Question about Kitchen Ranges
When starting washer it automatically starts washing cycle and never fills as if it senses that the machine has already filled.
  • Kitchen Ranges Master
  • 1,711 Answers
The water level is control from a pressure sensor located internaly on the of the washer and is connected to the drum cy a water plastic hose.
As the water levlel enter in the drum and start rising the same hapen also to hose. By rising in the hose is plessing up the air that was trap in it and as it resiing the pressure rising too. That is how the water level pressure sensor works.
So the posible problems are:
1.The water hose is goccled by something so the pressure sensor switch is stay on always. So you need to clean the hose entry, first you can try to make a wash by adding manual water and select a program at the very hot so by this their is very good chance that the dirt will be desolved and the hose will be open again.
2. If the baove does not work the you need to open the top of the washer and by finding the other hose end secured on pressure swuich remove it and blow air in it so it will be open.
3. If do this and sill have the problem the check the pressure switch which probably is stcuck on and need to be replaced.
Posted on Sep 11, 2010
  • espressonist
    espressonist Sep 11, 2010
    The water level is control from a pressure sensor located internally on the of the washer and is connected to the drum cy a water plastic hose.
    As the water level enter in the drum and start rising the same happen also to hose. By rising in the hose is pressing up the air that was trap in it and as it raising the pressure rising too. That is how the water level pressure sensor works.
    So the possible problems are:
    1.The water hose is cockled by something so the pressure sensor switch is stay on always. So you need to clean the hose entry, first you can try to make a wash by adding manual water and select a program at the very hot so by this there is very good chance that the dirt will be dissolved and the hose will be open again.
    2. If the above does not work then you need to open the top of the washer and by finding the other hose end secured on pressure switch remove it and blow air in it so it will be open.
    3. If do this and sill have the problem the check the pressure switch which probably is stuck on and need to be replaced
My washing machine fills up with water but does not continue the wash cycle. Sometimes when you slam the lid the washer will continue the wash cycle to the end. Other times the washer stays filled up...
Sounds like the lid safety switch is either out of adjustment, or needs replacement.
Most washers will fill with the lid open, but no continue a cycle where the drum or agitator spin, unless it senses the lid is closed.
Oct 01, 2013 | Whirlpool Washing Machines
Tip
SMELLY FRONT LOAD WASHER
MAKE SURE YOUR WATER IS HOT WHEN STARTING THE FILL CYCLE YOU MAY HAVE TO FILL IT UP ONCE THEN DRAIN IT THEN FILL IT UP AGAIN TO MAKE SURE ITS HOT THEN ADD 1 CUP OF AUTOMATIC DISHWASHER SOAP AND RUN AN EMPTY CYCLE. THIS WILL REMOVE ALL ENZIMES AND SMELLS FROM WASHER
on Jan 12, 2010 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
Whirlpool wtw57esvw washer won't fill
I had the same problem, started filling right away, also when the wash cycle is done, the clothes are wet, it starts to fill again after spin cycle. I intended to buy a load sensing switch the next day, but it was $76 dollars. i removed the switch, gentley pryed it apart, there was 2 small thin brass/copper contact tabs, I bent them slightly to make better contact. I put the switch back together and reinstalled it, put the machine back together, and it has been 3 months with no problems.
Mar 05, 2012 | Washing Machines
Whirlpool washer WTW57ESVW0 won't fill with water. I bought this machine two months ago was working fine and then just stopped filling water. Spin cycle and drain cycle work but it won't start fill...
Solution for WTW57ESVW0 Whirlpool Washer that won't fill or agitate, but will spin and drain water.
Replacing the Auto Load Sensing Switch (W10177795 - Illus. No. 12 on Control and Rear Panel Parts) fixed the problem.
In addition, a defective switch can also cause the machine to start agitating while it is filling.
It is relatively easy to replace and there are online videos that can help with the replacement.
Oct 27, 2010 | Washing Machines
No water no Spin
Check your 2 in 3 out water valve part# WH13X10029, this responsible for filling of water. By the way wash cycle will not run, until washer sense enough water.
Jul 27, 2010 | General Electric WBVH5200J Front Load...
Washer powers down during wash cycles
It is most likely a very slow fill problem ,either the cold or hot water supply is restricted and the machine cannot sense the right water temp. and will shut down .
Machine cannot wash properly with a small amount of water.
Ckeck ,the screens in the water valve or at the hoses at the top where the faucets are ,clean them or replace them but never leave them out .
Dec 17, 2008 | Maytag Neptune MLE2000A Front Load Stacked...
Does complete cycle
When would the washer stop?
Is there water in the washer when it stops?
Feb 26, 2008 | Maytag Atlantis MAV6000 Top Load Washer
Washer is filling and filling and filling...
CHECK YOU WATER LEVEL SWITCH IT SOUNDS LIKE IT IS STUCK ON THE FILL CYCLE
Jan 02, 2008 | Kenmore 24032\24036 Top Load Washer
Washing machine does not stop filling
Does the machine start working normally after turning the wash cycle manually ?
Feb 15, 2007 | Roper RAS8445KQ Top Load Washer
Kitchen Ranges Logo
37 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
