Question about LG DLE2532W Electric Dryer
I HAVE A FAIRLY NEW LG ELECTRICAL DRYER BUT IS NOT DRYING IS JUST COLD AIR. I NOTICED THAT THE VENT HOSE WASEN'T CONNECTED. CAN THIS BE THE PROBLEM?
  • LG Master
  • 43,501 Answers
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Sep 12, 2010
Lg dryer is overheating blowing the thermal fuse
you have an airflow problem. Check the vent hose all the way out and the outdoor vent hood.
a simple verification can be performed by disconnecting the vent hose from the dryer and see if this solves the problem.
Mar 03, 2014 | LG DLE5977 Electric Dryer
Takes too long to dry clothes
You may have a clogged air vent, check that the air vent hose is not smashed, if it is not smashed, have your dryer vent cleaned professionally, all the way from where the dryer connects to the wall to where the vent leaves the home,
Recheck the dryer operation, dryer vents should be cleaned every other year for optimum performance
Feb 16, 2014 | General Electric GTDP490EDWS GE 7.0 Cu....
Takes several cycles to dry
Clothes come out mostly dry, but need to run a 10 or 15 more minutes to completely dry. Towels need 2 drying cycles. Lint filter is clean. Lots of lint behind dryer and I notice a lot of lint on...
you need to clean out the dryer.somewhere lint is blocking the air movement.pull off the vent line,if it's long blow it out with a leaf blower,then clean out the duct that the lint filter slides into and vac out the cabinet where the motor is.if it's gas you should do this once a year electric once every two years.
Feb 17, 2011 | Dryers
I have a LG digital dryer about 6yrs old- there is cold air when drying and the clothes are still wet. The lights are blinking "drying" and "cooling" and also filter. My husband cleaned out all the link...
heatman101
Sep 13, 2010 | LG DLE2514 Electric Dryer
My maytag gas dryer has always taken a very long time to dry clothes....usually 2 hours. I have had it for 8 years and it has been this way the whole time. is this normal?
i would check air flow out of vent normally with plugged vent extreame amount of moisture is present in dryer on high temperature of air moving through dryer is
max about 140 degrees normally with room temperature arpund 70 the drying time is normally 60minutes or less
contributing factors to long dry time
pinched vent hose final rinse cold water
below 50 degrees remove vent screen inside dryer clean with hot water shine flashlight into vent opening verify not plugged if have candy or probe type
temperature gauge verify temperature
at vent exit
Dec 12, 2009 | Maytag PYE2300AY Electric Dryer
Water in vent
your vent out the house is broke or fell off,,suspose to a flap or lilltle blind type,,the cold air is coming in whule the hot air is trying to get out and it condensates in the vent hose ,,replace out side vent..with new vent kit..the best by is window ehaust kit...onthejob
Jan 10, 2009 | Kenmore 82822 Electric Dryer
Used to dry quicker
ck vent hose behind dryer to be sure it's no mashed or crimped may be too close to wall then ck vent to outside too long or too many bends will reduce air flow to outside
Aug 19, 2008 | LG DLE2532W Electric Dryer
LG Stacking Dryer
To make sure it is a vent problem ,Do one load without the vent hose attaching to the wall ,keep in mind that it may blow out some dust, you may want to cover the end of vent hose with a nylon stocking for just this ONE time.Now run this 1 cycle on a timed dry cycle at the highest mark...60, 70,etc.If the clothes are dry at the final stopping point than you know your vent is blocked.Or you pinched the vent hose closed.It only takes a small blockage to create alot of waiting time for dryer to end its cycle.The faster the air can get out of the dryer the faster it dries.
May 21, 2008 | Dryers
Clothes Hot but damp, water out of vent
Is this a combo washer/dryer in 1 unit? water shoud not come out if it is just a dryer. Your air coming out of the back vent hose should be hot. If your clothes comes out of your WASHER damp (more than normal) then your washer is not spin drying good enough. (worn belt, clogged drainage system).
Jan 09, 2007 | LG DLE2532W Electric Dryer
LG DLE2532W Electric Dryer Logo
54 people viewed this question
Top LG Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Mike
Mike
Are you a LG Dryer Expert? Answer questions, earn points and help others
