Question about Ovens
Can't figure out how to set oven to come on at a certain time.
  • 3 more comments
  • denkeenan Sep 11, 2010
    Kenmore Model 911-3218811 - wall mounted electric oven. Can't seem to find a way to set it to come on4 hours from now while we're not home.
    Kenmore Model 911-3218811 Wall mounted electric oven. Can't seem to set it to come on 4 hours from now while we're not home.
  • denkeenan Sep 12, 2010
    Kenmore wall mount electric oven, Model # 911-3218811 I want to set it to come on say 4 hours from now when we are not home
    Kenmore wall mount electric oven Model 911-3218811 Probably early 1990's model. Can't figure out how to set it to come on 4 hours from now when we are not at home.
    Where do I find manual?
  • Ovens Master
  • 3,083 Answers
You will have to refer to your manual for the settings. Not knowing what kind of oven you have, I couldn't look up the info or find a manual for you to download, but enter your model number at Retrevo.com and you might find one.
Posted on Sep 12, 2010
    Genius:
  • 1,622 Answers
All you have to do is to follow the steps below this will help you know to adjust your Oven.
Step 1 - Know Your Oven
In order to adjust your temperature control, you must be able to recognize the control knobs on your oven. There are 2 different types of control. One will have a screw in the shaft of the knob and the other has a small dial on the back of the knob. You can pull either knob away with a small amount of force.
Step 2 - Adjust Control
Adjust the temperature by either turning the screw in the shaft with a screwdriver or the dial on the back. Turning clockwise will lower the temperature setting and counter-clockwise will raise it. Once you are satisfied, fix the dial back onto the oven.
Step 3 - Check Temperature
Place a heat-resistant thermometer in the oven. Turn the oven to a high setting and check that the thermometer reading is within 5 degrees of the displayed temperature after 20 minutes. If it is too high or too low, go back and adjust the controls again.
Take care...
  • 944 Answers
Please specify the oven name and model no and please clearly explain your problem more.So we could clearly explain you in more depth.
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 11, 2010
  • Natarajan Ramasamy
    Natarajan Ramasamy Sep 11, 2010
    Please check the manual page no 9,10,11 .Page no 11 deals with your issue.
    This is not your produce manual.But Kenmore same series manual.So you can use it to refer it.
    Thank you.
How do I set the timer to cook on a certain time
read your owners manual . some will start at a preset time and others will not but will shut off the oven after baking for a preset time
no manual try Google with make ,model,and manual
May 28, 2015 | Ovens
AEG oven switches itself off after 35 mins
does it turn off after the oven has got upto temperature if it does it is probably that your thermostat has gone as this cuts off as a safety feature if your oven gets hotter than the thermo setting then it will shut off to protect from over heating or causing a fire hazzard with high temperature are you sure you havent changed the timer as well cus you can set a timer for your oven to switch on at certain time and to also switch off after a certain time if you still have the manuall have a look through the timer section if you do not have a manuall then check on your makers web site these should have a manuall online for you to check first i would check that the timer is not on if i can find you a manuall online i will post back hope this is some help.................
Nov 04, 2007 | Ovens
Ovens won't heat
Have you set the clock alot of ovens need the clock set so the oven will work, this is a safety thing so if you set the oven to turn off after 1 hour or at a certain time of day and say the power went out or the gas was turned off and came back on then the oven won't just start up on its own
Mar 08, 2011 | GE Monogram® ZET958 Electric Double...
I've just moved to a new house and there's no manual for the oven
I just sat down and played with the dials and worked them out.
Jun 05, 2009 | Ovens
Delay or time bake
You can find the manual at www.managemyhome.com, and the instruction is on page 11.
You make sure the time is set correctly.
You press Bake, and set the temperature you want to bake.
You press Cook Time and enter the amount of time you want the oven to cook.
You press Delayed Start, and enter the clock time that you want the oven to start.
Jan 30, 2009 | Kenmore 47772/47774/47779 Electric Double...
Setting the oven to come on at a certain time
I have a neff u1722 but I think the settings are pretty much the same. To set a coming on time first press the button with side by side triangles on it until the symbol l->l flashes then rotate the plain button next to it to the length of time you want the food to cook for. After about 4 secs the normal time will come back on. Then press the side by side triangle button again until the symbol ->l flashes then with the plain button rotate again to set the time you want the food to be cooked for. Hope this works
Jan 16, 2009 | Neff U1421 Double circotherm Electric Oven
Oven temperature increases 50' after original temperature is reac
What it needs is a new oven thermostat fitting, much cheaper solution than buying a new oven, it is a fairly straight forward repair, if you require more details let me know.
PLz rats my solution.
Thanks.
Jan 03, 2009 | Whirlpool RBS305PDS Electric Single Oven
Old Gaffers& Sattler oven won't heat up. I suspect timer setting?
The most common failure in any electric oven is the heating element.
Jun 20, 2017 | Ariston Technologies Ariston FO98P...
Frigidaire electri-clean oven Model RSE37BAL*5
make sure that the clock is displaying the current time of day
select timed bake
select the temp of the oven you wish to bake at
set the time you wish the oven to come on with the start knob
set the time you wich the oven to turn off with the stop knob
Apr 11, 2008 | Ovens
Oven doesn't maintain temperature
When an oven doesn't maintain the set temperature, first make sure no one is allowing the heat to escape by opening its door. If not, the oven control either needs to be re-calibrated or replaced. To have the control replaced, call an appliance service person.
Jan 18, 2006 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
49 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
