Question about GE 30" Self-Cleaning Freestanding Electric Range - White-on-White
I have a Self-Cleaning Oven from GE. Model # JBP24D0M1WW. The clock dropped a digit while I was using the burner and then the whole oven & display stopped working. When you turn the burner on, 24 shows in the display but the burners or oven will not heat up. The oven light works. Any suggestions? Thanks
  • 18 Answers
SOURCE: GE Spectra Oven not working
its sounds like your board is shot. replace board
Posted on Feb 04, 2007
Krazytech
  • 725 Answers
SOURCE: repair GE electric range
Door motor safety circuit you may have a faulty Electronic Range Control (ERC).. let us know what you find out.. krazytech
Posted on Sep 08, 2007
SOURCE: Estate Range #TE5400PXHQ0
MY SELFCLEANING WHIRLPOOL OVEN CLEANED ABOUT 30 MINUTES AND THEN STOPPED AND WENT INTO E2 AND F1. THE DOOR IS LOCKED AND WON'T OPEN. WE HAVE TRIED EVERY THING THE BOOK SAID AND NOTHING HELPS. DO YOU HAVE AN ANSWER?
Posted on Dec 20, 2007
SOURCE: I have lost my manual to my GE Profile Gas Range, self cleaning, convection and conventional oven
what does f2 mean when I am self cleaning my ge profile oven.
Posted on Dec 29, 2008
  • 15 Answers
SOURCE: clock and light in oven work but stove and burners will not
Sounds like the wires connecting your control panel to the individual heating elements have either shorted out or been disconnected. Try taking off the control panel board and testing the connections (the four on the sides of the circuit board in the middle, and the two five pin and one three pin connector on the mainboard). If they are good, then your problem lies in the control board itself and will require a replacement from Whirlpool. Depending on if you have the touch sensor board or a push switch, it can run upwards of a few hundred bucks.
Posted on May 26, 2009
Fridgeaire 316246639 model popped oven does not work. Time clock does not work, burners work.
Hello mrstrini2 - Do you have an electric or gas range? Most fault codes consist of both letters and numbers. Could you provide me the code to better address the issue at hand?
Jan 20, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
Self cleaning knob removal GE WB2X2030
There is a retaining clip that needs to come off.
Nov 27, 2012 | GE JKP27 Electric Double Oven
OUR HOME WE BOUGHT CAME WITH A RANGE, BUT NO MANUAL, WHERE CAN I GET A COPY OF THE MANUAL FOR THIS RANGE?
You will need to find the model number to get a manual. http://www.geappliances.com/service_and_support/literature/ provides a search box for looking up the manuals. For GE ranges, the model number could be in several places: on the frame behind the warming or storage drawer or kickplate, on the left leg behind the warming or storage drawer or kickplate, on the frame of the oven behind the door, under the left front surface burner, or under the lift-up cook-top at the center or on the right hand side.
If you clean the oven with non-abrasive products and avoid the spray on oven cleaners, you are unlikely to damage the surfaces/range even without the manual for your range. (Use glass cleaners for glass cook-top.) Warm water mixed with a mild detergent is useful for most spills. Avoid cleaning the seal around the oven door; damaging the seal may cause major problems.
I hope this helps.
Jan 27, 2012 | GE Kitchen Ranges
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    I have a GE XL44 gas range. My Broiler goes on then off, on then off what could it be?
    if this is a self cleaning model with the broiler at the top of the oven then i would guess that you may have an ignitor going out. is the bake working ok?
    if this is not a self cleaning model and the broiler pan is underneath the oven then it uses the same burner as the bake. if this is the case you should also be having trouble with the bake function.
    May 28, 2010 | GE Kitchen Ranges
    GE JKP15 does not self clean and minutes cant be set on clock
    Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
    Self Cleaning Oven Problem
    heatman101
    " Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
    Mar 30, 2010 | GE JKP15 Electric Single Oven
    Model FEFL78CBC frigidaire oven bottom (bake) burner won't work everything else works fine --even broiler element works fine. Just used self-cleaning cycle, which did work. Next morning oven won't heat ....
    We had the same thing happen and now they came and said it was the clock that needs to be replaced. They said that controls the oven. Even though clock is on and working the function for turning on the oven is not
    Nov 28, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
    I have an older GE self-cleaning oven. It has an
    Latch may have been damaged from heat of self clean. lift top where burners are, should see cover over latch assy(turn power off to unit) remove screws for cover and should be able to free latch.
    Jun 08, 2009 | GE 30" Self-Cleaning Freestanding Electric...
    Frigidaire electric stove keeps beeping
    IF IT HAS A MECHANICAL CLOCK, THE START AND STOP TIMES NEED TO BE SET, THE OVEN CONTROL SET TO CLEAN, AND THE SELECTOR SWITCH SET TO CLEAN.
    TO CLEAN NOW SET START TIME TO THE TIME ON THE CLOCK AND THE STOP TIME TO 3 HOURS LATER.
    LOCK THE DOOR. IT SHOULD START AND THE CLEAN LIGHT SHOULD ILLUMINATE, OR OVEN ON LAMP SHOULD LIGHT.
    IF IT STILL DOESN'T WORK, THERE IS A PROBLEM WITH THE CLOCK OR THE CONTROLS OR THE LOCK ASSEMBLY.
    A WIRING DIAGRAM WOULD BE BEST FOR DIAGNOSING THE PROBLEM.
    Feb 20, 2008 | Frigidaire FEF336BC Electric Kitchen Range
    GE 30" Self-Cleaning Freestanding Electric Range - White-on-White Logo
    67 people viewed this question
    Top Kitchen Ranges Experts
    Dan Webster
    Dan Webster
    Ismael Rodriguez...
     Fix Your Board
    Fix Your Board
    Are you a Kitchen Range Expert? Answer questions, earn points and help others
