Top light with flashing orange 'raindrop'shape ....blinking
    Top Expert:
  • Office Equip... Master
  • 44,295 Answers
This indicates that the ink/toner is running/has run out and a new cartridge is needed
Posted on Aug 13, 2015
3 Suggested Answers
leroyal
  • 2120 Answers
SOURCE: orange light is flashing
Unplug the power cord for 10 seconds
Posted on Feb 06, 2009
s.kaye
  • 115 Answers
SOURCE: cannot print
This usually means there is a problem with one of your cartridges. Try changing them or even cleaning them sometimes works. If cleaning them does not work you will need a new manufacturer cartridge. Sometimes when you use refilled cartridges or ones that are knockoffs, the printer sometimes acts up. In that case you should just buy a normal cartridge and it should make the light go off. If you don't think that is the problem, check to make sure your cables are tightly connected. Shut off your printer and then restart it. Check to make sure there is nothing that is waiting to print. Although I am positive it is a cartridge problem. Try that solution. Cheers
Posted on Oct 06, 2009
What causes orange light to flash 4 times?
It is related to a badly installed or empty print cartridge: http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#1600
1600 - Orange light blinking 4 times Description:
The ink cartridge has run out.
Resolution:
  1. Lift the printer cover up.
  2. Identify the ink cartridge that has run out (the ink cartridge flashes quickly at around 1-second intervals).
  3. Replace the applicable ink cartridge and close the cover.
  4. Press the [Resume/Cancel] button on the device to continue printing.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
1660 - Orange light blinking 4 times Description:
The ink cartridge has not been installed correctly.
Resolution:
  2. Check that the red lights on the ink cartridges are all turned on.
  3. If no red light is activated on a particular cartridge, check that the cartridge is securely positioned and adjust if necessary.
  4. Also make sure that the orange protective cap has been removed from the bottom of the ink cartridge.
  5. Press the [Resume/Cancel] button on the device to continue printing.
Feb 11, 2016 | Canon PIXMA iP3500 Printer
Raindrop light is blinking and printer will not print.
???? RAINDROP do you think perhaps that means INK supply is low .
Sep 30, 2015 | HP Deskjet 5650 Workgroup Color Inkjet...
I have a belkin wireless modem router model F7D1401 v1 and a week ago it would be normal then flash orange and stop working. however now it is a constant orange with the WPS button flashing orange.
I think you have the upper light blinking and lower light solid. Is that right? The upper light blinking means that the connection to your ISP is not working. Try unplugging/replugging the Ethernet cable in the top port (probably yellow and labeled "WAN" or "DSL" or something). Check the other end of that cable. If you have another Ethernet cable, try swapping it out.
If none of that works, call your ISP to check the connection.
Apr 05, 2015 | Belkin Computers & Internet
Goodman wall unit air conditioner WMC 24-1A has a orange raindrop light displaying and is leaking wayer from the right side???
You need to make sure the condensate pump is working. Check the voltage and the float in the sump.
Jul 21, 2014 | Heating & Cooling
Flashing orange light
Cannon pixma 3500 Flashing orange light count the blinks for the error,
Mar 17, 2014 | Canon PIXMA iP3500 Printer
Hi, my panasonic tv power light flashes green, then it turns to orange flashes 7times then stops and starts again=orange and repeats itself by flashing orange 7times over and over , Again This is the power...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, [Exclude the model number] in the "Search box at the top right of the display window of the Homepage" to get gathered related posts...
Jun 23, 2017 | Panasonic PT-56LCX66 Television
Alternate green and orange lights flashing, tried to remove battery pack and left off for half hour, still problem, if i hold green button down orange light blinks 15 times which i saw in the manual to...
Hi I have a ip100 portable printer and both green and orange lights flash. Green flashes twice and the orange light flash at what seems to be a random disorder.
May 17, 2011 | Canon iP100 Portable Printer
Cannot print
Oct 05, 2009 | HP DeskJet 5550 InkJet Printer
Both lights are blinking and will not print
they call that flash codes or error codes. please count
count how many times the lights flash, here is what they mean
Alarm / Power light flashes orange 7 times consecutively (ink cartridge installed incorrectly)
Alarm / Power light flashes orange 5 times consecutively (Print Head Error)
Alarm / Power light flashes orange 4 times consecutively (Out of Ink Error)
Alarm / Power light flashes orange 3 times consecutively (Paper Jam Error / Cover Error)
Alarm / Power light flashes orange 2 times consecutively (Load Paper / Paper Feed Error)
Alarm / Power light flashes orange 16 times consecutively (This FINE Cartridge has previously been used)
Alarm / Power light flashes orange 15 times consecutively (FINE cartridge not recognized)
Sep 20, 2009 | Canon Pixma iP2600 Photo InkJet Printer
Pixma IP4000 12 flashing lights error 6A00
IP4000 12 flashing lights error 6A00 problem, and notify you when a new solution is offered.
Dec 02, 2007 | Canon PIXMA iP4000 InkJet Photo Printer
66 people viewed this question
jasbo
jasbo
