Question about Microsoft Office Professional 2007 Full Version for PC
What is .xls in excel? - Microsoft Office Professional 2007 Full Version for PC
    President:
  • 2,340 Answers
.xls is the extension format for an excel file in Microsoft Office 2007.
Posted on Sep 11, 2010
How to repair damage excel file
Use Excel Repair Toolbox designed to restore data from corrupted .XLS files. MS Office .XLS file repair software can fix many error.
For more: https://www.xlsrepairtoolbox.com/
Jul 14, 2015 | Microsoft Excel for PC
How do I open an .xls file in 64-bit version of excel without it being in protected view?
I was like that when the problem exists when double-clicking in Windows Explorer. Then I get the message that the program isn't responding and have the option to close or wait. After a few moments Excel does eventually open and I can work on the file. I do not have the problem when I open the file directly form Excel.
Read here, perhaps this article will help you - Excel Restore Toolbox http://www.excel.restoretools.com/
Apr 25, 2015 | Microsoft Excel for PC
Excel file problem
Two possibilities:
  1. You accidentally save it as an HTM or HTML file. It will still open in Excel if so. Open the file in Excel and do a Save As back to an XLS (Excel 97-2003 version file) or XLSX (Excel 2007 - 2013 version file).
  2. You associated XLS or XLSX files to be opened with CometBird. If so, right click on the file and choose "Open With," then go to the bottom of the choices and left-click on "Choose default program..." Then choose Excel and you should be all set. Windows will reassociate all your files to automatically open with Excel instead of CometBird.
Apr 18, 2014 | CometBird
My excel files is not open how to open it
Hi.
OPTION 1
Right click your excel file, select the RENAME option.
Type any name and at the end put .xls example... nunex will be nunex.xls
Save it and try to open again.
If that dosnt work, go to microsoft Office, Excell. Open and select the files.
OPTION 2
For one reason you see the logo has changed from excel to a strange logo, then you must right click the file, Properties, then where it says Opens with you select CHANGE. -- > Browse -- > and select Microsoft Excel.
SAVE and Exit.
It will be solved.
Feb 02, 2011 | Microsoft Office Excel 2003 for PC
My file is in excel 2007 i want to open in excel 2003 how would it happen or not
open the excel 2007 file in excel 2007 only and save as file.xls[xls is a 2003 version]
with this method u can open it though excel 2003
any issues kindly rate and revert
Jul 14, 2010 | Microsoft Excel 2007 Home and Student...
Can a PDF be created from an Excel document? And
yes it can.. just download xls to pdf file converter.. it can convert xls, doc files to pdf file. Or you can simply convert it using the internet. just type to any search engine this keyword "xls to pdf convert"
Oct 23, 2009 | Checkmark MultiLedger for Mac/Windows...
Repair corrupt excel file
Don\'t need to worry even if your excel
files are get corrupt because there are several ways to repair
corrupt excel files. The easiest available solution is to use "Open
and repair" utility of MS excel to repair damaged xlsx or xls files.
Jul 10, 2009 | Microsoft Office 2003 Professional Full...
Problem while loading the xls file
hello my friend, the error refers to the writing of xls to xml of the file. So therefore the error committed within the software side particularly in the excel software. Try to convert another xls file to xml files then if you find same problem i advice you to used full version of office rather than using light version. Then reinstall the office particularly the excel software
Jun 16, 2009 | Microsoft Office Professional 2007 Full...
MS Office 2003 Intallation
Go to "FILE", "Save As" and then change "Save As type to XLS" That should hold that setting afterwards from now on.
<img src="http://i.i.com.com/cnwk.1d/i/tr/downloads/images/10_things_office2007_compatibility/10_things_office2007_compatibility_a.jpg">
If you have any more questions please feel free to email me and don't forget to rate.
Thanks!
Feb 23, 2009 | Microsoft Office Excel 2003 for PC
EXCEL2000 PROBLEM
I think I have a way for you to get this done. Open a.xls and then open b.xls. In b.xls, create a formula in any cell that you want to be updated based on the data in a.xls. For example, if you want cell A1 in b.xls to stay updated with the data from cell A1 in a.xls, your formula in A1 of b.xls would look as follows:
[a.xls]Sheet1!$A$1
You can also create such formulas by following these steps:
1) Open a.xls and then open b.xls.
2) Place your cursor in the cell that you want to update dynamically in b.xls.
3) Enter the equals sign ("=").
4) Click on the "Window" menu in the top menu bar.
5) Select a.xls from the bottom of the menu items in the Window menu.
6) Click on the cell that contains the data that you want.
7) Hit Enter.
If you do all of these steps, you should find yourself back in b.xls with Excel having created the right formula for you. As a test, you can switch to a.xls and make a change in the source cell, and then you should be able to switch back to b.xls and see that same update.
Good Luck, hope this meets your need!
Regards,
RichMTech
Aug 08, 2008 | Microsoft Excel for PC
Microsoft Office Professional 2007 Full Version for PC Logo
24 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
