How to open the gener8 steam cleaner model no bu/xy542743
I have a GENER8 steam mop i can not get it to steam it get hot but no steam, i have cleaned out the bottom foot but nothing can you help
There is probably a blockage preventing water from entering the steam generator.
Mostly with domestic steam equipment the water gravity feeds and it doesn't need much to stop the flow - often just a collapsed tube or a wayward blob of sealer.
Unfortunately to find the culprit the appliance will probably need partially dismantling.
Sep 23, 2016 | Vacuums
Cannot open water tank for beldray 5 in 1 steam cleaner
Its very hard to open the tank as it has a seal on to stop water and steam escaping hold it tight and twist anti clockwise
Nov 09, 2013 | Beldray Heating & Cooling
I can't take lid off steam cleaner!
need more information like make and model of steam cleaner
Jan 14, 2013 | Vacuums
Need a owners manual for Craftsman Power Wash- Quantum Gold 6.0 2300psi
Do you have a model # so I can help you find the manual
Jul 28, 2011 | Garden
No steam from a grime buster steam cleaner what is wrong?
Check the water reservoir for clogg. Be sure that the cleaner has water on it and it is heating. .If not heating there you'll sure it won't give steam. Check the heating element for open or no continuity.
Heated water needed to generate or produce steam and you'll need a continuity tester to test it. Replace it with similar model and rating also with same size.
Good luck.
Jul 07, 2011 | Irons
Need a water tank safety cap for euro- pro canister steam cleaner model S3325H
I need a cap which is located on the back of the clean water tank on a Bissell model 1950-3 steam cleaner
Aug 20, 2010 | Euro-Pro S3325 Handheld Steam Vacuum
My hoover legacy steam cleaner model#f7223-900 keeps dispensing liquids. Any cures woul'd be helpfull. thanks-
This model has electric solenoids which dispense solution. one may be stuck open, I would recommend to take it to a service shop for an estimate.
Mar 09, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
Euro-Pro Shark hand held steam cleaner model #sc618hd
Your heater in the cleaner is either plugged or has quit working, make sure you are getting a good ground for the cleaner. you may want to check the ground pin on the cord and make sure it is not loose or broken.
May 26, 2008 | Euro-Pro Shark SC-505 Handheld Steam...
Heating & Cooling Logo
673 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
