Question about Sony KP-53HS30 53" Rear Projection HDTV-Ready Television
Does it make any diiference if I use STK392-570 ICs on my Sony TV that uses STK392-560 ICs?
  • Sony Master
  • 11,800 Answers
No difference whatsoever - the 570 has a smaller polarisation current requirement, fully assured by the rest of the components.
Posted on Sep 11, 2010
I have a sony widescreen projection tv model KP51WS510. the picture has shadows and shows double.
Thats caused by failed convergence ICs your model uses the STK392-560 ICs you will also need several 3.5 amp pico fuses and a couple of 5 amp pico fuses to do the repair. The Sony Type 1 convergence repair kit is the correct kit for your model. It contains the parts and the CD with repair instructions. The kits available from www.tvrepairworld.com
Aug 09, 2011 | Sony KP-51WS510 51" Rear Projection...
I have a sony projection tv. Colors/piture not right
Replace convergence ICs and a 5 amp pico fuse on power supply. ICs are part number STK392-560.
Just be sure to use thermal paste on the ICs or they will self destruct in a short amount of time.
Jul 06, 2010 | Sony KP-57WS500 57" Rear Projection...
Sony kp 46wt500 has 3d screen what might the problem be?
If convergence out ICs got defective then TV shows that kind of picture.
Replace IC8001 and IC8002 on D Board, both big black ICs are mounted on aluminum heat sink and number STK392-560 would be written on it.
Required ICs are available in Part Store, click that link to see an image of IC and price info.
If you are not comfortable with soldering parts in circuit board, call local tv tech to replace it.
Thanks.
Nov 13, 2009 | Sony KP-46WT500 46" Rear Projection...
My sony projection tv has bouble image. can i
Well repair of TV depends on your own skills and if you have any experience of electronics stuff repair then it would not be difficult. This kind of repair requires good parts soldering in PCB expertise.
Your Sony KP-51HW40 seems have problem with convergence out ICs (two ICs) that would be replaced. Both ICs STK392-560 are located on D Board and available in Part Store.
Thanks.
Aug 21, 2009 | Sony Televison & Video
I have problems with my convergence, the picture shows on a oval shape. Its a Sony KP-53HS30
You need to replace two convergence out ICs STK392-560 in D board of TV.
Above said ICs are available in Parts Store.
Apr 21, 2009 | Sony KP-53HS30 53" Rear Projection...
Red and green shadow lines
This 3-D problem is because to failure of convergence out ICs failure in TV and convergence ICs will be replaced.
If TV is Sony KP-51WS500 then check D board for STK392-560 and replace 02 ICs.
Required parts are available in Part Store.
Mar 13, 2009 | Sony KP-51WS500 51" Rear Projection...
I have a 53 in. sony projection tv,. bowed picture tubes?!?
Replace Both STK convergence ICs will have part number on them STK392-560 use same part number on your STKs. Also around ICs ck pico fuses 5/6amps they are green or yellow.
Jan 07, 2009 | RCA P56930BL 56" Rear Projection...
Sony KP-51HW40 T.V. it turns on for about 30 sec. then just shuts off all the lamps turn on and you here it click on then all of a sudden it just shuts off any help?
Replace Both of your STKs convergence ICs they are big black ics they will have STK numbers on them STK392-560 ect. Parts you can order on line www.electronix.com or call 1-800-223-3205 you also need silicon heat sink white compound to put on back of new ICs. Use same # on stks but if they are 110s use 180s if 020s use040s.
Dec 26, 2008 | Sony KP-51HW40 51" Rear Projection...
How to change convergence ICs in Sony KP-57WS510 TV?
Replace Both STKs convergence ICs big black ics with number on them STK392-560.Parts 1-800-223-3205
Dec 20, 2008 | Sony KP-51WS510 51" Rear Projection...
Sony KP-46WT500
you need to replace both convergence Ics number STK392-560 its a fairly easy repair that requires basic soldering skills. you can get replacement Ics with free instalation instructions with pictures at the following link,
http://servicemanuals.vstore.ca/
May 25, 2008 | Sony KP-46WT500 46" Rear Projection...
Sony KP-53HS30 53" Rear Projection HDTV-Ready Television Logo
368 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
