Question about Rinnai Toyostove Direct Vent Heater: Laser 56 Toyostove Direct Vent Heater
The thermostat setting temperature of my Laser 56 Toyostove will suddenly jump up to a high setting (86) which in turn causes the stove, when not operating, to start up and/or causes the stove, when running, to overheat. The slide control for the thermostat setting remains at the high temperature setting and will not go down to its usual 55 degrees when moves to the left fully. Problem occurs erratically. Replaced the 2 circuit boards; worked for a while and then the problem reappeared.
  • Brian Niten Sep 12, 2010
    What do you have the set back thermostat set on? That's the lower one.
  • wios Sep 12, 2010
    I have the set back thermostat setting at the minimum setting (55 or so). Thanks for your help!
  • 674 Answers
The reason I asked was to see if it is a power supply problem. If the setback had been set on 86 I would suspect you were having power fluctuations causing the heater to go the setback temperature. I will give this some more thought and post something else soon.
Posted on Sep 13, 2010
  • Brian Niten Oct 01, 2010
    Check for some pinched wires in the heater or a spot where a wire is grounding out.
On l-56 stove an error code EE 8. what is this and can it be repaired?
The blower motor is not working properly. Turn the stove off and remove the front cover. Remove the lower baffle in the front. Remove the black hose that is about 1 1/2" in dia. If it breaks don't be surprised. Stick a pencil in the hole and spin the fan. Keep trying until it spins freely. If it spins freely from the start the motor is burned. Put the black hose back on and try to start. IF the hose broke you will need a new one. For now put some electrical tape around the break to get you going.
Keep us posted.
Tom
Oct 14, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
Temp is reading HI so stove won't come on. Figure it is a thermostat problem(?)
This means the room temperature is over 95F. This could be due to the sensor being in the sun or the sensor is shorted. Try unplugging the thermostat wire and see if it goes away. If it does you may need a new thermostat wire.
Sep 27, 2010 | Rinnai Toyostove Direct Vent Heater: Laser...
I have a toyo laser 56 stove. It is starting to make a moaning noise. what shoud i do?
Pilot,
You need to have a new mat put in the bottom of the burner. When this mat lifts, sometimes the flame will cause a moaning noise with a large yellow flame. A new mat and maybe a burner ring will fix ya.
Tom
Dec 16, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
The fuel leaks out thruogh the overflow and pump. Laser 56 Toyost
One possibility is that the float is not working properly.
The unit need to be serviced,
Sep 30, 2009 | Rinnai Toyostove Direct Vent Heater:...
Rinnai heater flashes code 12
Bailey,
Next time you try your stove watch the flame. If the flame goes away and then the error code comes on, you have something wrong with the over temp circuit, gas or gas valve, If the code comes on and then the flame goes away you have a flame sensor problem.
Good luck,
Tom Hawkins
hawkins111@gci.net
Mar 13, 2009 | Rinnai Toyostove Direct Vent Heater:...
Exhuast smell(odor)
J,
If your Laser 56 is giving off fumes it is probably coming from the igniter gasket and the igniter guide gasket. The igniter gasket has broken and needs to be replaced with the new style. The new style cost about $12. The guide gasket is the fiber gasket around the hole the igniter goes in. It has seperated and all you have to do is smash it back together. If you have high temp silicone or furnace cement, you can use either to seal the crack. Any toyotomi dealer can get you the new igniter gasket # 17185580.
Good luck,
Tom Hawkins
hawkins111@gci.net
Feb 28, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Laser 56 EE6
EE 6 happens for several reasons. Most likely in your case when the stove runs for a while after you turn it back on, the code is due to and over heat. The circulating fan and cover need to be spotless. If they are then the code is due to low fuel, no fuel or dirty filte on tankor stove.
Tom Hawkins
Bethel, Alaska
hawkins111@gci.net
Jan 09, 2009 | Rinnai Toyostove Direct Vent Heater: Laser...
Toyo 56
Hi ejohn,
There is no valuable, practical adjustment for the flame on a Toyo Stove. A yellow flame can be caused by several things. How old is the stove? When was the last tune-up? A dirty sooty carboned up stove will have a yellow flame. A breach in the flue pipe will cause a yellow flame. An incorrect installation of the flue and exhaust hoses/metal exhaust elbow will cause a yellow flame. In the last scenario, the intake will be hooked to the exhaust and the exhaust will be hooked to the intake ports of the flue pipe. A malfunctioning fuel pump can also cause a yellow flame. The wrong fuel can cause a yellow flame, too. Most likely, your stove is dirty and needs a tuneup. It should have a bright blue flame if it is clean, and operating correctly. You can download a manual at REE, Anchorage through a Google search. If you want a more detailed diagoses, write back and give me more detail and I can help you further. Toyotech
Jan 30, 2008 | Rinnai Toyostove Direct Vent Heater: Laser...
Heating & Cooling Logo
240 people viewed this question
Top Rinnai Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Tim Whalen
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
