Question about Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw
How do you change brushes on milwaukee sawsall
  • 2,176 Answers
Depends on the model number but, if you can see a black screw on the upper and lower portion of the tool UNPLUG the TOOL and remove the screws and the brushes are underneath. If you don't find the brush caps you need to remove the handle halves and expose the rear of the motor to access the brushes. I would recommend going to Milwaukeetool.com and with your model number under service type it in to download a breakdown for this tool.
Posted on Sep 12, 2010
My milwaukee hammer drill spins when trigger is pulled but many sparks from where brushes are along with a lot of electric burnt smell.
Change the brushes. The brushes have worn into the armature. I have had the same issue and that can usually fix the issue. But if armature is too far gone, the drill may be D.O.A. and time for a new one. Christmas specials are all over the place at a lot of local places that sell tools. Get on line and shop around should you want to replace instead of repair.
Dec 05, 2017 | Milwaukee Drills
1 3/4 milwaukee hammer drill speed slows down after 3 seconds
2 possibilities...if it is battery operated the battery may be damaged or will not hold the charge so u will have to change the battery. The other is the brushes for the motor needed to change or the contact may be dirty
Oct 11, 2017 | Milwaukee Drills
I cannot find a replacement part for my Makita mod. JR3000 recipricating saw. I need a handle.
Call Makita at 1-800-462-5482 they will sell direct. Sawzall is a Milwaukee trade name so when you call say reciprocating saw. You'll also need the serial number or date code because Makita has several revisions to that tool.
Dec 27, 2012 | Saws
I need to repair a switch on a milwaukee super sawsall
before change the switch,check 120 volt wire and brush
also check for loose terminal on brush holder,sometime look ok but you can see littlebit of melted plastic at the crossing of plastic and terminal
with more then 12 years to repair tools,when i open the handle,i weld the terminal to holder to eliminate futur problem,it take 2 minutes
Nov 17, 2012 | Milwaukee Tool Saws
Cutting an opening in a steel door for a doggie door. Bought a Sawsall just for this. Any tips?
be sure to use eye protection and gloves to protect you from sharp edges.
first mark your lines on the door using a square, then drill holes large enough for the sawzall blade to fit through in all 4 corners. next use the sawzall to cut your straight lines which were alraedy marked and you now the opening you need. if necessary use a file or dremel tool to clean up and debur edges. hope this was helpful, if so please rate.
Feb 17, 2011 | Milwaukee Tool Milwaukee Super Sawzall...
Milwaukee 5616-29 when turning on, spins up then shuts off.
it sounds like the brushes on your router need to be replaced. It is best to use the milwaukee replacement brushes available from any milwaukee service center.
Oct 02, 2009 | Milwaukee Tool Milwaukee 5616 24 2 ¼ Max...
Procedure to chamnge brushes on 1/2"Milwaukee Hammerdrill 5376-1
Yes look at the brush holder you will see a tiny hole in it push the brush just past the hole insert a paper clip or wire that will allow you to get it out after you get the armature in if you need more help let me know.
Jul 11, 2009 | Milwaukee 0799-20 V28 7/16" Quick Change...
How to replace the brushes on the milwaukee cordless drill 1/2'' # 0627?
Depending on age of tool older models did not have replaceable brushes. Change motor.
Newer models are replaceable , go to a service center and get a brush kit for this model. Or online.
Open tool with # 8 torx. Do not separate motor and gear case ,chuck remove as one unit. Brushes are solder in .De solder used brushes . Replace one side at a time. These kits come with new coil tension springs .
Jul 07, 2009 | Milwaukee 0627 24 Drill Hammer 18V T...
Plugged electric sawzhall in, no power. checked cable -- ok, checked both brushes, still have about 3/8in in each of them. What should I do next? Just replaced the blade, but I do not think that has...
I would say its either in your cord(an open wire from wear) or the switch on the sawsall.
Try plugging it in and hold in the switch (dont have a blade in) move the cord around in different places to try to get it to work if thats not it and your brushes are ok its probably the switch. I ve replace bad switches in sawsalls before from wear. You can either go to your local electrical supply store that sells milwaukee and order one or I ve purchase them at Grainger parts too.
Jun 29, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee Sawsal Broken blade
Spay inside where blade fits in with PB BLASTER & let set a while. Maybe you will get lucky & the blade will fall out as it should. If not then it will have to be dissembled in this area. There are 2 BB's inside that fit into the small hole on the blade. They are forced in by a spring, be careful not to lose these. Also check the accuatator when you pull the finger release, make sure it is going all the way or it is not broken, Good luck.
Jan 21, 2009 | Milwaukee Tool Milwaukee 10 Amp...
Milwaukee 6520 21 12 Amp Orbital Sawzall Recip Saw Logo
1,019 people viewed this question
Top Milwaukee Saws Experts
Navin Sharma
Navin Sharma
john h
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Milwaukee Saw Expert? Answer questions, earn points and help others
