Question about Maytag Refrigerators
I have a Maytag Performa side by side refrigerator, model number PSD262LHEW. When I change the water filter water flow drops to almost nothing. I have tried three filters (Pur # UKF8001). I let it run to get the air out but then after a few seconds water flow drops to almost a dribble. interesting is that is I remove the filter and install the filter bypass it flows like gangbusters! Any ideas?
Richie_asg1
  • 1036 Answers
SOURCE: Krups FME2 will not flow water.
Does it sound like it is boiling water at all?
If it is boiling, but not giving hot water, then the one-way valve is stuck.
If it is not getting hot (on the soleplate base) then usually the element has blown.
These machines use the steam generated by boiling as a means to move the water up - like a geyser, and need the heat to move the water.
Replacement elements are available, and the valves usually just require cleaning.
Posted on Jun 29, 2008
MNTECH
  • 1543 Answers
SOURCE: Water won't flow from GE Smart Water under-sink RO water filter
Disconnect the water pressure tank making sure the end the line hooks up to is open. The tank should be relatively light, and if you shake it you should not hear any water. If you hear water in it, or it feels heavy, that means the bladder inside the tank has failed. Replace the tank with a new one, and set the pressure on the bicycle type valve at 8 PSI before you connect the tank up to the water line.
Posted on Dec 09, 2008
  • 111 Answers
SOURCE: GXRM 10 GBL 02 under
No on the air bleed out, probably so on the water line reversed suspicion
Posted on Dec 19, 2008
  • 2976 Answers
SOURCE: Water flow on my Maytag ICE20 is very slow.
The orifice into the filter is getting clogged. A toothpick or small paperclip will clear it.
Posted on Jul 21, 2009
SOURCE: Water dispenser slow flow after filter change
I had the same problem when switching to Pur filters. There are two curved wedges inside the end that hold the filter away from its connection. It turned out that they were just a little to short, putting the end of the filter to close to the connection, and that's all it took to restrict the water flow. I went to the hardware store and found a thin plastic washer that would add some space (it was for a faucet diverter of some kind, thinner than a dime). It added just enough space for good water flow. Another benefit was it helped stop the icemaker line from freezing. A simpler solution might be to make sure to get factory-original filters.
Posted on Jul 30, 2009
Maytay model PSD262LHEW refrigerator or freezer does not cool at all
Could be the compressor is gone or the cooling gas is depleted.
Oct 05, 2014 | Maytag Refrigerators
Water dispenser and ice maker not working properly.
If the water flowed normally for a few years and now will not fill the ice maker with enough water to make full size cubes or dispenser fill too slow the problem may be a defective=> 67005154 Water Inlet Valve In the tutorial above I want you to listen carefully of all the possible items that can cause slow waterflow. I am here should you have questions Thanks Sea Breeze
May 25, 2013 | Maytag 26 cu. ft. Wide-By-Side...
Maytag ice maker floods the kitchen when water does not shut off when filling the ice tray. What's the reason and fix?
What is the refrigerator model number? In most cases the dual water control valve with have a mechanical defect and cause the water to flow by the valve even when off. W10408179 Water Inlet Valve
If you can find your model number around the fresh food section door frame please post so I can insure I give you the correct part numbers, Thanks Sea Breeze
Dec 04, 2012 | GALAXY Microsystems 25.4 cu. ft....
Side by side Maytag frig.dispenser water is slow. model MZD2665HEB I changed water filter .water flow is slower than normal.
When a water filter is replaced alot of air gets compressed in the plumbing and the filter which will cause a temporary reduction in the flow rate until the air is bled out through normal use.
Jan 15, 2011 | Maytag MSD2756G Side by Side Refrigerator
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house in June. The change filter light came on a few weeks ago and I can't get it...
I have a Maytag side by side with water/ice dispenser in door and filter for water. I changed the filter upon moving into house the change filter light came on and I can't get it to go off. How do I reset the change filter light (it's not time to change the filter)? The model # is MSD2732GRW and I don't have a manual for this refrigerator. Thanks!!
Sep 07, 2010 | Maytag Refrigerators
Turn off the change filter light on maytag refrigerator
For my Maytag Refrigerator Model # MSD 2756 GE, I had to hold the "Light" & "Lock/Unlock" buttons simultaneously until the "Change Filter" light went off instead of the "Water" & "Lock/Unlock" buttons.
Oct 09, 2009 | Maytag MSD2651 HE Side by Side...
I have a performa pds262lhe7 refrigerator. the water runs slowly and the ice maker hardly works. do i need a new water filter?
Your filter is clogged. Replace the filter in the refridge side, it is located on the top right hand side.
Mark
Jul 05, 2009 | Maytag MSD2756G Side by Side Refrigerator
No water pressure
I can send you a repair manuaql if you like. You also can just ge a prefilter from lowes or home depot and just bypass the filter ion your fridhe. I know about the water there. Live there for six years. Thanks Sea Breeze
seabreezehvac@yahoo.com
Mar 23, 2009 | Maytag MZD2766GES Side by Side...
Refrigerators Logo
158 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
