Question about Maytag Refrigerators
Just unrappoed Maytag model # MFF2258VEW2 22.0 cu ft .... bottom freezer drawer opens crooked. When you pull the handle to open it opens on the left side first, making the freezer drawer crooked and closes in the same crooked position. We have looked at the alignment of the tracks and they appear even but the whole drawer sits crooked when measure. Any suggestions as to what we can adjust? Steve
    Top Expert:
  • Maytag Master
  • 40,344 Answers
Consult with Maytag. Replacement may be the most practical answer.
Posted on Aug 04, 2017
  • 770 Answers
SOURCE: Maytag Frenchdoor w/freezer drawer - drawer sticks
you will need to remove the front and get to the slides clean them off and buy a low temp silcone to apply to tem do not buy grease apply it and work it in the problem will go away
Posted on Jan 24, 2008
SOURCE: Kenmore bottom freezer 795.75092402 freezer doesn't open
After several hours working and moving the door, I was able to slide open the door. Found out that the ice maker was leaking and the water was in the bottom an it frozen and that was stopping the door to open.
Posted on Jun 16, 2008
SOURCE: Haier 1.7 CU Ft. Refrigerator - what is warranty
1 year parts and labor
Posted on Aug 17, 2008
SOURCE: bottom drawer does not properly close
Okay, I fixed it for now. The design for this bottom freezer drawer is not good. What happened was most likely that my son slammed the door, and it bounced and was slightly open. Overnight, ice started to form all over the compartment, including inside the drawer guides. Some ice was probably obstructing the drawer glide from sliding shut.
What I did, not thinking this was the solution, was to prop chairs against the drawer to close it while I searched for answers on the Internet. In the meantime, some of this ice must have refrozen in the closed position (due to the weight of the chairs). When I went to check it later, I had a little trouble opening the drawer. I gave it a hard yank and some small frost flew off, as I opened the drawer.
It was not easy sliding it due to the frost. I then moved it out and in until it felt smooth, and finally closed the drawer and it stayed in the shut position.
Kids are instructed to close the drawer gently and visually check that it is sealed. There is also an air passage between the refrigerator unit and the freezer so that when you close the double french doors, some air pushed to the freezer section and momentarily pops the drawer open. You should make sure that the drawer closes before leaving the kitchen. If you are on vacation, prop chairs to make sure both the freezer drawer and the french doors stay closed. This is important if you're in an earthquake area as a small tremor could open the doors and you'll get a fire when the lights stay on and burn through the wiring (as others have noted).
Posted on Dec 04, 2008
SOURCE: Amana ARB2117BW - Bottom Freezer Door Won't Stay Sealed
This problem was posted in the wrong section. My model didn't have it's own, so its in ABB1927DE Bottom Freezer Refrigerator - perhaps you could create a section for it.
As it turns out, I looked more closely at the baskets inside. We had noticed that if the top basket was slid all the way forward when we closed the door that it would close better. So I looked to see if they or the slides were out of alignment. They seemed ok, but then I saw that the way the bottom basket was hanging didn't seem right - it was not quite nestled into it's retainer slot. I took the baskets out and turned the bottom one around. It fit perfectly into it's retainer slot. I then replaced the top one (it was already in correctly) and closed the door. It sealed correctly the first time. I tested it several times after that and it sealed tightly. Closing the top door did not make it unseal as it had done before.
Posted on Jan 23, 2009
Samsung rf 197acwp 18cf french door with bottom freezer drawer. Ice maker fell out of it's housing. I can't get the bins out to even look at it. HELP!
On my model RF265AABP there are two plastic clips near the back of the drawer that attach it to the slides. Pop those out, and the drawer can be lifted out.
Mar 26, 2013 | Samsung RF197 White 18 Cu. Ft. French Door...
The bottom freezer drawer is not closing so the freezer is getting an ice build up
It sounds like you either have a drawer that's off track, or something has fallen behind the drawer, not allowing the drawer to close. Empty the freezer, and pull the drawer all the way out. Look behind the basket of the drawer and see if some thing has fallen behind it. If nothing is behind the drawer, then the drawer must be off track. At this point, you'll need to pull the drawer out to the most extended point. Now push the drawer back in about 3-4 inches an **** it open fairly hard. Not hard enough to move the whole refrigerator. Just enough to put the drawer back on track. Hope this helps. : )
Apr 24, 2011 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
What is the cubic feet measurement for a GE Model TBX18 refrigerator? Also, what is its width and height?
The capacity depends on the exact model number. The TBX18TABWW and similar models are 17.6 cu. ft. The refrigerator holds 13.6 cu. ft. and the freezer 4 cu. ft. This model is 64.25" tall, including the hinge, 28" wide, and 31.25" deep.
The GE S series, including
TBX18SIBRWW, are 18.2 cubic feet; the specs are 13.04 cu. ft. for the fridge and 5.13 for the freezer. Total height (including the hinge is) 64.75", 29.375" wide and 31.5" deep including the handle. (It takes up 58" with the door open.)
The J series has the same total capacity and dimensions as the S series.
Remember to leave 0.75" free on both sides and 1" at the back and top for air to circulate around the refrigerator.
You can find your exact models specs and manuals here: . Enter the model number in the search box and click submit. Dimensions are provided in the Quick Specs for most refrigerators. The model number will be on a plaque in any of the following spots:
1) On the ceiling of the freezer near the front
2) By the temperature control
3) On the inside wall of the refrigerator near the crisper drawer on either side
4) Behind the crisper drawer
5) On the bottom front of the refrigerator
I hope this helps.
Mar 18, 2011 | Refrigerators
How is the freezer drawer removed for moving thru a small opening
pull it open, then there should be 2 screws on each side either on the outside of the rails, or on the inside
Jan 23, 2011 | GE Profile Stainless Bottom-Freezer...
Cannot open bottom freezer drawer. Ice in tray
remove all food from fridge and take it outside. leave it outside until ice is melted. this is the procedure and i have to do it every day im a Refrigeration Mechanic.
Oct 09, 2009 | Sub-Zero 19.3 cu. ft. / 547 liter Upright...
GE Profile 25.1 cu. ft. fridge is too large for door entrance
yes you can, or just removed the bottom drawer, open the upper doors and slide the refrigeraro thru the doorway by just swinging it thru. a mover friend of mine showed me that trick at it work great.
Jan 24, 2009 | Pds GE Profile Bottom-Freezer Drawer...
Bottom drawer hard to close
Check the drawer slides on each side for cracks or a screw that has come loose. The drawer should slide in a groove on each side firmly. Hope this helps. JT
Oct 10, 2007 | Miele 3.7 cu. ft. / 105 liter Upright...
My bottom drawer won't open?
Can you supply more info? Was there food in there that could have frozen in a position to lock up the door slides?
Oct 24, 2006 | Kenmore 4.8 cu. ft. / 136 liter Chest...
Refrigerators Logo
98 people viewed this question
Top Maytag Refrigerators Experts
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
