I have a blueware.exe file on my iphone that i cannot open help please
  • 19,396 Answers
Hi.
Blueware.exe cannot run or be installed on the phone, as this is a computer file. The file is probably the Blueware installer for the computer side. Blueware is a phone spy software comprising a computer setup and a phone setup. The phone setup file is blueware.jar.
Posted on Sep 11, 2010
Iphone error code 0xE8000084'.
Please try the steps provided below to fix this type of problem.
  1. First Close the iTunes application if it is opened already?
  2. Open the task manager and select the option "Show process from all users" and search for the Apple process and kill all with it's name.
  3. Now Navigate to the Apple folder from C:\Program Files\Common Files\Apple and go to the Support -> AppleMobileDeviceHelper.exe and just select OK which does some clearing up process.
  4. Now open the iTunes again and try to sync your iPad3 in it which should work fine without any issues.
Check this video also for reference.
Dec 21, 2012 | Apple iPhone4 4G iPhone 4
I download multi yahoo messenger it doesnt work,it says its zip,how to open and use it ,if you can gave me a simple loading?
You would open the .zip file and in that file there should be a file with the extension .exe. Double click that and the files should extract and install.
Hope this helps.
May 14, 2011 | Yahoo
So is it possible to use bluware on a iphone 3gs??
Blueware needs java. Unfortunately, the iphone does not support java, therefore the answer is no.
Nov 17, 2010 | iPhone Apps
I have photos on my 3g apple iphone I want to share on my laptop how do I download them from my phone to my laptop????
here is a smart way to help you,
Download SetupiPhoneBrowser.1.7.exe
for windows xp
http://code.google.com/p/iphonebrowser/downloads/list
for mac:
http://www.downloadoldversion.com/iphone-explorer-for-mac.html
Run the installer on your Windows XP (May not work well on Vista).
Upgrade your iTunes to 7.7.1 (it works on iTunes 7.7 as well).
Open the iPhoneBrowser and connect your iPhone to the computer via the USB cable. The iPhoneBrowser should detect the iPhone and show the file structure on its screen.You can now drag and drop files to the iPhone.
Please do rate the solution if the issue is resolved or post a comment for further assistance.
thank you for using fixya have a nice day:-)
Jul 25, 2010 | Apple iPhone 3G
How do i set up blueware.exe an application for my cell phone
I am sorry that you need such an application.
However, here is a list of currently supported phones:
http://store.bigdaddyspy.com/ProductDetails.asp?ProductCode=BDSBLUE&Show=ExtInfo
If you phone is on the list have some possible solutions. First, install the BlackBerry software on your PC and connect your BlackBerry using the USB cable. Then try running the EXE on your PC. It should detect the connected BlackBerry and install it on the device. Otherwise, the BB software should allow you to copy the EXE to the device and so you can run it on the device.
Otherwise, contact the company that makes the software for more assistance.
Mar 28, 2010 | Computers & Internet
How do i install blueware cell phone spy pro 2010 on my apple iphone need step by step directions
First, you need to jailbreak your iPhone, and then you can install the software step by step with the guide.
How to install iPhone Spy
Feb 13, 2010 | AT&T Cell Phones
Nokia 6100 contact service solution please
This tutorial will show you how to upgrade your iPhone 4 to iOS 4.3.1 without upgrading its baseband using TinyUmbrella for Windows.
Currently there is an issue with older basebands such as 1.59.00 and FW 4.3.1. Until ultrasn0w is updated, you will only see one bar under signal strength.
Please Note: This ONLY Works with the iPhone 4!
Step One
Download TinyUmbrella from here Also make sure to download the iPhone 4 iOS 4.3.1 which you can find here.
Step Two
Double click the downloaded TinyUmbrella.exe file.
If you get a Windows Firewall notification, check both boxes and click Allow Access.
Step Three
Make sure the device is connected, and Umbrella has detected the type of device and its firmware.
**If you haven't already saved your iOS 4.3.1 SHSH blobs then click Save SHSH. Make sure they successfully save before continuing.
Step Four
Hit Start TSS Server and make sure you receive no errors.
Once The TSS Server is "running" successfully, umbrella will kill iTunes. Leave TinyUmbrella Open. You can double check to see if the TSS server is running under the Log tab.
If you do receive an error, DO NOT continue. Your restore will not work if the TSS server cannot be started.
Step Five
Open iTunes by doubling clicking its icon.
Hold down the Shift key and click Restore
Select your iPhone 4.3.1 firmware file from the popup window that appears and click Open.
Click Restore to begin restoring your device.
Step Six
iTunes should give you error 1013. This is what we wanted, as it notes the baseband has not updated :) Click Ok and close iTunes.
If you get a 16XX error then try entering DFU and go to step 5.
If your restore does NOT end in a 1013, it means your baseband was updated. This is likely because you did not have the TSS server running OR you updated without TinyUmbrella OR you are working with a device OTHER than iPhone 4.
Step Seven
Place your iPhone into DFU mode by holding down both the Power and Home buttons for ten seconds, then release the Power button and continue holding the Home button for another 5 seconds. You can find help with DFU mode here.
Step Eight
Fix Recovery in TinyUmbrella is currently not working. Download this standalone .exe file to fix recovery on 4.3.1. Extract the file and double click on fixrecovery43.exe. A command prompt will open, and the program will go through the process. During this time, you will notice scrolling text on your iPhone 4.
Step Nine
Your iPhone will now be on 4.3.1 with the 1.59.00 baseband! (Which means you can now unlock using this tutorial)
**Thanks to semaphore for his work on this tool
Nov 18, 2009 | Nokia 6100
Computers & Internet Logo
209 people viewed this question
David Payne
David Payne
