Question about Toro Lawn Mower With Toro Power Tools
Have a toro LX425 steering problem. Pinion and gear not connecting. I can't find the correct part to fix it in the parts manual. Please help
  • 2 more comments
  • Lovelll3 Sep 11, 2010
    First, thank you so much for helping me! I have been frustrated and my lawn is growing. I have checked the small gear attached to the end of the shaft, and the gear directly connected to the front wheels. They are both fine. The problem is they don't connect as there is now too much play in the shaft. I am not sure how that happened. In the online manual it shows a flange part that I didn't have on mine. I ordered it, but I don't see where that would even help.
    Thanks!
    You spoke of a bushing. I don't see that in the exploded parts view?
    Pinion gear is turning fine
  • Lovelll3 Sep 12, 2010
    Hi. The pinion gear and the gear attached to the end of the shaft are both fine...they just don't touch due to too much play in the shaft. It almost appears as if something, all of a sudden, is missing. The shaft slips through two different holes, Both holes are wider than the shaft, allowing for much play. You spoke of a "bushing" yet I can't see a bushing on the manual. thanks for helping!
  • 10,515 Answers
Does the sector gear turn when you turn the wheel?
Does the steering shaft fit tight in the bushing and does the bushing fit tight in the housing?
The middle of the pinion should be in line with the sector gear. Is this how it is? Did you have the the steering wheel off and check the splines in the wheel? Is the pinion gear turning?
Let me know,so that we could proceed further.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • srcme2001
    srcme2001 Mar 14, 2012
    I just had this prob on my Toro LX425. From the bottom up.
    Take off the nut holding the small gear of the steering,at the base of the steering column. The gear will silde off easily, by hand in most cases. Then lift UP about three inches the whole steering coloumb. if you look from the bottom up, and push tr==hruogh it with your finger, you will notice a small 5/8 nut, which holds the steering in place just above the small gear. You cant see it but it is just on the other side of the metal that the steering coloumb passes through on the bottom. Push it up and take it out. You may need a hanger hook wire to get to it to pull it out . Very simple. Then you will see how worn it is. That is all you need and it cost three dollars at your nearest TORO parts dealer. Drop it back in and your set to go. The six side 5/8 is just there to hold it in place. It is not a nut that has to be taken off, just a bushing with a 5/8 six sides that falls into place to hold the steering coloumb.
    Hope your good with tools. All you need is a socket n ratchet wrench to remove the gear. When the bushing is repaired the stee will tighten up like a brand new machine. And you will use it again all happy.
    Now this machine is probly being used for commercial use right? It is not made for that but if you do the belt rollers and bushing will prob last about 3 or four years.
    The nesxt thing you'll be replacing most likely is the belt pulleys. and most likely one at a time. If you have the money it is a good investmernt in time to just get all four and replace them so you wont be stuck on a job in the middle with a failed lawn mower.
    Good luck, srcme2001@yahoo.com, just another guy with a LX425
  • Lorie Engberg Sep 09, 2013
    I have this issue as well, brought the tractor to a neighbour who mentioned maybe a bushing - I sure hope so - waiting to hear from him. This would be a cheap fix and I would be grateful if it was!!
My van is having a hard time turning, would this be the power steering pump going out and if so how can I fix my 1998 Mercury villager
It could be or the steering rack . The power steering system uses a CII type power steering pump (3A674) and a power rack and pinion steering gear.
If you never replaced either of these parts before suggest you take to a ASE certified repair shop .
Pump Flow and Pressure Tests Before performing pump flow and pressure test, complete the following checks for conditions which could cause loss of power assist. Take corrective action if necessary.
  1. Check power steering oil reservoir (3A697) for proper fluid level.
  1. Check tires for correct air pressure.
  1. Check drive belt (8620) for proper tension.
  1. Check power steering pump (3A674) for correct model and vehicle application.
  1. Check for correct size power steering pump pulleys (3A733) on power steering pump and engine.
  1. Check entire system for damage. Replace parts, if necessary.
If the above items are correct, or have been corrected, and the loss of assist still exists, test power steering pump flow and pressure to determine whether the trouble is in the power steering pump , power rack and pinion steering gear or hoses.
Oct 20, 2015 | Mercury Cars & Trucks
Steering on my Toro lx420 is loose. It takes numerous turns of the wheel to engage gear. I just replaced the gear and pinion but there is still alot of play between the pinion and gear.
Steering shaft has oil-lite bushing that wears = replace bushing. FWI, you posted in the wrong section--this is for cars and trucks.
Jul 23, 2015 | Cars & Trucks
How do i replace a drive belt for the toro lx425 lawn tractor?
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual......
Oct 10, 2010 | Toro Garden
Lx425 has grinding noise but won
replace the starter gear. the starter is probably fine and alot cheaper if you just relplace the gears.
Jul 14, 2010 | Toro Garden
My steering on my lawn tractor is not working, i currently have to push down on my steering to help it turn. what is happening and how do i fix it?
There is a brass or bronze pinion gear at the bottom end of the steering wheel rod, take it off and turn it around (upside down) to make the unworn parts of the pinion engage the rooster gear or replace both of the gears for tight steering again.
Jun 03, 2010 | Craftsman 20 Hp 42" Deck Lawn Tractor
Toro model 20017 PP drive problem
I went to www.toropartstore.com. I put in your model number and found they had 6 different models depending on the serial number. I went to buy OEM parts and went thru the menus to bring up your transmission #106-3956. Try this site.
HTH
Good Day.
Oct 28, 2009 | Toro Lawn Mower With Toro Power Tools
How do I get instructions on replacing both upper and lower drive belts on a LX425 Toro Lawn Tractor?
You can go to Toro.com and look at the lower left side for "Homeowner" or "commercial" parts. If you enter your model number you can get an owners manual online. I tried your LX425, but didn't come up. Maybe a different number?
Oct 25, 2009 | Garden
Toro 22in Lawn mower. Loud gear noise when try to engage drive.
Problem is in the rear pinion gears on rear axle and the design of the axle itself. I have a 2005 model 20041 had the same problem. I found a Toro dealer that had the fix.The problem is creadted by the fact that there is too much "play" in the rear axle. You have to limit that play by installing shims, or washers First, but the 2 new rear pinion gears for the rear axle. While you're at it, you may as well buy 2 new rear wheels because the "grinding" has worn the sprockets on the reas r wheels.Next, get 2 "fender washers", 1/2" ID and about 1" OD. I found it easier to turn the mower over and set it on saw horses to work on it.( drain the gas and oil first). Remove both rear wheels, pinion gears and all the washers etc. (caution - keep all parts from one side together - do not pile all parts together - keep them seperated by wheel - the reason is I believe there is one more washer/shim on the right side than on the left). Now to put everything back together, find a spot on the axle where the washer will fit in between the standard stuff.Install new pinion gears and replace the rest of the washers/shims just as they came off. INstall new wheels and you'll be good as new!
Jul 07, 2009 | Toro Lawn Mower With Toro Power Tools
I have a 20073A self propelled lawn mower that makes a grinding sound when I start out mowing or turn the mower around. I replaced the metal gears twice and that quiets it for awhile, but then the noise...
Assuming the pinion gears and wheel gears match, (sometimes dealers make mistakes too.) Check the bearings behind the wheel adjusters and the retainer-bushing Hoc. If they are in good shape lubricate the pinion gears and wheel gears w/ hi temp lithium grease.
Apr 09, 2009 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Mower With Toro Power Tools Logo
1,504 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
