Question about Fisher and Paykel DEGX1 Electric Dryer
I have a Fisher and Paykel dryer Model DEGX2 that is making a loud squeel when it is running. I want to take it apart so that I can lubricate it, but I do not know how to take the "shell" off. Can you tell me how to do that?
  • 552 Answers
Click on the link below to watch a video that explains how to take a Fisher Paykel dryer apart.
http://www.youtube.com/watch?v=g0Yf2tRE_dA
Posted on Mar 06, 2011
    Problem Solver:
  • 14 Answers
Sounds Like you need a drum barring As for taking it apart I am sending you a link to the parts manual It has a exploded view
http://fisherpaykelparts.net/partmanuals/degx2us.pdf
Posted on Sep 11, 2010
What could make a noise when drum tumbles on Fisher Paykel top loading dryer, Model DEGX2?
GOD IS GOOD !!!!
DRYER MAKES NOISES.
A loose or worn BELT can make funny noises
Or the idler pulley that puts tension on the dryer drum drive belt could be worn out. If the pulley is bad we recommend also replacing the belt.
The glides on drum worn and making metal to metal contact.
The drum slides or glides support the front of the drum. As the drum rotates over the years, the glides wear out and then the dryer makes noise. Replace all of the glides as a set if they are worn out.
CHECK FOR LOOSE BELLOES inside the drum
Sometimes an item can get stuck inbetween the drum and the housing and scrape and grind making funny noises, things like coins, bra wire, nails, hair pins, etc sometimes u can just remove the cabinet and observe by turning the drum by hand or looking for scratch or scrape marks on housing.
The blower:
Clumps of lint, socks, and other small articles of clothing can get past the lint filter and into the blower wheel. If the dryer makes noise, and the noise seems to be at a very fast pace, there might be something caught in the blower wheel. In addition, the blower wheel sleeve might be worn out, allowing the blower wheel to wobble on the motor shaft. If this happens, replace the blower wheel.
The bearings:
The drum bearing supports the rear of the dryer drum. If the dryer makes noise this bearing might be worn out. Replace the bearing if it is worn out. Do not lubricate the bearing, the lubrication will attract lint and dirt and accelerate the wearing process.
The bearings TEST by moving drum by hand u may be able to feel loose or rough movement. And listen to sounds when turning it.
The drum rollers or castors:
It is very common for dryer drum rollers to wear out. If the dryer makes noise, particularly a loud rumbling noise, one or more of the rollers may be worn out. After removing the drum from the dryer, inspect the rollers.
Check for cracks, dryness, or damage and not engaging drum properly. Sometimes u can use high density LITHIUM BASE gear grease to re oil/grease them.
Sep 30, 2014 | Fisher and Paykel DEGX2 Dryer
Service Manual for DEGX2
Get the model # and go to Fisher Paykel website for info or to order the service model. Also you can enter your model and it will show you a breakdown on parts.
Mar 17, 2013 | Fisher and Paykel DEGX2 Dryer
My Fisher and Paykel Model Degx2 The drum is stick it will not open. Can someone help me please
see this and fix it. God bless you
If your electric dryers control is locked try the following. First make sure there is not a seperate control lock button if there is press one time to unlock. Next locate the end of cycle button and press and hold for 3 seconds. If this does not clear it press and hold for 15 seconds. Still not cleared shut off breaker for 5 minutes if this does not correct the problem replace the main control.
Sep 28, 2012 | Fisher and Paykel DEGX2 Dryer
My Fisher Paykel is making a high pitched whine. Similar to some one running the finger around a wine glass.
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Sep 07, 2011 | Fisher and Paykel DEGX2 Dryer
FPaykel Dryer model # DE05US2 is making a screeching LOUD sound ... still turns and dries just VERY VERY LOUD and high pitched squeeling
It could be bearing or guides in the drum.Go to http://fisherpaykelparts.net/techhelp/fisher-paykel-top-load-dryers-us-models/ This forum will work you through your problem
Sep 27, 2010 | Fisher and Paykel DEGX1 Electric Dryer
Fisher & Paykel DEGX2 Dryer. Need heating element changed?
I had the same problem. Everyone continued to tell me that I needed a new heating element, clean lint trap, etc. However, I took the front off of the dryer and located the heating element. On the front of the heating element, in between two wires, there is a red button. Push the button and you might hear a click that sounds similar to a circuit breaker. It is a reset button for the heating element. Try that and it might help.
Jul 08, 2009 | Fisher and Paykel DEGX2 Dryer
Fisher and Paykel DEGX1 Electric Dryer Logo
236 people viewed this question
Top Fisher and Paykel Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Craig Butler
Craig Butler
Are you a Fisher and Paykel Dryer Expert? Answer questions, earn points and help others
