Question about Philips Televison & Video
Osd main menu locked message - Philips Televison & Video
  • 10,515 Answers
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
OSD Locks Automatically
Power off your computer and then remove the monitor cable from the port on the back side of the computer case.
Reattach the cable and make sure the pins are correctly screwed in. Power the computer back on and check to see if the OSD lockout message is still being displayed.
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lockout message.
Find the OSD lockout heading and read the method that your particular model uses to remove the lockout.
Attempt generic lockout removal procedures if you no longer have the manual that came with your monitor.
Press and hold the "Menu" button located at the bottom of your monitor for 15 seconds and wait to see if the OSD lockout message disappears.
Press the "Menu" button again if the lockout message remains on the screen.
Use the arrow buttons to navigate through the main menu options.
Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lockout.
hope this helps
Jun 07, 2012 | HP Computers & Internet
Ihave an view sonic E70fb moniter. and am having problem with osd lock. osd lock strip often and often see in my moniter screen. and i coulden't solve this problem. so, please give me the solution as...
· The OSD Lock Out Message
Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
· 2
Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
· 3
Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
· 4
Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
· 5
The OSD Settings Menu
Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out
Jul 22, 2011 | ViewSonic E70f 17" CRT Monitor
My HP 1730 monitor is showing "OSD Lock Out" message. How can I remove this msg?
The following site has step by step instructions on steps you can try: http://www.ehow.com/how_5008634_fix-lockout-display-computer-monitor.html
I'll paste them below: All computer monitors, whether they are LCD or CRT style, have a built-in feature called the on screen display (OSD) lock out that prevents users from viewing any images on the monitor. If your computer screen has accidentally been set to the OSD lock out setting, there are several different ways you can remove the lock out, depending on the make and model of your particular computer monitor.
1 Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
5 Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Mar 01, 2011 | HP 1730 LCD Monitor
I am getting many times osd lock problem i am getting irritating so please give solution for unlock the osk lock on monitor.... or sometimes repeatedly blinking the main menu on the...
Nov 26, 2010 | ViewSonic E70f 17" CRT Monitor
Why am I getting osd main controls locked flashing and then the same message saying unlocked and i am unable to clear it - posted in Monitors ... the attention osd locked is constantly flashing on and off...
Most of the monitors have a function to lock the OSD to prevent accidental changes in the configuration of the monitor.
If you are constantly getting the message about OSD being locked and unlocked then it means that the OSD locking button is constantly pressed.
Usually it is the "Menu" button on the monitor which is used to lock the OSD.
Check if the Menu button is constantly pressed.
Sep 11, 2010 | Compaq Presario 5000 PC Desktop
My hp 1740 monitor is displaying osd lockout and menu back ond forth and i cant get rid of it
  1. Power your computer completely off and then remove the monitor cable from the port on the back side of the computer case. Reattach the cable and make sure the pins are correctly screwed in all of the way. Power the computer back on and check to see if the OSD lock out message is still being displayed.
  2. Step 2 Check the manual that came with your computer or monitor and locate the troubleshooting section if you are still receiving the OSD lock out message. Find the OSD lock out heading and read the method that your particular model of monitor uses to remove the lock out. Follow the instructions to remove the lock out.
  3. Step 3 Attempt generic lock out removal procedures if you no longer have the manual that came with your monitor. Press and hold the "Menu" button located at the bottom end of your monitor for 15 seconds and wait to see if the OSD lock out message disappears.
  4. Step 4 Press the "Menu" button again if the lock out message remains on the screen. Use the arrow buttons to navigate through the main menu options. Highlight the "Settings" or "OSD Menu" option and then hit the Menu key again to access the new list of settings.
  5. Step 5 fix-lockout-display-computer-monitor-1.5-120x120.jpg jQuery(document).ready(function(){ jQuery('#jsArticleStep5 span.image a:first').attr('href','http://i.ehow.com/images/a04/or/7q/fix-lockout-display-computer-monitor-1.5-800X800.jpg'); }); The OSD Settings Menu Scroll down to the "OSD Lock" heading. Use the arrow keys to change the setting to "No." Hit the Menu key again to return to the main menu. Scroll over to the "Exit" setting and then hit the Menu key a final time to exit the menu setting and remove the OSD lock out.
Apr 15, 2010 | HP L1740 17" LCD Monitor
MY LG FLATRON L1951S, THE OSD IS LOCKED. HOW CAN I UNLOCK IT.
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
The OSD Menu on the monitor itself is locked. How do I unlock it so I can adjust my settings? It was given to me, I have no printed material for it. Thanks
Turn off monitor, hold down the menu button, turn the monitor back on, release the menu button after 10-20 seconds. Your Iiyama screen will now be unlocked.
Mar 07, 2010 | HP M700 Monitor
Osd lockout? How do I get the on screen display unlocked?
OSD Lockout prevents changes being made to the monitor through the use of the front panel buttons. When the OSD is locked, pressing a button from front panel displays OSD Lock-out for about 10 seconds. You can quickly remove the OSD Lockout message by pressing a front panel button again. To unlock the OSD, press and hold the Menu button until the Main menu displays, about 10 seconds. To lock the OSD, press and hold the Menu button until an OSD-Lockout message displays, about 10 seconds.
Dec 03, 2009 | HP W1707 LCD Monitor
Problem with OSD Main Contorls unlocked/locked
Philips say "To unlock the OSD Controls press the “MENU(OK)” button for more than 10 seconds while there is video input from PC."
Jan 29, 2009 | Philips 190B6CB/27 19" LCD
Televison & Video Logo
191 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
