Question about Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351
I have a Kenmore commercial freezer - I can't find the cubic size, but it is huge! The alarm went off, we pushed the reset button, but it won't go back to the correct temperature (10 degrees). It will go to 21 degrees, but flashes a "6".
  • 909 Answers
In short you possibly have a gas blockage or a leak in the system and need a Tech. with gauges and testing equiptment to confirm.
Posted on Sep 24, 2013
  • 161 Answers
SOURCE: Old Kenmore Freezer
It is uaually coded into the model #. Usually in the middle. I can usually eyeball them. another solution is measure the outside dimensions of a refrigerator or freezer you know the size of then compare them. This will give you a rough estimate.
Posted on Jun 30, 2008
SOURCE: flashing power light on Kenmore upright freezer
If the yellow light is flashing it may mean that the 9 volt battery is dead.
On my Kenmore there's a small battery compartment on the bottom right of the unit - under the door.
Posted on Aug 20, 2008
SOURCE: Kenmore commercial standup freezer alarm
Sounds like the temp sensor is bad or intermittant. Check the connections to the display to see if they are loose. If not, the sensor might be bad, causing it to read the wrong temp. The fact that it is jumping around like that points to this kind of problem.
Posted on Feb 11, 2009
  • 103 Answers
SOURCE: Freezer alarm stuck on - can't reset
Hi: Does the freezer have a battery backup for the electronics? A 9v. battery in the grill down below. You won't have to remove the grill but pull a small rectangular panel to expose the battery. High end Kenmore freezers have a battery to back up the alarm. The six you see is actually supposed to be a "b" for battery most likely. L.E.D.'s are tough to tell the difference. Buy an new battery and all will be well. I hope this helps, Jeff
Posted on Jun 12, 2009
devdeep545
  • 137 Answers
SOURCE: Freezer Alarm keeps going off...
I think your freezer's coils have been damaged. Consult a enjinner.
Posted on Aug 10, 2009
Wherehis alarm reset button?
KM says this is an ice maker. Reset button is on the control board. Board is in compartment on the right side where the power switch is located. Remove 2 screws and remove cover by sliding forward. Watch for wires, do this carefully. On the board, up at the top, is a small, white button. With power on, push the button.
Jun 12, 2014 | Hoshizaki Commercial Freezer KM-500MAH
Where is the alarm reset button for KM501 MWH
Look for a small button on the control board. just press it to reset.
Sep 06, 2013 | Hoshizaki Freezer Commercial Ice Machines...
Kenmore freezer buzzer
I would need to model number to check if you have a on/off for you over temp alarm. That "Buzzer" is a over temp alarm. If you fridge uses a 9volt battery then you might need to replace the battery. Please post your model number.
Mar 13, 2013 | Kenmore Freezers
Kenmore elite upright freezer service manual mod# 253.28093800
There is a lock on the display. Try pressing standby button for 10 secs
Apr 14, 2012 | Kenmore Freezers
Can you tell me how large (in cubic feet) this freezer is?
Is this a trick question? It is 20.3 cubic feet according to your question. This may be the capacity or the size of gross measurement ... you have not indicated.
Please ask the actual question you want to know ...
Thank you
Mar 22, 2011 | Kenmore Freezer 20.3 cu. ft. Frost Free...
KM-500-MAE Hoshizaki Problem huge cubes, alarm code three beeps
Might need to clean float switch, or water inlet valve bypassing water. Deep clean Hoshizaki.
Sep 30, 2010 | Hoshizaki Commercial Freezer KM-500MAH
ALARM WENT OFF ON OUR KENMORE UPRIGHT FREEZER. HOW DO WE GET IT RESET. WE HAVE PUSHED THE BUTTONS BUT RED LIGHT IS STILL ON AND FREEZER NOT RUNNING. THE PROBLEM STARTED BECAUSE WE DID NOT GET THE DOOR SHUT...
The light and alarm will remain active until the temp in the freezer is "normal" or satisfied. You should be able to push & hold the button (if electronic) until it stops. If it is a manual switch, they are usually located at the bottom of the cabinet below the door.(some are located inside the unit on the wall as well) It may be a "rocker" switch or part of the actual indicator light. Good luck
Sep 26, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Oct 09, 2008 | Freezers
Old Kenmore Freezer
Jun 25, 2008 | Freezers
Kenmore 22.7 cu. ft. / 643 liter Chest Freezer 13351 Logo
131 people viewed this question
Top Kenmore Freezers Experts
AJMAL KHAN
christian nielsen
Dan Webster
Dan Webster
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
