you get the convergence mode--7,8, 9 will select red, green, blue, 5 will stop the cursor from blinking and allow adjustment---with the cursor blinking 2,8, 4, 6 will allow you to navigate---depending on the remote used--the P mode button will take you across the screen in a series of steps--the remote I use for this has a button on it marked data save--this saves the adjustments. Your remote may have it or a different button for this.
Understand---if you get into the convergence mode---Green determines if the geometry of the picture is straight---red and blue are adjusted to it---to align the green you need to call the convergence mode up and then cover the lens for the red and blue---leaves you with a green grid---then you need to select green and wherever the grid is not straight adjust it--once you get it straight you need to uncover the red and adjust it to the green, and then the blue to the green---green alignment determines if the picture is straight---It sounds like this guy did not try to get the green straight and just adjusted the red and blue to whatever the green was.
My point here is if you paid money for this repair--either he aligns it straight or you should get your money back----GREEN never needs to be adjusted unless the dcu(digital convergence unit that stores the adjustments) has been replaced or the Convergence module has been replaced---I bet if the original convergence module was repaired(chips replaced etc) and installed you would not have this problem.
If the guy replaced the DCU then GREEN must be fully adjusted for a straight picture FIRST! then red and blue adjusted to it.
It is not easy or quick to Adjust the green--maybe he just wanted to get out the door?
I do this here for free so if this has helped you take a minute and give me a vote here.
If you have any questions or need help reply to this post here.
SD TECH
Sep 05, 2009 | Samsung PCL6215R 62" Rear Projection...
I have a Halina Digital Photo Frame DPF070B with no instructions. The screen will display only one picture, I have to manually advance to the next photo vs. a slide show functioning automatically. I made...
Go into the folder where the pictures on your memory stick are stored. There should be thumbnails of all of them and you can select anyone with the red border. Select anyone so it shows up in the picture frame. Now press Enter. Five buttons should show up. Press the middle one to start the slide show. Press Esc to stop the slide show. You can also access the tools settings from here to adjust the interval time. Hope this helps.
Aug 15, 2009 | Cameras
Sony Grand WEGA KDF-50WE655 50 in
If it is dark because of an adjustment the "picture" adjustment would make a difference.
The most likely cause of a dark picture on this type of set would be the lamp getting near the end of it's life. This set should use part number, A-1606-034-B and is something you can probably change yourself, check your owners manual, it shows how. Follow the instructions and remember to have the power chord unplugged while you are changing lamp and to put the lamp door back on the set before you connect the power chord again.
Mar 13, 2009 | Sony Grand WEGA KDF-50WE655 50" Rear...
Leveling refrigerator
you might lower the front ones to get it level thats the only sloution i can come up with
Aug 04, 2008 | Maytag MSD2656G Side by Side Refrigerator
Toshiba theaterview 50in rear projection tv
Look at it on the QVC channel where you have boxes with straight lines. If any of the 3 colors are bowed and 1 inch off, then it needs parts inside. If the colors are straight and only 1/4 inch off, you can adjust it. Using the remote, in the menus find convergence to adjust. Your user manual will explain it. At WWW.Toshiba.com you can download the manual if you do not have it.
Mar 24, 2008 | Toshiba 57H81 57" Rear Projection...
Adjusting date, time, anything...
timex.com should be able to send a PDF of your manuel
May 11, 2007 | Timex 5B841 Wristwatch
General Electric Cafe CSS25USWSS Side by Side Refrigerator Logo
156 people viewed this question
Top General Refrigerators Experts
John Tripp
John Tripp
Shehu Pro
Shehu Pro
Joseph Mueller
Joseph Mueller
Are you a General Refrigerator Expert? Answer questions, earn points and help others
