Question about Dell Inspiron 1300 Notebook
My laptop keeps shutting down and restarting. It won't stay open long enough to access any programs. How can I fix this?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 100 Answers
1. Scan for any virus present using norton bootable cd. If it restarts even while booting through CD. Then its sure a hardware problem.
You have to give it to a service technician to clear all the dust and replace heatsink compound on the processor.
Posted on Sep 11, 2010
Door won t stay closed
The door catch is down or has lost a spring inside the hook
No simple fix but too replace door latch inside
In order to drive car with door that way no back seat passengers till fixed but use tie down ratchet straps from door to door inside handles
This will keep door shut then can drive vehicle normal till door catch is fixed its simple hour job to replace just buy parts have mechanic shop install
Sep 08, 2014 | 2000 Toyota Camry
Hpw to reset macbook pro
  1. Turn off your Mac (if it isn't already off).
  2. Hold down these four keys right after you press the power button: command+option+P+R (that will reset the PRAM).
  3. Keep holding down those four buttons until your Mac restarts and you hear the second startup chime.
May 28, 2014 | Computers & Internet
Dell xps 14z won't turn off
i don't think you're giving it enough time to actually shut down.
May 18, 2012 | Dell Computers & Internet
My computer came up with a blue screen that said system error said something about a physical memory dump and that it is shutting down the computer to keep me from losing my files, that was all I got from...
Not necessarily. This usually means an error somewhere in the critical operating system files. whether this is software problem or hardware remains to be seen.
Assuming that you will, sadly; not be able to access the operating system again, you can still access the files and get a back up using a hard drive adapter: http://www.coolmaxusa.com./productDetails.asp?item=CD-350-COMBO&details=overview&subcategory=converter&category=converter
This does involve having another pc to load the files onto. Once the data is backed up a format will indicate if its a hardware issue but hopefully the format will manage any bad sectors. Once the format is complete the hard drive can be placed back in the laptop and an OS can be reloaded.
This all is if you wish to backup, you can just load in an OS cd/recovery disk and let it format the drive and just Install rewriting over any data and formatting around any potential bad sectors on the drive.
Feb 04, 2011 | HP Pavilion dv9000z Notebook
My computer keeps shutting down for no apparent reason... I hasve a toshiba satellite p10...
Possible causes of the problem:
System overheating
- Virus infection
- Power supply malfunctioning
Solutions:
- Check your computer if the fan is properly working.
- Scan your computer for viruses
- Check your computer power supply by a qualified technician
- Reinstall your computer operating system
Try this also:
From the run box you can type shutdown -a and that should stop it from shutting down long enough for you to fix the problem.You need to look up how to remove msblast from your computer.
Nov 17, 2009 | Toshiba Satellite P105-S921 Notebook
How do I reboot vista laptop in order to remove radial point
a reboot is always a last resort!!! a better option to remove a program is to access control manager by pressing ctrl, atl, delete at the same time. when the prompt window is opened look through both processes and services tabs for anything related to the program hit stop process then just go to start>control panel>add/remove program. if that doesnt work restart your computer in safe-mode. if its a vista hit the power button let it rest for a sec then restart it. since the computer was improperly shut down it will ask if you want to start windows normally. don't instead choose start in safe-mode when it starts everything related to radial point will be shut down making it easy to remove the program through control panel. if you still whish to reboot shut down your computer by opening the start menu and in the lower right corner select restart. when the comp. restarts and the logo appears hit f8 quickly (you only have about 5 seconds before it restarts normally) choose boot with disk insert your start up disk and the computer will restart and all non-default programs will be lost. radial point will finally be defeated but at what cause? at what cause!!!??
Nov 14, 2009 | Microsoft Windows Vista Ultimate Edition
Hp will keeps restarting durring initail start up
while computer is starting don't just press F8, u have press and depress it as fast as possible on and off on and off. This will let u go into safe mode, remember if u added a program or hardware or software before this problem happened and if u did try removing the program if might have a conflict with the operating system. Or do a last good known configuration. If this doesn't help try this starting the computer with the mouse disconnected or the keyboard or the printer or speaker or if u just added a card remove it. This things might help.
Jul 26, 2009 | HP Pavilion dv6000t Notebook
E500 won't shut down
It is probably not shutting down because there is a program running that will not shut down. Unnstall programs you no longer use and do a virus scan, often the programs that refuse to shut down are malicious. Holding down the power button for 5 seconds should shut down the computer (it signals the motherboard to power down). As for the black screen, not enough detail for me to say.
Jan 02, 2009 | Compaq Armada E500 Notebook
Blank screen
the power is supposed to stay on when that little plastic button is pressed(screen switch)the screen switch activates hibernate and power saving;if you press the power button a screen will open informing you what programs are currently working.by shutting down you have caused an illegal command.
hopefully if you restart in safemode then shut down correctly and restart every thing should be ok.
Mar 03, 2008 | Dell Inspiron 700M Notebook
Dell Inspiron 1300 Notebook Logo
80 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
