Question about Garden
Do not hive and need to know how to put new blades in. thank you ray
  • 5,603 Answers
Almost all chain saw blade replacement is the same.
You remove the cover over the driving sprocket area.
You loosen two clamping bar nuts.
You loosen a small screw that helps tension the chain... this is usually parallel and close to the bar on the engine side of the bar.
You remove the old chain noting the direction of the teeth.
You put new chain on the same direction.
You partially tighten the bar nuts so they will allow bar to slide a bit.
You then tighten the tensioning screw until you can lift the chain halfway up the bar, away from the bar and have the guide that runs in the bar JUST come out of the bar at that point.
Fully tighten the bar nuts.
Replace the cover plate.
Put a little bar oil along the chain. Done!
Posted on Sep 11, 2010
Ihave a craftsman ridding mower model #917.289900 new belt for the deck new blads it still leaves miss cut in the middle anybody know why?
usually if its missing cut it's not rotating fast enough, or the other thing it can be the blades have not been sharpened. some companies that make blades don't sharpen them so they can be handled, it will have a leading edge and you need a sharpening stone to put a cutting edge on the blade. and the blade has to be put in the right way round. flate top cutting edge bottom.
Jun 14, 2017 | Craftsman Garden
What is the correct way to Install New Blades on John Deere G100 with 54"cutting deck
Do Ray:
I pull my machine up so the front tires are on a ramp. make sure the key is out of the ignition. Raise the deck to its top position (every little bit of room to work helps!) I think that the spindle nuts are 1 inch. lodge a two-by-four piece of wood between the tip of the blade that you are removing and the blade deck and remove the nut at the bottom of the blade (make sure you are turning your wrench in the correct direction!) It will take a two-grunt pull to loosen the nut. The blade should fall off when the nut is loosened. Make sure to not put the new blade on upside down! (Use the other two blades for reference). Repeat for the other two blades. Make sure that the blade retention nuts are Very Tight.
Jun 15, 2015 | John Deere Garden
Binatone b430 gives message "recover
I have the same problem.
My Binatone B430 shows LOGO screen or 10-15seconds and
then it gives blue screen saying "RECOVER THE HIVE PARTITION..."
I don't know what to do, any ideas guys?
Aug 18, 2011 | GPS
How do i change blade
Under the mower,the blade is held by a single nut.Unplug the spark plug.Lift the mower.You will need to hold the blade.I use a large screw driver to keep the blade from turning as you remove the nut.Do NOT but a blade before you get the old one off.Some blades use a star shaped hole others use a round one.You need to know which you need,as one will not fit on the other.Once the nut is off the blade will come off too.Then just put the new blade on and the nut.
Jun 29, 2011 | Garden
Trouble with blade. I must be missing something (a part) when I put on a new blade it pulls left it as if it were wobbling. I have no manuel to go by so I need advise on how to change the blade. Thank you
first unplug the tool and remove the hex bolt. you will find an outer flange and then the blade, under the blade is usually an inner flange which I think you might be missing. What is the brand and model number and I will try and find a manual for you. Let me know, but I would not try using the saw until you find out what is missing.
Apr 21, 2011 | Saws
Dell Studio Laptop- Cannot Log On Message- User Profile Service Failed Log on User Profile cannot be loaded
I had one case like this before where there was another user on the machine who loaded the user profile hive in the registry and then forgot to unload it. Therefore when the user tried to log in, it gave them the message just like yours because it's "in use" by the registry. If there is another user on your machine, please ensure that this person unloaded the hive in the registry. And then try logging in again. Please let me know if the problem persists. If my suggestion works, please do rate me. Thanks.
Feb 04, 2010 | Dell Studio 15 Laptop
C0000218 Registry file failure. Registry cannot
The hive file is the problem, it is low on honey. Put it back to where the bees can produce enough honey for your PC to recognize it. Compaq's are notorious for their love of honey, that is why it is showing it is missing. DO NOT simply put honey on a CD and insert. Will not work.
Feb 01, 2010 | Compaq Presario 5000 PC Desktop
T40 memory upgrade
One of your memory slots may have gone bad. Try putting one memory card in one slot thaen the other. Let us know.
Sep 25, 2008 | IBM ThinkPad T40 2373 Notebook
New Drive Missing Hive
put the dvd writer in slave position with the help of jumper near the data cable insertion,
May 15, 2008 | Computers & Internet
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
