Question about Garden
My mower bogs down and blows out white smoke after a few monutes of m owing is this the carb causing this?
    Problem Solver:
  • 14 Answers
You may have a bad ring/head gasket. Check inside the oil see if there are metal shavings if you have a magnet that will fit in the oil fill see if it picks up any shavings or part of a ring try to move the magnet around as much as possible. Also could be valve guides/seals old and hardened.
Posted on Sep 11, 2010
Cranks but sputters, blows grayish/white smoke, and I do smell gas in the oil. What could cause this?the blades it cuts off.
do not run or try until you change the oil . sometimes the float sticks in the carb and fills the crankcase with gas . I like to add an inline shutoff valve .
Aug 28, 2016 | Garden
Honda gx620 on golf cart occasionally bogs down & blows enormous cloud of white smoke from exhaust.gas getting in oil also.runs great until this happens
What ussually causes white smoke to come out the exhaust is oil being sucked up in carb. Typical causes are too much oil in crank case or PVC valve. Or really bad piston rings
Feb 26, 2014 | V-Twin Horizontal OHV Engine with Electric...
Blows white smoke dies
Blowing a light colored smoke can be an indicator of burning oil. Have you checked your oil level? If it ran low it may be ceasing from heat and stalling. If it was running rich with too much fuel it should be dark colored smoke which can cause stalls. If your unit has a radiator a bad head gasket may let radiator fluid into the combustion resulting in white smoke. A little white smoke on start up can also just be moisture burning off in the exhaust but this should not cause stalling conditions, however if you're low on fuel that could contribute too. More details are important to narrow down your problem.
May 29, 2013 | Craftsman Garden
Oil in carb on john deere lt180
a needle valve in the carb thats not seating the gas over fills the carb and overflows threw the vent
Sep 15, 2012 | Garden
Husqvarna riding mower blowing white smoke out front
check the oil does it smell like gas the needle valve is not seating and gas over flows the carb and dumps it into the crank case
Apr 28, 2012 | Husqvarna Riding Lawn Mower 42 Inch Cut...
Engine only runs at low idle and smokes
So now, without the blades engaged, it smokes and then dies?
In your first description it sounded like the engine was under a strain. Overfilling with oil could produce a strain, but since it ran ok until you said you engaged the blades, I would have to ask if the blades themselves, were causing the strain. Sometimes if you cut wet grass, the clippings stick to your underside of the deck and can really build up. Also some rope, wire or twine would around the spindles could creat one. Check this out...
Now, with the "smoke" issue (I'm assuming a blue smoke from burning oil) I'm inclined to think your rings aren't compressing any longer and you're burning oil. You might be in for a rebuild... I hope not.
Aug 31, 2009 | Husqvarna 19.5hp 46" Yard Tractor
Engine bogs big puffs of white smoke from front
the engine will bog because the cutting blades are either cutting to much grass or the blades are touching the ground making it hard to keep rpm's then it will smoke a bit
Jun 05, 2009 | Garden
Started lawn mower first time of the season and it ran straight for a good 25 monutes with no problems. i turned it off to move it to the front yard andnow wwon't stay running. will only run for 5 to
Immediate thought is that something got ingested into the needle feeding the carb. Might have to remove the carb and clean it out thoroughly to maintain fuel flow through the engine. Generally if it runs a few seconds and shuts down then it is running off the initial burst of fuel and then starving out for any more from there.
May 12, 2009 | Craftsman Garden
My scooter is blowing alot of white smoke and bogging down.
replace the spark plug 2cycle engines are hard on plugs also sounds like it needs a carb cleaning black smoke means carb is fooding
Apr 01, 2009 | 2005 TN'G Verona 150
Craftsman riding mower starts, then runs for 30 seconds, then pours out white tons of white smoke and sputters and dies. It will then re-start and repeat the same. The amount of smoke is tremendous. It...
The smoke is oil going in to the combustion chamber, will have to check for broken rings or piston. also if the tractor was stored in a position that the oil would run to the combustion chamber it will do that untill all the oil is burn
Mar 22, 2009 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Garden Logo
95 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
