Question about GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel
I have a GE Profile side by side, model #PSC23SGPA that is roughly 6 years old. The freezer and fridge suddenly quick cooling yesterday. The system seems to be running normally - ie controls, fans motors. I need help troubleshooting the problem. From what I have read it could be any number of things - bad compressor, leak in the sealed system charge, control board problem, ect. Can you help me determine what the problem is?
  • able_fam Sep 11, 2010
    Would dirty evaporator coils cause a sudden change in the cooling system - the electronic tempature control for the fridge went from 37 to 72 degrees in less than 24 hours. Freeezer went from 0 to around 72 degrees as well? How can I tell if the compressor is running properly - I can hear the system running but don't know how to tell whether it is the compressor or the condensor? Thanks
  • 10,515 Answers
You could read the below guide :-
http://www.fixya.com/support/r3886637-refrigerator_not_cooling_enough_or_not
This is a simple DIY guide. If problem still persists, then we need to go for advance troubleshooting that would be quite a tough job and usually i personally prefer a tech to take take from that point. However, if you wish i could also guide you further .But, you need to take all the precautions .
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Sep 11, 2010
  • taran_2005
    taran_2005 Sep 11, 2010
    Thanks for your response!!
    Dirty Coils could cause less or no cooling.So, they could cause this problem.If you have experience in repairing appliances, could take all
    precautions necessary and use multimeter - You could do a continuity
    check on compressor motor and all combination's. An infinity value on
    multimeter would confirm bad compressor.
    On the side of the compressor you will see a box
    (maybe a cover) remove the cover if it has one and then remove the wire
    harness. next you will see the relay with the capacitor mounted to it.
    give the relay a tug and pull it off the side of the compressor. once
    you have it off pull the capacitor off and then give the relay a shake.
    If it rattles the relay is bad. if the relay does not rattle the
    compressor is bad and you will need to call a service guy to replace the
    compressor.
    Other option would be - Go to a local repair shop
    and get an overload and relay ( cost around $50 ).Replace it.
    Hope i helped you.
What problems exist with GE model pscs5rgxafss
I have a GE Profile Side by Side Model PSCS5RGXAFSSThe lights work but it does not cool (or work) in the Fridge side or the Freezer side. The front door panel numbers illuminate but, will not control any setting. What's wrong? The unit is 4 years old.
Sep 04, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Have GE profile refrigerator. It is 3 years old.
OK check the Thermistor, the actual temperature sensor element, and or thermostat if it uses a separate feed.
Sep 10, 2011 | GE Refrigerators
Freezer works but frigde isn't working
once ice forms on the freezer coils there is no air flow. I had the same thing. I suspect your defrost cycle is compromised. Could be the bimetal switch, defrost timer or defrost heater element.
Nov 25, 2017 | Pds GE Profile Bottom-Freezer Drawer...
Not getting any water out of the dispenser, but its making ice
The water dispenser on my GE profile fridge stopped working for a couple days. The refrigerator and freezer temperatures have fluctuated over the past several months causing fridge items to periodically freeze and freezer items to periodically thaw. GE tech came today identified a bad circuit board, which he replaced for a cool $300. Ouch. Fridge is only three years old. Oh yeah, the icemaker also has a broken tab which causes it to jam every couple weeks. We have GE Profile appliances throughout our kitchen and they all work great except for the fridge :-( I hope GE engineers read this post. If so, get to work! LOL
Feb 03, 2010 | GE Profile PSW26P Stainless Steel Side by...
PTS25 Top Freezer Model- Fridge & Freezer won't cool
If the compressor is still good your hard start relay might be bad.
Aug 05, 2009 | GE Profile Arctica Stainless Steel Top...
GE Profile refrig side by side Model GSS 20iEMCC, not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
df
Dec 26, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer isn't freezing all of a sudden but frig. side is still cold
There is a cheap repair manual for this model listed on eBay. The item number is 200262539606.
Premmy
Oct 14, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge and Freezer running, but not getting cold.
make sure your fans are working. one is in freezer section,the other at back by your compressor.
Jan 06, 2008 | GE 16.7 cu. ft. / 473 liter Upright...
GE Profile 23.3 Cu. Ft. Counter-Depth Side-by-Side Refrigerator - Stainless-Steel Logo
439 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
