Question about Juicers
The shaft on my sharper image juicer is unstable as it wobbles when in use. I would like to know how to reair it or where to take it for repairs. I live in dallas, texas.
  • Juicers Master
  • 17,130 Answers
You will need the help of a tool shop to get the bush of the shaft replaced. You must locate one of these machine shops around where the shaft can be set back with a new fitting bush so that there is no wobbling.this will solve the issue.
Posted on Sep 11, 2010
Sharper Image Juicer locking bar won't engage.
micro switch lever might be broken might want to post on youtube.com check video's
Mar 11, 2014 | Juicers
Hi, while operating this juicer, the plastic piece from the top cover has broken off, is there a replacement part for the top cover for this juicer available?
I would contact Macy's customer service for an answer to this question. It is not a model that has a retail parts division. Macy's should be able to provide a solution for you as they still carry these units. Otherwise, you may wish to purchase a new one from them and return your old one to them in the box you receive. It will end up costing you shipping, if you do not have one near you, but right now they are only $79.99. Model 8021
May 25, 2011 | Sharper Image 8021 700 Watts Juicer
I just want to know how to take it apart to clean it and everything that comes a part.
Go to this website:
http://www.powerjuicer.com/power-juicer-manuals.php
Click on the image of your machine to download the Owner's Manual.
You will find Assembly, Disassembly and Cleaning Instructions, etc..
Mar 06, 2011 | Jack Lalanne Power Juicer 250 Watts
I cannot remove the blades from the shaft. This juicer has been in storage with all the attachments in place. I was able to pry it out about an inch or so but can't get it any further. Is it safe to use...
Do not use WD40. Wear heavy leather work gloves. Lightly tap two flathead screwdrivers positioned opposite each other to initially pry the blade apart from the main body of the juicer. Alternate tapping on the screwdrivers until some of the shaft is exposed. Tilt the juicer towards the blade and drizzle olive oil on to the exposed shaft. Every few hours return juicer to stable upright position and use a hammer to lightly tap a screwdriver positioned at an angle that will not gouge the shaft. Rotate blade manually and tap in different positions. Keep juicer tilted towards blade in between tapping attempts to allow oil to penetrate shaft opening. Continue drizzling olive oil on shaft as it is exposed. Cutter may need replacement after this procedure. Use steel wool to thoroughly clean shaft. Soak Cutter blade in hot soapy water for two days.
Sep 30, 2010 | Champion G5NG853S Household Juice...
My juicer spins off of its axis i think, wobbles all over, spinning itself in circles spewing juice everywhere
Omega and Acme juicers will vibrate because pulp
is not ejected during juicing. Only suggestion I can
offer is avoid soft produce and feed as slowly and
as evenly as possible. Been using an Acme for 21
years and did notice a duller worn blade does produce
less vibration.
May 23, 2010 | Omega 1000 Juice Extractor
MP-80 240 Watts Juicer: where do i go to find a larger image of this parti...
Larger image as in an image of all of the parts, or just a photograph?
I have access the the Ownes Manual if required.
May 18, 2010 | Braun MP-80 240 Watts Juicer
Does not turn on, all parts seem to be seated correctly. I think it is a safety interlock, but I do not know what to do to make it work. This is a Sharper Image Super Juicer
i also have the same problem....sometimes it does work....same problem with my other previous juicer called juiceman junior
Jan 01, 2010 | Juicers
Given a kenwood je500 juicer
email me at ewingelectrical@optusnet.com.au I have a PDF file that may help.
Apr 28, 2009 | Kenwood Juicers
Juicer does not work.
Had same problem...juicer stop working without any warning. First I took the unit apart and remove the on-off switch and capacitor and had them tested by appliance shop. Both checked good. Next I remove the small circuit board behind the face plate below the motor shaft; circuit board was coated with oil and shaft grease. Appliance shop did not know how to test it, so I clean it all up and reassemble the unit. I told God is it worked I would praise Him. Hallelujah to God ... it worked. I hope my experience helps someone. God is good.
Jul 18, 2008 | Champion 2000+ Household Juice Extractor
Juicers Logo
69 people viewed this question
Top Juicers Experts
eyecam
Tom Chichester
David Payne
David Payne
Are you a Juicer Expert? Answer questions, earn points and help others
