Question about HP Photosmart A526 photo printer
I just installed my brand new printer cartridge in my hp a526 printer (NEW) and when I follow the instructions for set up to perform printer alignment it failed and will only print re and yellow colors even after cleaning the printer cartridge in the cleaning mode in the machine, can you help me please.
  • HP Master
  • 17,129 Answers
First of all if there is a procedural fault when a new ink cartridge is installed this fautl can occur.
So first of all remove the printer, Uninstall the software. the reinstall the printer software and on instruction connect the printer to the PC. The new harware will be now installed .
make a test print. It must work fine.
Failing this test there can be errors in the printing head / main board.
Posted on Sep 11, 2010
Hewlett Packard HP 2140 how do I re-install the drivers
HP loves to screw with their customers! The software in the printer will not recognize an expired cartridges! Check the expiration date on your cartridge, if expired, replace it. one word of caution! When replacing cart in HP units do so carefully and delicately. There are 2 very small plastic teeth that hold the cart in position, if you break one off you will keep getting a "replace cart" error even though its brand new. Be careful!
Aug 11, 2014 | Office Equipment & Supplies
I have an HP Photosmart A526 printer. I have tried 2 new cartridges and neither print yellow. I thought it was a fault with the cartridges but now think it may be the printer. I have aligned and...
There are two possible malfunctioning in this case.
  • Issue with the cartridge.
  • Issue with the printer.
Its better if we start resolving this issue linearly and logically first by following these steps as given in the manual on the following link.
Please click here:
Missing, Faded, or Dull ColorsIf the above doesn't help, we might try a printer reset to bring it back to the default print settings and configuration.
Performing a Partial Reset
  1. Disconnect any universal serial bus (USB) cables attached to the printer.
  2. Open the print cartridge door and remove the print cartridge.
  3. Close the print cartridge door
  4. Press the Power button to turn the printer off and wait for the printer to shut down before proceeding to the next step.
  5. Unplug the printer AC adapter from the printer and the wall outlet or surge protector.
    NOTE: The adapter itself has an overload trip that may need resetting, but will not reset if power is flowing to it.
  • Wait approximately fifteen to forty-five seconds and proceed to the next step.
  • Plug the AC adapter back into the wall outlet, and then into the printer, but do not plug in the USB cable.
  • Wait for the appropriate missing print cartridge error to verify that the printer can recognize this error.
  • Open the print cartridge door and re-insert the ink cartridge.
  • Print an internal test page.
    1. Remove any memory card, if inserted.
    2. Use the arrows (c01070297.jpg ) to highlight Print test page .
    3. Press Print to begin printing a test page.
    This is how the Test Page looks like:
    If still the printer is not printing the way it should, we might think of going for a HARD RESET by following the steps below:
    Performing a hard reset of the printer
    1. Unplug the power cable from the back of the product.
    2. Unplug the power cable from the electrical outlet.
    3. Wait 15 seconds.
    4. Reconnect the power cable into the product and then reconnect the power cable into the electrical outlet.
    5. If the product does not turn on, press the On button.
    This should bring the printer back to normal.
    Wish you luck.
    Regards,
    techbuddy247
    Nov 15, 2010 | HP Photosmart A526 photo printer
    Hp printer model A909a indicated new ink cartridge needed. When I installed new cartridge kept giving message needed new cartridge. When I removed new cartridge ink was leaking on outside edge of...
    Follow the instructions below to replace the printheads in the All-in-One product.
    Video of replacing the printhead
    The following video demonstrates how to replace the cartridges and the printhead. You do not necessarily need to replace the cartridges. Simply refer to the video for replacing the printhead, and then stop the video.
    Aug 28, 2010 | HP Office Equipment & Supplies
    Won't work after installing new ink cartridges
    This can happen to cartridges with attached print heads such as HP, Lexmark or Dell. All cartridges are weighed and tested before leaving the factory so lack of ink isn't the problem. It usually has to do with the print head of the cartridge not having any ink to feed it. This happens because cartridges are kept flat or upside down for weeks or months before being used and the ink settles away from the print head. The easiest remedy is to open the box and stand the cartridge upright for a few minutes before using. Then get a damp paper towel, fold it into quarters and sit the cartridge print head down onto it. Hold the cartridge down to the damp paper towel for three minutes. This will help pull the ink out of the print heads, priming them and getting them ready to print. Finally, install the cartridge into your printer and print a few test pages.
    Feb 19, 2010 | HP DeskJet F380 All-In-One Printer
    HPC8180 Did not follow intitial instructions and now have ink system failure. Hp unable to help sent me brand new ink cartridges, I tried to reset with no success. Any help?
    Follow the instructions on this web page http://www.ccl-la.com/blog/index.php/hp-photosmart-ink-system-failure-1/ to prime ink through the lines and hopefully clear the error. I don't know why HP sent you new ink cartridges when it should be obvious to them that the cartridges are not the problem.
    Nov 25, 2009 | HP Photosmart C8180 InkJet Printer
    Error message on HP 2800 business inkjet, message reads 1% ink left on brand new cartridge
    View the user manual here. http://bizsupport2.austin.hp.com/bc/docs/support/SupportManual/c00449611/c00449611.pdf
    go to page 60 and follow the instructions for replacing the ink cartridge, remember to have the printer on when you do.
    Then go to page 62 and allign the print head automaticly following the instructions it gives.
    This will re-callibrate the ink level on the printer and should read correctly for you.
    Thanks
    CompuFirm
    May 27, 2009 | HP Business InkJet 2800 Printer
    HOW DO I CLEAN MY PRINTER CARTRIDGES/HEADS?
    For using the HP Deskjet 5000 series Printer Assistant:
    1. Double-click the 5000 series printer assistant icon on the Desktop of the computer.
    2. Click Utilities .
    3. Click Printer Maintenance .
    4. Click Clean Cartridges .
    5. Follow the on-screen instructions.
    read info on this HP link:
    http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09339&cc=us&lc=en&dlc=en&product=71896
    copy and paste the complete link into your browser.
    If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
    Thanks, Joe
    Nov 15, 2008 | HP DeskJet 5550 InkJet Printer
    My HP Photosmart D7360 will not print black, despite changing cartridge and performing print-head cleans My printer shows there is ink in the cartridges according to the monitor, plus the black and yellow...
    Hi rfillmore, I would suggest you update your printer drivers, try this, follow instructions exactly as written:
    Create a new folder on your desktop and name it newhpdrivers(substitute your manufacturer in new name). Un-intall printer and printer software completely. Go to manufacturers website and navigate to their drivers/downloads or support menu. Select your model, choose the relevant software and download to the new folder you created on your desktop(watch for the light yellow bar at the top of window viewing pane, click on this and choose – download file - . Power down your computer. Reconnect the printer to the computer and turn printer on. Power on pc. Windows will detect new hardware and ask if you have the manufacturers install cd or a location to check for install files. Direct the wizard to your new software, follow the rest of the setup instructions and your done.
    anaanymous
    Rate Me Please! Hate it? Rate it…Like it, try it!
    Thank you for submitting your question to FixYa.com
    Would you please take a moment and show your appreciation by rating my performance.
    All ratings and comments are welcome. Thank you - anaanymous
    Oct 21, 2008 | HP Photosmart D7360 All-In-One InkJet...
    HP Photosmart A526 photo printer Logo
    137 people viewed this question
    Seeker5211
    Seeker5211
