I belive it is a magnet which usually hold a CD on the spindle motor during playing. you need to take off top cover and find the spindle. The spindle has a round base for the disk, above the base should be another round piece with the magnet so during playing the disk is fixed between these two pieces. Check if there is missing round magnet in top piece. You can probably glue the magnet in place. Be careful, everything is fragile there, you can make more damages, probably better to bring it to a repair shop.
i would do a tack together job on it,,
get some thick fuse wire and tiy it round inside the grill holes on the out side edge tiy each one together at about every inch apart around the grill that will hold the two grill's tight, then if you still have the broken plastic bits glue them back on using supper glue its cheeper that trying to get part that you may never find?
reset centrel on round piecein dvd player just push carfully and check round piece is sumuthly turned if ok then play DVD /mp3 cd [ if totaly brokon you replace with new]
It sounds like the piece that holds the little ice door in place with a pin. If this is broken the only way to fix it is with a kit that Whirlpool has released. The part number for it is 8201756 and most appliance parts stores will have it. It contains a metal bracket that replaces the tabs as well as a new door assembly and instructions on how to install it. Hope this helps!
Depends on where you live they have Breville repair centers. I have problems with my juicer (not running) for Northern Virginia the closest place is NY. Check www.breville.com for a list of repair centers after warranty (not many) In California plenty of centers. Hope this helps.
Please send me your model number and I will try to find the piece that holds the pin that holds the flap in place. My phone is (865)945-3808, or email is [email protected]
Michael Anderson (Owner)
Anderson Appliance Parts and Service
