The monitor will not come on immediately when we first turn the computer on. We have to play with the buttons underneath the monitor (ie. the source, menu etc. button) sometimes for fifteen minutes or more and then all of a sudden it will come on. We do not remember changing any settings and cannot figure out why this is happening. Helppppppp!!!!!! Thanks Tim
  • 17,129 Answers
This is only a coincidence that when you fiddle with the controls the monitor comes on. Just leave is aside and the monitor may come on in 15 minutes.
If so then the fault can be due to poor filtering inthe power supply, poor solder joints inthe main board or the thermally active components.
So use a good soldering iron to solder all suspected points.
Change suspected capacitors in the circuit/power supply.
Posted on Sep 11, 2010
I have a dell studio 540 desktop, I need to restore to factory settings but my monitor will not stay open. It opens for a few seconds then immediately goes into power saver mode and turns off, how can
I see two things here, but need clarification;
1) Monitor goes to Power Saver Mode, then turns -> OFF?
Sure that monitor didn't go into Standby Mode?
2) Why are you performing a restore back to factory settings?
Pick up a virus?
Primer;
The monitor receives a signal. A video signal. The video signal comes from the computer.
If the monitor is NOT receiving a video signal, then the monitor will state No Signal.
This is for older monitors.
New monitors do not state No Signal anymore.
It's Power Saver Mode, or Sleep Mode.
If the monitor is truly OFF, the Power On button will Not be lit up.
Or the Power On LED light on the monitor.
Monitor power on LED is lit, or Power On button is lit?
Monitor is not receiving a video signal;
Use a monitor cable from a KNOWN to be working monitor, for a temporary test.
OR,
Use a Known to be working monitor, and it's monitor cable.
Need to find out if monitor cable is good.
Monitor cable checks out good?
Then problem is computer.
The two leading issues with desktop computer failure, is;
1) Computer is dirty inside
2) Power Supply inside computer is bad.
Please post back in a Comment.
Regards,
joecoolvette
Mar 27, 2013 | Computers & Internet
Computer does not recognize any monitor and fan runs immediately after turning on the CPU and does not stop.
try cleaning and re-seating the RAM modules and also check all the cabels inside the cabinet are perfect ie. not loose. if this doesn't work try going to a workshop.
Jan 06, 2011 | Gateway 508GE PC Desktop
Monitor won't stay turned on. You push the on button and it flicks on and then immediately off. Help!
The possible problem of your monitor is may be cold solder, bloated elec. capacitor or defective lcd panel. If you found that bloated capacitor replace it and resolder all pins of inverter area. Defective lcd panel could cause of display flicks then immediately off.
Sep 30, 2010 | Samsung SyncMaster 203B LCD Monitor
I have a model Q7C4 when turned on it immediately turns off again even if not connected to the computer (ie power only)
Most modern monitors will not run if the signal from the computer is not present. If you can borrow another monitor, see if it will work. If ok, the problem is within your monitor. If the new one doesn't work either, then the problem is likely the video circuit in the computer--a bad video card if it's a desktop, but a bad circuit IC if it is a laptop.
Oct 08, 2009 | Computers & Internet
Hp f2105 monitor goes immediately to sleep mode
Sounds like your monitor is not processing the resolution signal from the graphics card. Reboot the computer in "safe mode with networking", from there you can play around with the resolution, start low resolution and work your way up to test the monitor.
Sep 07, 2009 | HP f2105 21" LCD Monitor
The monitor turns white immediately after being turned on for about two seconds; and then immediately turns off leaving an un-powered screen. Repeating this process to gain access the control buttons does...
the problem is most likely you graphics card, if you have installed more than one graphics card you will most likely not get any picture from this.
remove any newly installed graphics card until you have installed the drivers for the latest one.
Aug 11, 2009 | BenQ FP71G 17" LCD Monitor
A Gateway GTW-L17M103 will not power on, no power lights/menus.
Have you read the manual for trouble shooting? Is there a reset button on the unit?
Screen brightness is diminished?Video display devices experience degradation of brightness over the life ofthe device. Normal brightness degradation is not covered by your warranty.
You cannot see a picture?Make sure that the power cord is plugged into a grounded electrical outlet.?Make sure that the power button is turned on.?Make sure that the selected input source is connected to a working inputsource.?Press thecorrect input source.?If your LCD TV is connected to your computer in RGB or DVI mode, pressany key on your keyboard to "wake" your computer.You see a distorted picture or hear unusual sound?You may be getting interference from electrical appliances, cars,motorcycles, or fluorescent lights. Try moving your LCD TV to anotherlocation.The color is abnormal?Make sure that the input source cable is connected securely and correctlyto the back of your LCD TV.
Get schematics and look for fuse and voltage points
Feb 28, 2017 | Gateway LCD17TV 17 in. Television
OSD main menu pop-up will not go away
Please try to Turn the monitor off. Hold down the Menu button while the monitor is turned off, then press the Power button again to turn the monitor back on. This should unlock your OSD menu and remove that message from your screen. best regards
May 19, 2009 | HP Pavilion F1703 17" LCD Monitor
3yr old got ahold of monitor
ok, get to the event where you get this to happen "...then turn it back on the monitor does come on normally...", but just after power-up, press the F8 key to go to safe mode. If nothing visible, press ENTER anyway...get to safe mode yet?
Oct 27, 2007 | Computers & Internet
Computers & Internet Logo
David Payne
David Payne
