Question about HP Vs17 17" LCD Flat Panel Monitor
My HP F2105 21" LCD MONITOR shows only that VGA connection is good and then goes into sleep mode
  • Josef Liebel Sep 11, 2010
    I have tried a different monitor and the video card works
  • HP Master
  • 6,487 Answers
Base from the description of your problem this can be cause by two different reasons.
First the video card of your computer is not properly working and what you can do for that is to open the computer tower and then unplug and replug the video card from the motherboard and then after doing that connect the monitor back and check if its already working.
Second the monitor itself is bad and needs some repair , to check that try using a different monitor with your computer tower to identify the real problem.
Posted on Sep 11, 2010
  • Mark Gil
    Mark Gil Sep 11, 2010
    If a different monitor work with that computer so the main problem here is the monitor itself is bad and there's a big possibility that some Capacitor are busted or burned inside the monitor and needs to be replace .
I have a hp 2009m monitor and i want to connect it to an emachines t6212
Verify you have connected the VGA cable to the VGA output of the computer.
Feb 05, 2013 | HP 2009M Monitor
How to fix my monitor when its in sleep mode
I assume this is a Desktop computer:
The Monitor receives, graphics or text from the PC (personal computer) and displays it on the screen.of the Monitor.
If you see a message on the screen that says * NO SIGNAL * in most cases the Monitor is good, and the Monitor is either not connected to the PC or there is a problem with the PC Check the connections and the video card.
The problem could also be related a failure of the motherboard, memory or the processor
Let us know..
Nour Sabre
www.aaatvservice.com
May 21, 2012 | HP W2007 LCD Monitor
HP W2007 + Xbox 360 = Constant Sleep Mode
the monitor is bad
if it will not power on,
or show NOSIG< with XBOX on then turned off the monitor must show NOSIG>
why not test the monitor on any pc made even laptops VGA jacks works, so that works, its not the monitor.
and bad xbox video caused. but is not it. as you said.
the menu needs sync lines active. to pops the OSD button menu.
so the monitor is bad.
or the cable.
what is w2007, lets see.?
its old. at 1680 x 1050 @ 60 Hz
this old monitor runs CCFL lamps.]
im shocked it glows at all up to now.
ever do flash light trick test?
see got data, but no back light, CFFL is dead.
HP W2007
users guide last page.
This HP product contains mercury in the fluorescent lamp
in the display LCD that might
require special handling at
end-of-life:
that means CCFL died, also all do, soon.
(as short as 2 years, full time , they die. 20k hours)
out of your service manual it shows.
ccfl-wcj1avqu0msqxnqr1cdquwfl-1-0.jpg what any running pc connected the OSD menu most work
not in sleep mode.
if there is sinc, H/V pins active
that OSD must work or the blacklamp is dead
use flashlight see, there is data there, see?
Sep 09, 2017 | HP W2007 LCD Monitor
HP monitor going into sleep mode right after turning it on
If it goes in to sleep mode, that means that the monitor is not getting a signal from the computer.
The things to try (from simplest to most complex) are:
  1. Make sure the computer is on and not in "sleep" mode -- press the "Caps Lock" key and see if it lights up the caps-lock light on the keyboard.
  2. Make sure the video cable is connected from the computer to the monitor (that the cable hasn't come loose on either end)
  3. If your monitor has multiple inputs, make sure it's set to the right (probably analog VGA or DVI) input
  4. If your computer has more than one video output (like a laptop with it's internal screen plus the external monitor) then make sure the external monitor is enabled
If none of those solve it, post a comment back here and we can dive in to the more complex tests
Sep 06, 2010 | HP w1907 LCD Monitor
Monitor wont come out of sleep mode
I'm guessing you are using a the VGA input of this monitor (the smaller "D" shaped connector with 15 pins) on the back. If not, and you are using the DVI input (larger white connector), then check your PC video output. I've seen this occur with HP monitors when they accidentally get set to "digital" input. Its easy to set that way (even by mistake), but not as easy to reset to analog (VGA). To do that, you'll need to find someone with a DVI output on their video card. Once you connect to a DVI source, the monitir will come on and stay on. You then need to go into the menues of the monitor, find the setting and change it back to "analog". After you do of course, you won't get an image on your monitor until you reconnect to an "analog" (VGA) source.
Jun 02, 2010 | HP w1907 LCD Monitor
My monitor goes to sleep and doesn't come back on.
For that when you power up the computer press F8 key then enter in enable vga mode .
Then go to display property and set screen resolution to 1024*768 then apply and ok.
if still not work then try safe mode then uninstall graphic driver and reinstall.
When you power up the computer press F8 key untill you see windows logo.
Let me know if you need further assistance.
Thanks for using Fixya.
Feb 07, 2010 | HP w1907 LCD Monitor
Compaq Presario stuck in sleep mode
Connect the monitor to some other computer, e.g., a notebook, and see if it does the same thing. If it does, then the monitor is the problem.
If it does not, then your computer is not putting-out any "video" signal, and so the monitor goes to "sleep".
If you have MORE than one VGA-output port on your computer, connect your monitor to the "other" VGA port.
Or, press-and-hold the ON/OFF button on your computer, to force it to completely shutdown.
Jan 13, 2010 | HP Pavilion a1710n (RK573AA#ABA) PC...
Went into sleep mode and will not awake, gives message of not being able ti find vga source, but all connections are good and secure, then returns to sleep mode
Sounds like there could be a short in your video cable. I had this problem occur where i would boot up my pc and after about 5 seconds the screen would go blank. Also give your monitor a reset manually after starting up your box. Just unplug the power cable to it for about 10 secs and see if that helps. Good Luck
Dec 09, 2009 | HP vs17c 17" LCD Monitor
HP w2007 LCD monitor goes off Monitor going to
Make sure that everything is connected to the monitor properly. Go to the back of it and make sure the VGA or DVI cables are secured and then check the back of the computer to do the same.
Sep 16, 2009 | HP W2007 Desktop Monitor
HP Vs17 17" LCD Flat Panel Monitor Logo
195 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
