Question about Magellan Maestro 4040 GPS Receiver
The location where you plug in the charger broke free. It's loose inside the unit. How do I get the back off and how do I make the repair.
    President:
  • 1,111 Answers
The following advice pertains to the following magellan gps systems.
Magellan 800, 860, 2000, 2200t, 2500, 3000, 3050, 3100, 3140, 4000, 4040, 4050 and 6000t
i fix these and many other magellan gps daily so when considering my advice , please understand i do not google my solutions.
assuming your car charger is working (the little green light is on) and your magellan still wont start up after holding the power button while its plugged in for up to ten seconds and still does not start..read below
this is actually a very common problem with these magellan power ports...they are poor quality from the factory and always and i mean always fail..the new ports that you find on ebay are 100% better then the factory port.
if your able to replace that power port yourself, you can get one HERE, if not, ask the fellow that sells them for help.
due to some dubious "experts" on fixya, im not permitted to help you directly, but please follow the link above to get further help.
let me know if you need more help or info
Bill
Standing Member of G.O.T.
Posted on Sep 21, 2010
Can not charge
The socket that the charger plugs into has come loose from the control board. The only thing you can do is open it and resolder or send it in for repairs.
Jan 20, 2014 | Trust Flex Design Tablet
Charger problems
Sounds like a typical charging port problem and it's common to a lot of devices. What happens is that one or more tabs on the receptacle broke free from the main circuit board. The unit has to be opened, inspected and if it's only a poor solder joint, it can be repaired. But you will need the right soldering equipment to perform the job. The other solution is to send it away for repair and the companies usually have a flat rate repair for this. Good luck, hope this helps.
Jan 11, 2014 | Ematic 8GB Pro Series 8" Multi-Touch...
Where you plug in the charger is broke. Someone tried to plug in the wrong type charger and now the piece inside is loose. It will not charge.
http://satnavrepairservice.com/repair/charging-connector-damaged-missing/garmin-nuvi-350/34/46.html
This is your best option since additional devices need to be installed with SWS adaptors by technicians.
Mar 09, 2011 | Garmin nuvi 350 GPS Receiver
W800i not charging
Since you've got a new charging unit, you may need to try using different battery. If same problem occurs, then plug the charger to the phone and slowly wiggle the charger to see if the power jack is loose.
If everything looks okay, then there's a loose connection inside or a bad IC that needs to be replaced. And you may need to contact the manufacturer for repair.
Have a great day!
Oct 18, 2009 | Sony Ericsson K800i Cellular Phone
Can I fix loose charger inside the unit of Magellan Maestro 4040?
  1. The only way it can be fixed is to replace thew whole motherboard. about $90.00
please rate our help to keep free sewrvice online
Aug 30, 2009 | Magellan Maestro 4040 GPS Receiver
Two year old #200 unit. Plug seems to come loose
yikes! unfortunatly it sounds like you will have to send that back into garmin for repairs. for loose parts inside they are the only people who are authorized to repair it. Unless you know someone who is good repairing electronics
garmins website will give you a flat rate repair on what it costs to fix it.
Aug 14, 2009 | Garmin nuvi 200W GPS Receiver
Square outlet on back of unit not connecting to charge plug
You probably have a loose connection inside the unit and it needs service or replacement. call the manufacturer.
Aug 05, 2009 | iGo Smart Connector A13 For GameBoy...
Charger broke
There is a proprietary charger for the HDD6330, but it is no longer available through Philips. Try contacting Fox International or some third party seller for the original USB cord.
Mar 13, 2009 | Philips GoGear HDD6330 MP3 Player
Samsung x830 Charger Port cracked
You can take your Samsung Phone for Repair to Dr. Cell Phone in Houston, TX. They do all kinds of Samsung Phone Repairs.
Nov 17, 2008 | Samsung SGH-X830 Cellular Phone
Power pin fell off inside of Magellan Roadmate 3000T
I managed to solder my connector back in place. The ground trace broke away from the board so I had to install a jumper to ground. I put RTV on the connector to secure it after the repair.
Worked great for a few weeks until it was dropped again and lost power, something else has a broken connection.
Jan 05, 2008 | Magellan RoadMate 3000T GPS Receiver
Magellan Maestro 4040 GPS Receiver Logo
Top Magellan GPS Experts
Will Halftowaite
Are you a Magellan GPS Expert? Answer questions, earn points and help others
