Question about RIM BlackBerry 8700g Smartphone
Jvm 102 my blackberry 8900 - RIM BlackBerry 8700g Smartphone
    Problem Solver:
  • 13 Answers
Here is a temporary solution if you don't want to return your defective BlackBerry and loose all your informations:
JVM 102 error means that a .cod file on your BlackBerry seems to be corrupt. By doing the following steps, you will have a chance to backup your BlackBerry and re-install the OS.
1. Download and install JL_Cmder. You can find it on the web by Google it, or you can go to this web page: http://www.blackberryfreaks.com/JL_Cmder.html
2. Connect your BlackBerry to your PC.
3. Start JL_Cmder and select the option 2 (Event log).
4. Scroll down to the bottom of the log and look for "JVM Error 102." The line before it, should tell you exactly what file is causing the error. Save the file name; you will need it later.
5. Go to Start / Run, and type "CMD" and press Enter.
6. Change directory to the JL_Cmder installation folder.e.g., type: cd "C:\Program Files\JL_Cmder\" and press enter.
7. Type the following command to remove the corrupted file:javaloader.exe -u erase -f FILENAME where FILENAME is the name of the corrupted .cod file.
8. Disconnect your BlackBerry from your PC and restart it.
9. Now you should be able to start BlackBerry Desktop Manager and take a backup of your device. (Optional).
10. Reactive your BlackBerry
11. Restore your backup from BlackBerry Desktop Manager. (Optional).
Regards,
BES Tech
Posted on Nov 11, 2010
Hi I haven't used my phone for a couple of years. when I switch it on now it say.. error 102 reload software... what do I do?
You need to do a Factory Reset, AKA a Hard Reset. This removes everything on the phone and reloads the operating system. Your phone is a Blackberry?
  • Error 102 Reload Software - BlackBerry Support Community ... https://supportforums.blackberry.com/t5/BlackBerry-Device-software/... Hello, I've just had a problem with my Blackberry 9930 phone. I already tried updating the Blackberry Desktop Software and I also tried the phone,
  • Error 102 - Reload Software - Blackberry Torch 981 ... https://supportforums.blackberry.com/t5/BlackBerry-OS-Smartphones/... Hi. I took the battery out of my phone and when the phone re-booted I now can only see a white screen with the error 102 and states reload software.
  • How to Reload Blackberry Mobile Software - Snapguide snapguide.com > Technology > Explore
    • 3.5/5
    • 10 RATINGS
    • BY TAHANI ALGHAREEB
    i will teach you how to reload your blackberry soft ware when its got error 102 and not working by this steps. all you ... How to Reload Blackberry Mobile Software
  • JVM Error 102 on your BlackBerry? Try this solution BEFORE ... crackberry.com > ... > Classic > Z30 > Z10 > Q10 > Leap > OS 10.3.2 Video embedded · JVM Error 102 on your BlackBerry? Try this solution ... JVM Error 102 on your BlackBerry? Try this solution BEFORE wiping! ... "Error 102. Reload Software ...
  • Terpecahkan: Curve 9360 Error 102 (Reload software ... forumdukungan.blackberry.com/...Error-102-Reload-software/td-p/258111 Terpecahkan: Dear all, Saya newbie disini, BB saya curve 9360, sudah mati 5 hari dengan error 102 (reload software). Sudah coba ikut instruksi dari
  • How to fix an error 102 reload software blackberry torch ... www.askmefast.com > ... > Error How to fix an error 102 reload software blackberry torch 9810? ... How can I fix reload error 102 on blackberry torch 9810? Comment. Reply. Report.
  • ERROR 102 www.blackberryos.com/general-blackberry-issues/38452-error-102-a.html
    • 2 POSTS
    • FIRST POST: 2013-08-12
    2013-08-12 · how do i reload software on a bb 9360?? ... Join Date Dec 2010 Location Gainesville, FL PIN Jarmeling Device Passport OS 10.3.2.2134
  • May 20, 2016 | Cell Phones
    Jvr error 102
    If you get "JVM Error 102" when starting your Blackberry, read this before you wipe everything!!
    I had spent hours searching for a solution to this problem (I even went to my service provider) and all I could find was that I would have to wipe the contents of my phone and start all over again -- tough luck if I didn't have backups for my contacts, appointments, program data, etc.
    What it comes down to is that the JVM 102 error means that a .cod file on your phone seems to be corrupt, so the phone refuses to load it. Why wipe everything for one bad file? You might not need to!
    Follow these steps:
    Download JL_Cmder
    Connect your phone to your PC using the USB cable that came with it.
    Run JL_Cmder and select option 2 (event log)
    Scroll to the bottom of the log and look for "JVM Error 102." The line before it should tell you exactly what file is causing the error. It might look something like this. Save the file name; you will need it later.
    Go to Start > Run, and type "cmd" then press Enter.
    Type the following command to remove the offending file:
    where FILENAME is the name of the .cod file.
    Disconnect your phone from your PC and restart it.
    This might not be a permanent solution, but it should at least let you boot up your Blackberry so that you can back up all your data before reinstalling everything.
    jed neal
    Sep 24, 2012 | RIM Blackberry Curve 8900 Smartphone
    I have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    i have a blackberry 8330 when i put on the phone . theres a white screen that says jvm error 102 reset
    Dec 27, 2010 | RIM BlackBerry? Curve 8330 Cellular Phone
    I am using blackberry curve 8900. i am facing JVM ERROR 102 problem. Phone does not boots. I tried updating the software online as well. But still it doesn't work. Please help how can i resolve the same.
    With any JVM Error you are going to need to reload the operating system to your device, this process is slightly different with each carrier, so it is important to contact them during the process, first (if you have not done so already) Download and install the Blackberry Desktop Manager to your computer, once installed you will need to download and install the most up to date software from your carriers website,then follow the instructions to install the software to your phone, now unfortunatly your going to lose any information you have not backed up to your computer
    Hope This Helps!
    William
    Sep 21, 2010 | Cell Phones
    How do i solve the jvm error 102 on my blackberry storm
    Your Blackberry probably just needs a firmware restore. Here's a guide on how to restore the blackberry firmware, the website is at : Restore Blackberry 9530.
    May 15, 2010 | RIM BlackBerry Storm 9530 Smartphone
    How to reset if JVM error 102 is hown on the
    Try to replace the firmware / system software of your BlackBerry Boild 9700 to fix your initialization errors. The latest BlackBerry Bold 9700 system software is available through here.
    Jan 21, 2010 | RIM BlackBerry Bold 9700 Smartphone
    Jvm 102 error locks up my blackberry 8330. What
    this problem generally occurs when there is a software problem ......take backup of the handset using desktop manager and reload the software ...
    May 15, 2009 | RIM BlackBerry? Curve 8330 Cellular Phone
    JVM Error 102 Reset
    JVM Error 102 (death screen) is going to require that you do a complete reinstall of the BlackBerry OS. Here's a quick FIXYA for the JVM error > here
    ** If you still have issues completing this let we know and we can perhaps provide further assistance.
    Sep 25, 2008 | RIM BlackBerry 7250
    Blackberry jvm error 102
    mt blackberry has a problem. it displaysjvm error 529
    Jul 15, 2008 | RIM BlackBerry 8700g Smartphone
    RIM BlackBerry 8700g Smartphone Logo
    159 people viewed this question
    Top RIM Computers & Internet Experts
    Computer Repairing
    Computer Repairing
    Andrew Wright
    Trisha
    Trisha
    Are you a RIM Computer and Internet Expert? Answer questions, earn points and help others
