Question about HP Pavilion 110-1030NR Notebook
Hp mini 1030nr is slow after ram upgrade. I installed a second 1 mb dimm thinking to take the speed up a notch. Instead it seems to work more slowly. Did I miss something?
    Guru:
  • 1,051 Answers
This is a common misconception. Increasing the RAM typically slows things down due to additional information needed to be read and interpreted. In the old DOS days this can be compared to a wait state, were the faster components need to wait for slower ones to catch up. You may be better off removing the added RAM.
Posted on Sep 11, 2010
I want to upgrade my Laptop NX 5000 RAM which is currently 256 mb. Please suggest in details what type of ram is reqd i.e. DDR, DDR1/2 and what about 180/200 pins
You can upgrade to 2GB.
(1024MB.
512 MegaByte + 512MB = 1024MegaByte
1024MB = 1GigaByte )
It is DDR Sdram.
(Double Data Rate Synchronous Dynamic Random Access Memory)
It is also SO-DIMM, as used for laptops.
(Single Outline Dual Inline Memory Module)
http://en.wikipedia.org/wiki/SO-DIMM
There are 200 gold plated contact pins. 100 on each side,
http://en.wikipedia.org/wiki/File:1GB_DDR2_SO-DIMM.png
Note the Locating Notch on the bottom, and how it is off to one side.
Note the Side Notch on each side.
There is a Locating Lug in the bottom of the ram memory slot, for the laptop.
The ram memory module must be turned to the Locating Notch lines up with the Locating Lug.
There are spring clips on each side of a ram memory module.
The tops of the spring clips are eased to the outside.
This allows a bump, or protrusion on the spring clip, to come out of the Side Notch.
When the ram memory module is ensured to be seated correctly, in the ram memory slot, the spring clip 'bump' will be in the Side Notch.
A laptop ram memory module is removed AT AN ANGLE!
NOT too much more than the angle it is in, when installed in the ram memory slot.
After the two spring clips are eased out, the ram memory module will pop up a little bit.
Slide it out AT THAT ANGLE.
If you it up to a straight up position, you will damage the gold plated contact pins of the ram memory module, and the contact pins in the ram memory slot.
Damage the contact pins in the ram memory slot, and you are looking at motherboard replacement.
Everywhere on the ram memory module is the BODY, except for the gold plated contact pins.
Handle the ram memory module by the Body.
The Body is coated with a see-through protective plastic.
Refrain from touching the gold plated contact pins.
[ DDR Sdram IS DDR1. Double Data Rate Sdram.
DDR2 Sdram is Double Data Rate 2 Sdram.
DDR3 Sdram is Double Data Rate 3 Sdram,
1) http://en.wikipedia.org/wiki/DDR_SDRAM
2) http://en.wikipedia.org/wiki/DDR2_SDRAM
3) http://en.wikipedia.org/wiki/DDR3_SDRAM
It is the Technology used, not referring to the size ]
DIMM for desktops, Dual Inline Memory Module
SO-DIMM for laptops.
Single Outline Dual Inline Memory Module.
You need SO-DIMM, with 200 pins, and it's Frequency Rate, ('Speed'), is rated at 333Megahertz. (333MHz)
That is PC2700.
http://h20000.www2.hp.com/bizsupport/TechSupport/Home.jsp?lang=en&cc=us&prodTypeId=321957&prodSeriesId=449877&lang=en&cc=us
Under the bold black subheading -
Resources for HP Compaq nx6110 Notebook PC,
click on - Manuals
Quick jump to manuals by category:
,click on - Service and maintenance information - in blue.
Under the subheading - Service and maintenance information -
,click on -
HP Compaq nx6110, nc6110, nx6120, and nc6120 Notebook PCs -
Maintenance and Service Guide
(1 Oct 2005 )
This is a PDF file. The computer you are using now has Adobe Reader on it, which uses PDF files.
After you click on the file name above, it may take up to 30 seconds, before the first page comes up.
In the Bookmarks menu to the left, click on the + sign to the left of -
Removal and Replacement Procedures.
Scroll it down, click on -
6.7 External Memory Module
There is also an Internal Memory Module -
6.17 Internal Memory Module.
You can put UP TO 1GB in the Internal memory module slot, and UP TO 1GB in the External memory module slot.
For additional questions please post in a Comment.
Regards,
joecoolvette
Aug 10, 2012 | HP Compaq nx5000 Notebook
I upgraded to 1 gig ddr2 800mhz pc6400 dimm ram but it only shows up as 512 mb. why ?
The P5VDC2-MX motherboard specs state that DDR2 533/400 ram is supported. Your 800 is just too fast and is forced to operate at a slow speed. It is not unusual to get half the amount of memory shown when operating at half speed.
Nov 14, 2010 | ASUS P5VDC-MX Motherboard
I upgraded my RAM to 1 Gig but it's still showing only 256 meg. Why?
Hi this model sopport 2Gig Memory Ram.
RAM Technology DDR SDRAM Installed RAM 512 MB Max Supported RAM 2 GB Number of Memory Slots 2 x DIMMs Supported RAM Speeds 400 MHz • 333 MHz Installed Cache Memory 256 KB
Please check in to your Bios system maybe share memory Video or capacity is setting
Nov 03, 2010 | Dell Dimension B110 PC Desktop
I have Acer Aspire-5570-4765 laptop with Intel Core Duo Processor T2050 (1.60GHz, 533 MHz FSB, 2MB L2Cache) & 1 GB DDR2 (support dual channel) RAM memory. I want to upgrade RAM my memory from 1GB...
512 MB of DDR2 533 MHz system memory, upgradeable to 2 GB using two soDIMM modules (dual-channel support)
Yes its possible
Yes but the memory its going to run at slow speed 533Mhz
Sep 26, 2010 | Computers & Internet
Hp Compaq dx2200 MT RAM Problems
Firstly, you have to know that you can upgrade RAM as Double or Half of your pre-installed RAM. For example, like your pre-installed RAM is 256 MB, you can only upgrade RAM of capacity 128 MB or 512 MB. Secondly, check your previous installed RAM's speed that is shown in Ghz. You can only upgrade RAM to its similar speed, otherwise you get slow performance of PC.
Jul 18, 2010 | HP Compaq dx2000 Microtower PC Desktop
What is the ram limit of HP Pavilion 061 DW234A-ABA A530N I have two sticks of kingston 512 in it right now but want to put in two sticks of 1 GB each. Can I? Nvidia 7800 GS OC with 500 watt power supply,...
From the HP specifications page for Pavillion A530N:
Memory type DDR Memory speed PC 3200/2700/2100/1600 Memory sockets Two DDR DIMMs (184-pin) Maximum HP/Compaq approved memory Two x 512 MB DDR-DIMMS, 1024 MB total (1 GB)
Mar 10, 2009 | ASUS Computers & Internet
Need to know mem spd...333...400 etc to add cards
Memory Installed 512 MB (2 x 256) Maximum allowed 4 GB* (4 x 1GB) requires the replacement of the installed 256 MB DIMMs
*Actual available memory may be less Speed supported PC3200 MB/sec Type 184 pin, DDR SDRAM DIMM slots Four Open DIMM slots Two
Thats the sticks you need
Good luck
Nic
Feb 26, 2009 | HP Compaq Presario SR1630NX PC Desktop
Need to know bus speed of Trigem Cognac MB used in HP Pavilion 6730. Is it 100 MHz or 66 MHz?
it's 100 other info as follows:
Component Attributes RAM (standard) 64 MB SDRAM standard Maximum 256 MB (2 x 128 MB DIMM) Speed 100 MHz synchronous Sockets Two 168-pin DIMMs Size 16, 32, 64, and 128 MB DIMMs Type Supported SDRAM, 100 MHz, Intel PC SDRAM unbuffered DIMM specification, revision 1.0 compliant
Cache Level Quantity Level 1 (Primary) 32 KB (on processor) Level 2 128 KB (on processor) Upgrade Sockets None
Dec 09, 2008 | Computers & Internet
My name is Siavosh Eskandari. I have a desk top PC Compaq presario Desktop with Intel celeron processor 2.7 HHz Model SR1010NX, Prod. # DW25AA-ABA,Serial # MXK4180P8Y with 256 MB PC 2100 DDR SDRAM. The...
the model SR1010NX can take upto 1gb max of ddr 1 ram and must be done a 2x 512 ddr 1 chips
Memory Component Attributes Memory Installed 256 MB (1 x 256) Maximum allowed 1 GB (2 x 512 MB) requires the replacement of the installed 256MB DIMM Speed supported PC2700 MB/sec (messages at PC2100 Type 184 pin, DDR1-333 SDRAM DIMM slots Two
Nov 28, 2008 | HP Computers & Internet
When i add a memory in damaged DIMM slot showing black screen?
Try moving the working DIMM to other slots, it should work in any slot, if it does, the other ram u have is incompatible or bad
Install a matched pair of DIMMs (equal in speed: DDR266, DDR333, or
DDR400; density: 64 MB, 128 MB, 256 MB, 512 MB, or 1 GB; and
technology: 128 Mb, 256 Mb, or 512 Mb) in DIMM 0 in both Channels A and
B. If additional memory is to be used, install another matched pair of DIMMs
in DIMM 1 in both Channels A and B.
Mar 25, 2008 | Intel D865GBF Motherboard
HP Pavilion 110-1030NR Notebook Logo
149 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
