The door won't unlock and won't open is thier a way of overriding this problem so I can get in the machine, and is thier a solution to this problem? I would be very grateful for any help.
    Problem Solver:
  • 10 Answers
It should let you open it after a few minutes, when there is no power going to the machine. Take the plug out as well.
I hope this helps.
Posted on Sep 11, 2010
The door on LG front loader washing machine won’t unlock
hi Margaret.
If the washing machine malfunctions or you need to stop the cycle and retrieve the clothing, you can force the door to unlock.
  • Open the door after the "Door Lock" indicator turns off. ...
  • Press the "On/Off" button, if the washer is not already on.
  • Select the "Spin Speed" button to turn on the Drain & Speed cycle.
  • or go to this link and have a read up.
LG front loader washing machine wont unlock Google Search
Dec 12, 2017 | LG Washing Machines
1999 Dodge Stratus passenger side door locks won't lock
thier really is no other option.. thier are plastic clips that hold the linkage together.. it's common for those to break.. so the panel has to come off.
Jun 25, 2012 | 1999 Dodge Stratus
Neptune door lock override
You can't override the door lock It's a safety feature. You can bypass it by connecting the wires that go to the switch but please don't! It means the door can be opened while the drum is still spinring and children can be severely injured. You may also open the door accidentally with water in the tub. If you think there is a fault with the door lock, first make sure it's not just a blocked air tube, but replace it rather than try to override it.
May 15, 2012 | Washing Machines
Washer won't unlock
These doors are usually on a timer and so won't be released for opening until a couple of minutes have passed by after turning the machine off.
Assuming you've already allowed for this, try giving the door a good firm push (closing) on the mechanism. It may just have caught partially closed.
Apr 28, 2012 | LG WM2455 Front Load Washer
Bosch Nexxt 300 has error code E-13 and the door is locked. turned on/off, unplugged, removed the drain hose to see if it is blocked, but ok. but still won't unlock. Is there someway to unlock the...
Turn the dial to off position wait few second, door should unlock. Unless you try to open it during cycle, it won't open. Otherwise, follow owner manual. call the manufacture.
May 18, 2011 | Bosch Washing Machines
I cant open the door
For some reason, your door lock isn't unlocking properly. You can manually override it, but this won't fix the root problem. Here's how...
1. Unplug the machine
2. Remove the 3 screws from the back edge of the top and pull it off rearward
3. Using a flashlight, look down along the RH inside of the machine (facing the machine). About half way down, you'll see the door lock mechanism which has a manual pull that will unlock it. Pull up on this to unlock the door.
4. You could take your chances and put the machine back together, plug it in and see if the lock acts up again. If it does, you'll have to replace the door lock, if not- it's your lucky day.
Good luck.
Feb 03, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
