Question about Kenmore Elite HE5t Washer
We have a Kenmore HE5t that has an F30 error code. When you start the washer it just keeps clicking and won't fill. Any advice?
  • 15,935 Answers
The F30 error code will flash when the dispenser motor cannot be driven to its proper position.
* It could have a mechanical failure in the linkage between the dispenser motor and the top of the dispenser.
* Loose wire connection between the machine control board and the dispenser motor
* Failed dispenser motor
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 11, 2010
Kenmore Elite 5t shows an F30 code, water fill solenoid is making a noise like its not opening
This is a dispenser motor issue. If you pull the unit out and remove the 3 screws coming into the back of the top panel, you can remove the top panel to access the top of the dispenser. There is a motor that turns a plastic lever on the dispenser. you might be able to manually help the arm move to get past the error code, but ultimately you will need to replace the dispenser motor. Here is the part to order.
Dec 03, 2012 | Kenmore Elite HE5t Washer
Won't fill and clicking noise
What is the model number of your unit? Where is it clicking from?
Dec 02, 2012 | Kenmore Elite HE5t Washer
I have a kenmore elite HE3t and it has an F20 error code. What does this mean?
The F20 error code means; no water was detected entering washer or pressure switch trip was not detected after 6 minutes
Many times that is caused by a blockage a pinched fill hose,or the filter screen on back of washer where hoses attach to are clogged
Good luck,i hope this helps
Gene
Aug 01, 2011 | Kenmore Elite HE5t Washer
My Kenmore 11047512600 front load washer has a F30 error. it start the cycle and the dispenser cycles / clicks several times and then flash F30. I have already replaced the CCU module with no results.
Oct 24, 2010 | Kenmore Washing Machines
My Whirlpool washer flashed F30. Not filling up with water.
"F30" indicates "DISPENSER SYSTEM ERROR" When the dispenser motor cannot be driven to its proper position this error appears in your washer. To fix this problem follow these procedures.
1. Unplug washer or disconnect power. 2. Check mechanical linkage from dispenser motor to the top of the dispenser. 3. Check wire harness connections to the dispenser motor and Central Control Unit (CCU). 4. Check dispenser motor for powered rotations.
Thank you !!
Jun 13, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore elite HE5t steam front load washer that keeps putting up f20 error the water lines are not plugged water is flowing into it i moved it out to check the water lines and it ran 3 loads then...
http://www.fixya.com/support/r3608632-f20_error_code
This code is tricky to troubleshoot, so jsrock516 advices to eliminate the easy common sense items first.
May 14, 2010 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he5 - error code F30
F 30 code can be reset by un plugging power cord for 5 minutes also pull out the detergent dispenser and reach all the way in to the back there is a small plastic flapper valve move it from side to side with your finger this will rest code f30 and save a tech visit..
Nov 10, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite HE5t Washer Logo
577 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
