Question about Craftsman Garden
Put no new ground drive belt on my ride on mod#917255950 now my gears are back wards
  • 183 Answers
You have a twist in the belt. The belt should run roughly in a circle. You have made a figure 8 out of it.
Posted on Sep 12, 2010
Was cutting and stop moving forward and back wards belt in good condition
Could have broken the shear pin in the drive pulley. If one of the pulleys turns when you put it in gear but the other pulley does not turn then the shear pin is broken or missing.
Apr 04, 2015 | Husqvarna Rz4623 46" Ztr Lawn Mower Zero...
How do I put on a sabre 1542 hydr belt
Hydro static drive belt path. View second if gear style transmission.
Gear Trans drive belt path.
Oct 16, 2014 | Garden
What to check when it won't go in gear
force it into gear get tires off ground push foward petal roll wheel forward if it whine bad pump have to replace it
Aug 23, 2014 | Garden
MTD starter ingages but wont turn motor
HAVE REPLACED THE BATTREY LATE LEY IF SO SOUNDS LIKE THE CABELS ARE BACK WARDS CK IF THAY ARE IT WILL SPIN THE STARTER THE WRONG WAY
Aug 25, 2012 | Mtd Drive Belt 42"
My john deere js30 walk-behind mower will not drive.
either the belt do not have enough tension or the plastic gears on the drive wheels are worn down or eaten away
Jul 02, 2012 | Garden
I have a Honda HRR2165VXA mower that is having issues with the smart drive.
hello, hello, Drive belt replacement for front drive mowers. remove the belt coved on top of deckand clean out grass,turn mower on side where carb is facing up,use a pair of vice grips on side of mower deck so the blade can stop,remove the blade,remove the belt cover and clean out the grass,remove belt from rear and front pulley pulleys. install new belt,put belt cover and blade back on,put front belt cover on, should work,if that is not the problem; wheels will not prepeal the mower,wheels turn only when raised off ground, Check the gears or groves on the inside of the wheel for access wear that is a common problem,check the axle drive gears to make sure turns ok, to check gear box if ok pull mower back wards while drive is engaged,if wheels turn backwards than the trams is bad,all of this is caused by the operator,by not disengaging drive while pulling mower backwards or by holding mower back not allowing to propel self completely,hope this helps,any comments welcome,thank you.
Feb 15, 2012 | Garden
Put new belt on ground drive, but gear shifter only goes to 2nd gear as it is pushing against the new belt. Should the gear shifter be against the belt? Does the clutch tension pulley need to be adjusted?...
No it should not be against the gear shifter look over and try to rearrange.You may have to turn a bolt or two.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
Can't figure out how to put my belt back on my garden tractor, deck blade belt, craftsman model 917255950
Go to www.searspartsdirect.com. Put in your model number and it will come up with an IPL and diagrams for your mower.
Jun 25, 2010 | Garden
I have a crafstman riding mower. None of the
check drive belt probably slipping /stretched out and needs replacement
Apr 08, 2010 | Craftsman Garden
I have montgomery ward riding mower and cant
Line up the deck where it needs to be, and lower the lever....the hanging links should come close to where they go, then use the pins (or whatever) to insert into the hanging levers....Leave the handle lowered, then hook the belt onto the engine pulley, then line it up with the pulley on the deck...you may have removed the belt guides, so put them back on...They help keep the belt from falling off.
Check your work to make sure things look right...You should be done.
May 10, 2009 | Garden
Garden Logo
43 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
