Question about Dishwashers
Fisher & Paykel FP8185 - Dishwashers
  • 784 Answers
SOURCE: F1 Error on Fisher & Paykel Nautilus
It leaked before leading to this.
1- Unplug the power.
2- Dry out the leak.
3- Before taking off the lid seal, check if Lid actuator working by going to diagnostic mode. 4- Select LD.
5-Pull the drawer half way out so you can see the lid going down or not when you turn on by pressing lock button.
6- Press the lock button again to release the Lid.
7- Most the time it is a Lid actuator problem and your seal look good, then you replace the Lid actuator only.
8- If it is a problem with the Lid actuator and your seal look bad then replace all .
Posted on Jul 03, 2009
  • 677 Answers
SOURCE: Fisher & Paykel leaves film
the problem is hard water. www.dishwasherfilter.com has a new product out that solves this problem once and for all. it filters the water going into the dishwasher removing the hard minerals that leave those spots. it is very affordable and guaranteed to work or your money back. you will love the way your dishes look.
Posted on Aug 22, 2009
  • 784 Answers
SOURCE: My Fisher & Paykel DD 603 has the fault code
Check at bottom housing both top and bottom drawers for leaks.
Pull the tube out, on the left side below the tub you can access to touch the bottom housing. Dry it out with a tower. Un plug the power cord at least 24 hor so the flood sensor can be dried out before pluggin it back.
However, if you don't fix this leak, the sam F1 problem will happen again.
There is not much clogging up in filter. If you expect something clogged up, you have to take the spraying arm off then take out the bottom stainless steel with a lot of holes out to see the impeller clean or not. Good luck.
Posted on Sep 12, 2009
  • 3247 Answers
SOURCE: The flood switch has been activated on our Fisher
Turn off the main power to the dishwasher.
I am assuming you are getting F1 error code flashing (if your drawers have LCD display) or the LEDs are flashing if you have intergrated drawers.
The flood switch is located at the base of the drawer tub. You will have to either extend the drawers out fully or take them out depending on the amount of water that would have collected at the base of the tubs. Get some towels and dry the base out. You may also need a hair dryer.
Once the flood switch dries off the drawer should work ok when you turn back the power.
The causes of the flood switch trriggering is either too much foam in detergent (use recommended detergent) or leak in water in or drain pipe.
Please remember to rate the solution if it helps or post a comment if not.
Posted on Jun 12, 2010
  • 251 Answers
SOURCE: How to reset the flood switch on a fisher & paykel
Hi - unfortunately my good friend it cannot be reset as one would like quite easily anyhow... water has found its way to the base of the drwaers and have activated the flooding switch - one could pull it apart to dry it - tip the water out from the base but if the leaks not repaired you will have the same problem later and will be on-going.
5 Fault Codes
Fault Code LED Display Fault Possible Causes
F1 ----#
The flood switch has been activated.
A leak has occurred in the base of the dishwasher.
Cause
 The fill valve has failed open.
 The flood switch is faulty.
 Excessive water has been added to a wash sub cycle, indicating leaking seal or siphoning.
hope this is useful tp you - let me know if you require further asspstance...
Posted on Jul 17, 2011
Why does it leak, even when machine is not running?
Small leak/drip with Fisher & Paykel GWL11 Washer (with ...
ths.gardenweb.com > Home Forums > Laundry Room
May 6, 2008 - Got a small drip/leak with my GWL11 washer..... The washer is ...Small leak/drip with Fisher & Paykel GWL11 Washer (with pictures) ..... New project for a new year: Light a fire under plans for an outdoor oven and claim the best pizza in town ... Speed Queen Front Load AFN50 Washer Review - Long Post.
Fisher and Paykel GWL11 Top Loading Washer
Mar 5, 2008 - My GWL11 Top loading washer has had nothing but problems! ... I have a Fisher Paykel GWL11 that I purchased new and have loved until this problem started. ... The machine fills with a small amount of water to saturate the clothes ...... Fault 36 is related to water leaking, but is *not* the kind of leaking from ...
Fisher and Paykel GWL11 Top Load Washer - faqqq
www.faqqq.com/.../fisher-paykel-gwl11-washer-leaking-and-squealing-fish...
Question Product: Fisher and Paykel GWL11 Top Load Washer Question Details:Fisher Paykel ... Small leak/drip with Fisher & Paykel GWL11 Washer (with .
Dec 12, 2015 | Fisher and Paykel GWL11 Top Load Washer
Fisher paykel washing machine fuse smartdrive
All Fisher & Paykel top load washers have 4Amp fuse for 240vac.
Apr 05, 2014 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel gw612 washer constantly trying to drain
The pump triacc in the motor control board needs to be replaced
by a technician, it's cheaper than getting a new board.
Apr 22, 2013 | Fisher and Paykel Fisher & Paykel Washer
MW512 Fisher & Paykel Washer Machine...Where is the lint filter located?
Fisher & Paykel machines don't have a lint filter.
Manual cleaning of agitator and s/steel bowl will make your washing cleaner.
Oct 12, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel 7.5 kg excellence smart drive doesn't spin
Check the out of balance switch (under the larger Grey board)
for corrosion on the terminals and replace if faulty.
Jul 03, 2012 | Fisher and Paykel Washing Machines
My fisher & paykel washer will not move to rinse cycle
Fisher & Paykel GW712 AU 93200-A STOPS @ THE RINSE CYCLE & THE SPIN CYCLE?
Oct 12, 2011 | Fisher and Paykel IWL12 Top Load Washer
Our Fisher & Paykel Intuitive Q came up with an Error Code 51, Stopped and an Alarm came on.
Hi, this is an update on what I found out about the E51 error code from Fisher & Paykel. This code is an error with the internal memory as one of the previous poster's said. Fisher & Paykel Rep said though it wont hurt the function of the machine it should still be replaced because it may effect the compliance information.
Nov 15, 2010 | Fisher and Paykel (IWL12)
Fisher Paykel Intuitive Eco Washer - IWL15: what is error code 136 on a fisher & paykel IW...
fault code 136 is a hard one possible causes are faulty rotor speed sensor on motor,siezed bearings or rotor,motor windings ,or motor control module, would suggest you get a tech for this one to diagonse correctty ,without proper tools to test eg: rss tester you could cot yourself more money... hope this was some help....:)
May 18, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & paykel refrigerator n325t freezing up
how long it takes to form the ice in a frost free (fisher & Paykle) refregerator ?
Feb 25, 2010 | Fisher Refrigerators
Fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Nov 12, 2008 | Fisher and Paykel AeroTech - OS302M...
Dishwashers Logo
35 people viewed this question
Top Dishwashers Experts
Owen Barnes
