Question about Maytag MER5870 Electric Kitchen Range
Model 5770ACW 19401490Z. An hour into self cleaning I heard a beep and a F1 appeared on the screen. Can you tell me what happened and what I need to do to fix the problem. Thank you
  • 1,711 Answers
F1 touch pad / ERC test This simple test will help determine whether the ERC (Electronic Range Control or Clock) or the touch pad is defective when F1 error code is present.
Note: Some models incorporate the touch pad in to the ERC as a single assembly, in which case this test is not necessary. Simply replace the ERC (Clock).
Warning: If you feel in any way uncomfortable performing this test or making this repair, please contact a qualified appliance repair technician.
1. Disconnect power to the range (unplug the range power cord or turn the power off to the range at the circuit breaker). It is very important that the power to the range has been disconnected, so please double check before continuing.
2. Gain access inside the control panel.
3. Disconnect the touch pad (also called keypad or membrane switch) ribbon from the ERC.
4. Make sure there are no lose wires, or anything else that may cause a short when power is turned back on. Assemble the control panel back the way it was.
5. Turn the power back on.
6. Wait for at least one hour to see if the F1 code comes back (usually accompanied by a beeping sound).
7. If F1 comes back, replace the ERC. If it does not, replace the touch pad.
Posted on Oct 04, 2010
Stopped f1 flashing and beeping by adjusting the lock feature to 12 o clock not oven and self cleaning not working at all
You have disabled the oven feature if you did adjust the door lock assembly. Interesting that the F1 stopped. notsure why myself.\
Usually the F1 feature does not go away unless you replace the electronic/control board.
I wonder what would happen if you set the door lock assembly to where it was before?
Oct 25, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Tip
Please help. We are a cleaning crew that went to a client's home to do a reno...
If you are having oven problems with your GE XL44 oven then you need to do a bit of oven troubleshooting. The first part of that problem is to know what the oven fault codes are trying to tell you.
The codes F0, F1, and F7 could either be a problem with the control or the keypad.
-to see what the problem is cause by, push clear/off on the keypad. Then disconnect the ribbon connector from the control. Wait at least 35 seconds to see if the code comes back. If the code comes back then the control is the problem. If the code does not come back, then replace the key panel.
F2 – This means there has been a problem with the temperature of your oven. It could be a cooling fan or air flow problem. Also could be that the oven got too hot in either a baking mode or a cleaning mode.
-check to make sure the contactor contacts are not welded together. If this happens the oven will always be putting out heat, even if turn off. The thermal switch may also have burnt out. If this switch is open then the fan may be bad, causing the thermal switch to activate. The thermistor that senses oven temperature may also bed bad or have a poor connection somewhere.
F3 and F4 - These are oven temperature sensor codes.
- check the sensor by removing power to the range and then removing the sensor. Check that the sensor reads approximately 1100 Ohms at 72 degrees F. Then check the oven sensor lead to make sure that it is not shorted out. Then check the terminals to make sure that you are getting good contact. If everything checks out okay, then replace the control.
F5 – This is a relay safety circuit failure code
-check the lock circuit for problems. Then check the thermistor for high resistance. Press clear/off on the key pad and reprogram the control. If the code is still there then replace the control.
The F5 code can also result from a short loss of power. If you had a power flicker then reset the control.
FC – This shows a problem with the door lock circuit. Check all the wires and the switches. Check the operation of all the switches.
FD – This is a problem with the meat probe. Check the probe wiring and the receptacle where the probe plugs in at. Resistance on the probe should be 30 to 50K ohms at 72 degrees F.
FF – This is a problem with the door motor safety circuit. To fix this the control will need to be replaced.
http://www.fixya.com/support/r4388324-oven_fault_codes_ge_xl44_oven
http://www.fixya.com/support/r4391163-range_stove_oven_door_glass_replacement
http://www.fixya.com/support/r4404788-electric_oven_problem_oven_will_not_shut
http://www.fixya.com/support/r4319588-electric_oven_problems_not_use_in
http://www.fixya.com/support/r4154940-fault_codes_admiral_range_stove_oven
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
on Jul 01, 2010 | Ovens
Amana self cleaning oven Model ACS7270AS, Seril 10924419AT F1 And F5 code come on control panel and continuous beep. All burners and other oven controls seem to come on ok. How do we clear the beeping...
Both F1 and F5 are the code for a board failure; it would need to be replaced. What you could try is disconnect the oven for a few minutes and then turn the power back on. If that does not do the trick you would need a board
May 24, 2011 | Ovens
What does error code f1-4 mean?
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Dec 30, 2009 | Maytag Kitchen Ranges
Kenmore Oven going crazy
The bang may have been an element arcing over.  Turn off the power and remove the element.  If it shows any form of damage, replace it.  If you're not sure, use a continuity checker to check it.  If you have two elements...do this for both.  You will likely find the problem.
Nov 13, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error
I have had the same problem and the machine is 12 years old - serviceman who came told me the console can be replaced for $400 - I am opting to purchase a new oven
Nov 13, 2008 | Maytag Ovens
Maytag Model # MES5770AAB F1 error
Hi was using the oven and as soon as it reached the tempurture i set it to the F1 went on and beeped. I hit cancel and resumed it to see if it would finish cooking and it did. I just dont know what f1-1 means and its almost Thanksgiving. Has anyone found out what F1-1 means??
Setauket mom
Jul 28, 2008 | Maytag MER5770 Electric Kitchen Range
Maytag gemini f1-9 error
plug it back in and press the cancel button
Mar 31, 2008 | Maytag MER6772 Gemini Electric Kitchen...
Oven beeping f1 and f3
Im having the same problem I have model arg71000 serial 9809185133 Hook me up with the solution please
Dec 22, 2007 | Kitchen Ranges
Maytag MER5870 Electric Kitchen Range Logo
145 people viewed this question
Top Maytag Kitchen Ranges Experts
vince
gbob59
Are you a Maytag Kitchen Range Expert? Answer questions, earn points and help others
