Question about PTC Mathcad® 14 for PC
Unable to create 12.0 engine factory, error - PTC Mathcad® 14 for PC
Exiting tally error contact tally solutions, unable to create company in path'e:\tally\data\10002'
Nov 01, 2012 | Computers & Internet
I need to restore my acer to factory settings
You can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction. NOTE: This will erase all the datas on the computer.
You can also create a set to Recovery disk from the recovery partition, to do so
Start Menu> All Programs> Acer erecovery management> Click Create Factory Default Disk, if you receive any error code or unable to burn the disk, please contact Acer Technical support at 1 800 816 2237 and order for an Recovery Disk.
Thanks and regards,
Jitha
Nov 17, 2011 | Acer Aspire Computers & Internet
How to restore my laptop to factory settings
If you are using Acer computer then you can restore the computer back to factory default,to do so, follow the below steps: Turn OFF the computer, now as soon as you hit the power button, keep on holding "Alt" key & keep on tapping "F10" key, i.e Alt+f10, it will open the recovery console, select full factory restore and follow onscreen instruction.
Thanks and regards,
Jitha
Feb 06, 2011 | Computers & Internet
How do I create a back-up (recovery) disk?
You can create a set to Recovery disk from the recovery partition, to do so Click
Thanks and regards,
Jitha
Dec 27, 2010 | Acer Aspire T160 PC Desktop
Lost recovery disc
Thanks and regards,
Jitha
Nov 29, 2010 | Computers & Internet
Need erecovery for acer aspire 5610z
Thanks and regards,
Anil.B.R
Jan 27, 2010 | Acer Aspire 5610-4648 Notebook
Samsung CLP 300 Error #12288 Unable to create tempfile
I suggest you download the latest version of the print drivers, uninstall the old ones first. Also, check to see if your program has any updates. Does it do it on other programs as well?
If so, there is a driver issue not properly talking to Vista.
If it works on other programsl, its related to the program itself.
thanks adi
Dec 12, 2009 | Samsung CLP-300N Laser Printer
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
LAMP FAILURES
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
Outlook calendar sync error: 03-0058
Did you get a solution to this? I'm in exactly the same situation and nothing is fixing it.
Sep 11, 2005 | Palm Treo 650 Handheld
PTC Mathcad® 14 for PC  Logo
427 people viewed this question
Top PTC Computers & Internet Experts
David Payne
David Payne
Are you a PTC Computer and Internet Expert? Answer questions, earn points and help others
