Question about Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S
Replacing fill valves in mansfield 160 toilet
  • 451 Answers
If this is the standard manfield 160 toilet I recommend replacing the fill valve with a Fluidmaster 400a. They are easy to install and adjust , and work very well.I have installed hundreds of these and have had zero problems. Hope this helps.
Posted on Dec 28, 2013
picatudo
  • 239 Answers
SOURCE: Toilet fills up slowly
buy a universal fill valve and replace it
Posted on Jan 03, 2009
SOURCE: Toilet Refills Every 15-Minutes
I have minute amount of leakage into the bowl causing mold to grow. I believe that it may be the rubber seal for the flapper body to the porcelain.
Posted on Jan 10, 2009
  • 6 Answers
SOURCE: Toilet will not fill up
Some Toto fill valves have a plastic debris screen located at the inlet connection. Turn off the supply valve and remove the supply connection at the bottom of the tank. Use a mirror to inspect the screen for debris.
I agree w/ Smithbrother, the Fluidmaster fill valves are cheap and work well. The only thing they ever need is an occasional seal for $1.50 and 5 minutes to replace.
Posted on Mar 14, 2009
  • 7 Answers
SOURCE: i need a tank for my toilet. it's a mansfield
buy one online it will come with instructions i bet to.
Posted on Jun 08, 2009
  • 10 Answers
SOURCE: Replaced toilet fill valve - now bowl water level a bit lower
put some water in with a bucket. poor some in slowly until you get it where you think it should have been. If it levels back out at the lower level. Then there is nothing wrong. Maybe the leaking water was keeping the bowl water line high than it should have been.
Posted on Jul 26, 2009
My mansfield 160 toilet tank will not fill after flush. I will turn the water off and then on and it will fill and then after it is flushed it will not fill.
indicates a problem rubber washer on the inlet valve
get in a plumber or get replacement rubbers form a quality hardware shop or plumber supplies
rubbers expand with age and jam over the small opening
Dec 10, 2016 | Home
I have a mansfield toilet and after flushing it keeps running, how can I fix that?
Not sure about your brand but many toilets have a flapper valve inside the tank which needs adjusting or replacing. Try this U tube link
How To Repair Mansfield Toilet
Apr 06, 2015 | Home
Mansfield 160 toilet diagram
The tank bolts do not get removed. The flush valve is mounted in a hole toward the rear of the tank. The nut under the tank is removed to allow removal of the flush valve from the inside of the tank. The replacement flush valve is inserted into the hole inside the tank and the nut is installed to fasten it in place
May 15, 2013 | Danco Flush Valve. Replacement Flush Valve...
Toilet model 386 is spraying water through the top of the water valve when tank is refilling.The water then is coming out between the lid and the tank onto the floor. email Address: milemc@yahoo.ca
there is a black hose line that goes from the flush valve to the fill valve. that black hose needs to be attached to the fill valve the one in the center. Your clip may have broken or it could of just slipped out. the hose is called the refill tube. If its broke then you will have to replace the flush valve.
Mar 14, 2011 | Summit Appliances Division Mansfield 386...
Toilet flush valve is hard to flush....too much suction. Sometimes takes two hands to push the handle.
Hi, you need new Mansfield 210/211 flush valves. They can be found on amazon.. here: Amazon com Mansfield 210 211 seal. I hope this helped you. Cheers
Jun 27, 2010 | Mansfield Plumbing Products Mansfield...
MANSFIELD TOILET KEEP LEAKING
I'm not exactly sure where the seals are that you are describing. I'm thinking that you might need to shut the water off, unbolt the toilet from the floor, and replace the big wax toilet gasket underneath.
That's the main seal for internal plumbing in the toilet, unless you're talking about the toilet leaking into itself and wasting water. In that case you might need to simply adjust the mechanism (float, flapper valve etc.) to get the right setup.
I'm not sure I completely understand your problem though.
I hope this has helped anyway.
Lyle
May 03, 2010 | Mansfield Plumbing Products MANSFIELD 3/8"...
My quantum toilet continues running after flushing and refilling.
May have to bend the float rod or adjust the set screw on the fill valve.
Feb 14, 2010 | Mansfield Plumbing Products Mansfield...
Runs all the time
TO AVOID ALL PROBLEMS INSTALL A NEW FILL VALVE FLAPPER. THERE ARE MANY UNIVERSAL KITS YOU CAN USE . TRY FLUIDMASTER
Jan 06, 2010 | Mansfield Plumbing Products Mansfield...
My Mansfield toilet has a broken float rod and it seems like a need a Mansfield made replacement kit, is that true? I can't use a standard store bought replacement kit on Mansfield toilets?
mansfeild toilets are very common Korky or Fluidmaster makes a replacement ballcock and will change out easy I wouldnt fool around trying to find parts and replace the valve they run about 15 -$20.00 and replace the flapper at the same time
Aug 23, 2009 | Home
Mansfield Plumbing Products Mansfield QUANTUM White Round Front Pressure Assist Two-piece Toilet with S Logo
558 people viewed this question
Top Mansfield Plumbing Products Home Experts
jdthefixer
john h
bobalix
Are you a Mansfield Plumbing Products Home Expert? Answer questions, earn points and help others
