Question about Refrigerators
We recently bought an upright freezer. The inside temperature remains at zero, but the outside (the sides) get intermittantly hot and then cool down. Is this normal?
    President:
  • 1,796 Answers
Hi!!
That is completely normal. Read your owners manual for a more technical explanation of why it does it.
Good Day!! Don't forget to rate this post!!
Posted on Sep 11, 2010
Testimonial: "Quick and great response....will use website often."
  • 4,793 Answers
Although you dont say what make this is the majority nowadays use the metal casing as a heat exchanger.so yes this is normal.
My 82L Upright Freezer from The Good Guys - a GVA is very hot on the outside - almost too hot to touch. Is this normal?
yes
the freezer works by taking the heat from the inside and exchanging to a coil that is under the outside of the freezer
It will be quite hot until such time as the inside temperature is brought down to the setting
the thing with freezers is that on start up the food that you are putting in should be cold to start with and not hot ( if necessary , use a bag of ice as a helper ) Later on any hot food added will not affect the operation that much as it is be in small quantities
this would be explained in the user booklet that was inside the freezer
Jan 09, 2016 | Freezers
Bought an upright Frigidaire Freezer on Craigslist and the inside gets cold and works like a champ but the outside side panels get very hot- is this normal or is there a short?
If there is a short circuit, the circuit breaker protection in your house wiring would trip (Open the electrical circuit path).
It is normal for the condenser, which is on the outside of the appliance to be hot because it is transfering the heat from inside the freezer cabinet to the ambient air outside the cabinet. Make sure that you give the appliance enough space all around the hot condenser so that it can transfer its heat to the surrounding air efficiently.
P.S. Some freezer designs integrate the condenser coils into the metal cabinet, thus the hot side panels.
Aug 28, 2011 | Frigidaire 14 cu. ft. / 396 liter Upright...
My Kenmore 9 upright freezer feels warm on the outside, what could be the cause. I have defrosted and cleaned it already and seems to work fine. however i am concerned with the outside temperature. Please...
This is normal. The condenser coils on freezers are typically located in the walls.
The refrigerator in your kitchen has condenser coils that are hot either under the frig or on the back. Freezers do not need as much heat transfer on the coils with the air so they put them in the walls, it is called a warm wall condenser. It may even feel hot to the touch if you happen to feel it near the end of a cooling cycle. It will be the warmest close to the compressor and cool off at it makes it around the cabinet down to the other side.
Apr 25, 2010 | Kenmore Freezers
Walls of freezer are hot to touch
freezer is working overtime . these symptoms generally indicate excessive outside air coming into freezer. make sure doorgasket is completely sealed all the way around door.
Sep 08, 2009 | Frigidaire 14.1 cu. ft. Upright Freezer...
Does the light on the outside of freezer stay on . I bought a used freezer. It is a frigidaire commercial upright (frost free) Does the light on outside of freezer stay on all the time? I have no manual....
Normally there is a Green light showing that power is on
A Yellow one for fast freeze and a Red one for under temperature
The outer casing is well insulated from the inside otherwise the freezer motor would run none stop without cooling the contents so the temperature of the outside casing will reflect the room temperature not the intenal
Aug 21, 2009 | Frigidaire 20 cu. ft. / 566 liter Upright...
Does not hold temperature, warms up.
if you hauled on its side then it is very possible you have oil in evaporator. replace all sealed system parts. compressor, drier and evaporator.
Jun 21, 2009 | Roper Refrigerators
The sides of the freezer are really hot
Is it really becoming excessivly hot or is it that you just have not been aware before. Most freezers generate heat when they are cooling down (yeah ok, so that sounds crazy). It may just be the freezer working hard to lower the temperature to get back to normal operating temperature
Aug 29, 2008 | GE 13.7 cu. ft. General Electric Upright...
Running but does not get cold enough
feel the sides or the coils on back if it has any see if they are hot or cold
Feb 20, 2008 | Maytag 15 cu. ft. / 425 liter Upright...
Refrigerators Logo
70 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
